Failed new gland nut
Braukuche
Braukuche is offline
PostPosted: Tue Mar 20, 2018 1:43 pm    Post subject: Failed new gland nut Reply with quote
Bought this from Wolfsburgwest along with my new WW stroker crank for my Okrasa project an this happened luckily while just doing the end play. Stripped out just using a breaker bar! Anyone else here of this? I ordered another one from AA, hope Wolfsburgwest is selling their gland nut. What a piece of garbage.
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
Sharp64
Sharp64 is offline
PostPosted: Tue Mar 20, 2018 1:45 pm    Post subject: Re: Failed new gland nut Reply with quote
Had the same thing happen on a buddies car. We forgot the washer and it bottomed out and stripped.
1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine
Braukuche
PostPosted: Tue Mar 20, 2018 2:08 pm    Post subject: Re: Failed new gland nut Reply with quote
I had the washer on it. Was yours also a WW one?
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Sharp64
Sharp64 is offline
PostPosted: Tue Mar 20, 2018 2:18 pm    Post subject: Re: Failed new gland nut Reply with quote
Nope. Oddly after putting the washer back on and torquing it it tightened back up.
1967 Ghia
snowbug
snowbug is offline
PostPosted: Sun Apr 01, 2018 10:54 am    Post subject: Re: Failed new gland nut Reply with quote
looks like a 1600 gland nut. They are different than 36hp.
Old enough to remember THRILLS, the gum that tastes like soap.
Braukuche
PostPosted: Mon Apr 02, 2018 12:57 pm    Post subject: Re: Failed new gland nut Reply with quote
Really? In what way?
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Mon Apr 02, 2018 3:16 pm    Post subject: Re: Failed new gland nut Reply with quote
36 HP is shorter and the shoulder is different. I'll look later and see if I can take a pic of the differences.
Did you look and see if it was the same as an old one?
Here's a crappy pic from an old ad
https://www.thesamba.com/vw/classifieds/detail.php?id=751701
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
Braukuche
PostPosted: Tue Apr 03, 2018 6:39 am    Post subject: Re: Failed new gland nut Reply with quote
WOlfsburgwest advertises it as a German gland nut explicitly for 36hp. I think I still have it I will compare it to others I have.
I bought one from AA which is advertised as for any VW engine and it worked fine.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
&Dan
&Dan is offline
PostPosted: Sat Apr 21, 2018 11:16 am    Post subject: Re: Failed new gland nut Reply with quote
Yeeesh...just bought a WW gland nut for a customer's vehicle...think I will use the old one w/ a new bearing.
Been having a bit of difficulty w/ WW parts as of late, dumb things like not fitting. Hmmm.
