ChapinBusDude Samba Member
Joined: June 25, 2013 Posts: 131 Location: South Carolina
Posted: Sat Apr 21, 2018 6:14 am Post subject: Rear Brakes Problem |
Another question about the rear brakes this time guys, well it actually a general VW brakes observation and question.
The connecting bar that levers the hand brake. When I install it with the "dimple" down, it makes contact with the backing plate retention bolts. When I try to center the shoes to make clearance for the drum to fit, when I tap the shoe that is messing up the clearance down (tap, tap, tap), the connecting bar levers the other shoe up because it is touching the backing plate bolts. This just moves the drum clearance problem to the other spot on the drum. Does the connecting bar "dimpled" side go up or down?
Looks like I have two connecting bars from the same side. One ends up with the dimple pointing up and clears the backing plate bolts while the other side has to have the dimple pointing down and gets in the way like this. I guess I could grind off the dimple enough to make things work, or I could find another one that is situated for the clearance. What is right? Picture below...
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Sat Apr 21, 2018 7:15 am Post subject: Re: Rear Brakes Problem |
there's no left and right bar...both the same part, dimple up one side and down on the other...your photo shows the bar on the lever end attached too low and not in the notch in the shoe....and you need to back off the nut on the handbrake cable so theres no tension on the handbrake arm...after drums are back on and shoes properly adjusted then you adjust handbrake |
Posted: Sat Apr 21, 2018 10:46 am Post subject: Re: Rear Brakes Problem |
I'll check that out! Thanks! |
Posted: Sat Apr 21, 2018 1:15 pm Post subject: Re: Rear Brakes Problem |
Ok Volksworld, it's gotta be awesome to be you! Really.... I appreciate the good catch and when you give spot-on advice and the guy's thankful - gotta feel awesome. Thanks! |
Posted: Sat Apr 21, 2018 7:32 pm Post subject: Re: Rear Brakes Problem |
you're welcome...every now and then i do something right... |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Sat Apr 21, 2018 8:17 pm Post subject: Re: Rear Brakes Problem |
Yeah, never made any sense to me why VW never made a mirror image of the brake "spreader" part for the other side !! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Sun Apr 22, 2018 5:24 am Post subject: Re: Rear Brakes Problem |
Cusser wrote: |
Yeah, never made any sense to me why VW never made a mirror image of the brake "spreader" part for the other side !! |
Second production process for an unneeded part....Not efficient...We ARE talking about Germans.... _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Sun Apr 22, 2018 7:11 am Post subject: Re: Rear Brakes Problem |
if they had people could then install them on the wrong sides... |
Cusser Samba Member
Posted: Sun Apr 22, 2018 8:35 am Post subject: Re: Rear Brakes Problem |
volksworld wrote: |
if they had people WOULD then install them on the wrong sides...the same ones who don't know to work on one side at a time !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
njg02 Samba Member
Joined: October 11, 2007 Posts: 92 Location: Australia
Posted: Sun May 27, 2018 3:29 am Post subject: Re: Rear Brakes Problem |
So which side had the dimple up? Should be the same on all cars.
I don't want to break my brakes so I'm having a break until I find out what brake should have the dimple up. That way when I brake with my brakes I won't break anything.
Thanks. |
Cusser Samba Member
Posted: Sun May 27, 2018 7:37 am Post subject: Re: Rear Brakes Problem |
njg02 wrote: |
Thanks. |
Gimme a break !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
AlmostHeavenWV_VW Samba Member
Posted: Sun May 27, 2018 8:43 am Post subject: Re: Rear Brakes Problem |
Cusser wrote: |
njg02 wrote: |
Thanks. |
Gimme a break !!! |
Are you asking for a Kit-Kat bar, Cusser? _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
njg02 Samba Member
Posted: Sun May 27, 2018 5:08 pm Post subject: Re: Rear Brakes Problem |
Mr Cusser. Well done.
I'll have some of the Kit-Kat please. They break easy! |
njg02 Samba Member
Posted: Mon May 28, 2018 1:33 am Post subject: Re: Rear Brakes Problem |
Fixed.
Turned the cross brace over.
It appears that the adjusters at the bottom have a slight angle in the slot. Turned one around, moved everything to where I thought it should be moved to and the drum slipped on nicely.
Nearly have brakes. Time for another rest. |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Mon May 28, 2018 4:00 pm Post subject: Re: Rear Brakes Problem |
One end of the bar is cut with a wider slot to fit around the parking brake lever (the arm that is pulled by the parking brake cable). The wider slot should be to the rear and offset to the outside since the parking brake lever is mounted to the rear shoe and attached to the outside face of the shoe.
The common mistake is to think the "dimple" is to allow space for the spring. The dimple is there to stiffen the bar and prevent it from flexing. Without it the bar would flex/bend. It doesn't matter if it is up or down, as long as it properly fits on the brake shoes.
Knowing which side had the up/down dimple is really the wrong question. Some aftermarket maker could produce a part with the dimple on the opposite side from stock. It would still work since the dimple is there only for strength. And if someone DID make a left and right side bar set with the dimple always down, you would be stuck because the side which you expected to be dimple up would no longer fit, because you were following a silly expectation. Similar to the expectation that the dimple was spacing for the spring. _________________ AshMan40
njg02 Samba Member
Posted: Mon May 28, 2018 9:48 pm Post subject: Re: Rear Brakes Problem |
Thanks for that Ashman. I understand.
But, does this look correct?
[/img] |
