67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9663 Location: Oregon
Posted: Sun Apr 22, 2018 11:00 am Post subject: Re: To EMPI or not to EMPI... (34 EPC) |
jpaull wrote: |
Bob,
With the actual weber 34 icts the weak point is the throttle shaft that just rides in the carb body (no bearing) so it wears out the soft aluminum and then gas/vacuum leaks past. My educated guess is the chinese 34's will be even softer, and wear out sooner.
Do you have any idf stuff? |
He's building a single port Jeff.
I made the same suggestion yesterday in another thread he posted in. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3456 Location: Paradise, Ca
Posted: Sun Apr 22, 2018 11:13 am Post subject: Re: To EMPI or not to EMPI... (34 EPC) |
67rustavenger wrote: |
jpaull wrote: |
Bob,
I made the same suggestion yesterday in another thread he posted in. |
Thanks for the fyi, yes that makes since now lol. _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Bob Brugge Samba Member
Joined: April 09, 2015 Posts: 721 Location: Missoula, MT
Posted: Mon Apr 23, 2018 10:53 am Post subject: Re: To EMPI or not to EMPI... (34 EPC) |
no, but how would I run dual idf's on a single port? My intention is to run this motor I am building now until it detonates. Since it is my first build from the short block out AND I used as many of the old school hot rod secrets that I know, I expect it to last maybe 30 seconds, anything else is gravy.
Before this motor does crap out I hope to build a 1955 sp. The bug came with a sp motor and I want to keep it that way, but I want ALOT more power.
Do you have a set of idf's for sale? _________________ Keep on Dubbin'! |
Posted: Mon Apr 23, 2018 11:00 am Post subject: Re: To EMPI or not to EMPI... (34 EPC) |
jpaull wrote: |
Bob,
I read and appreciate the info. Thats why this is called research. I know a guy around here that does bushings so having new ones put in before I run the carbs might be the way to go. I am still curious about the dimensions of the notch between the runners on the vw dp intake _________________ Keep on Dubbin'! |
Frank Bassman Samba Member
Posted: Mon Apr 23, 2018 11:28 am Post subject: Re: To EMPI or not to EMPI... (34 EPC) |
Someone was suggesting IDF's because they thought you were building a dual port. So now there is confusion, is it a single port or dual port?
If single port, dual ICT's, EPC's, or hadrons.
If dual port, you have the above options OR take advantage of the opportunity to run dual throat carbs like IDF's, DRLA's, DCOE's, HPMX, or D Empis.
I personally run dual 1 bb's on my car and I like them but I'm in no way going to debate that dual 2 bbl's wouldn't be better because on a dual port they are IDEAL.
One thing though, whatever you do, DON'T overcarb.
-Frank
-Frank |
Posted: Tue Apr 24, 2018 7:42 am Post subject: Re: To EMPI or not to EMPI... (34 EPC) |
Sorry for the confusion. The easy answer is I am building both. I am just finishing up my 1679 DP motor.
Then I intend to get a second case I have opened up and the sp heads I have opened up and rebuilt. That sp motor wants to be a 1955.
The 1679 is my first build from the short block out, the 1955 will be my first complete build.
Thats the whole reason for going with the itc/epc clones. I can't plop down $500+ for a set of dual bbl's and then plop down ANOTHER $500 or so for a different set of carbs. This way seems ideal on the surface, all I would have to do is buy different intakes.
And I really like the look. To me it reminds me of growing up in the 70's and 80's
Thanks for the read _________________ Keep on Dubbin'! |
p0rschenut69 Samba Member
Joined: March 11, 2012 Posts: 35 Location: Pemberton, BC
Posted: Sun Mar 05, 2023 6:38 pm Post subject: Re: To EMPI or not to EMPI... (34 EPC) |
I installed a single Weber 40idf on a single port 1600 with the EMPI cast aluminium manifold ends and the center section of a Weber style manifold meant to work on a Dual Port with manifold heat tubes and it sure worked well with an 009. It was many years ago but I do remember that it worked really nice and I really liked that engine. It had a stock cam and 1500 Heads. I had installed 30mm Venturies. |
modok Samba Member
Joined: October 30, 2009 Posts: 26741 Location: Colorado Springs
Posted: Sun Mar 05, 2023 8:10 pm Post subject: Re: To EMPI or not to EMPI... (34 EPC) |
It's true
MOST single carb systems actually work better on a singleport, at least SIZE wise.
A SP does not need a smaller carb and intake than a DP, it actually wants slightly larger all else the same.
Or the truth is reducing the extra volume of the intake manifold allows the intake tubes and carb to get away with being slightly larger.
The factory DP intake SHOULD have been a bit smaller and the SP should have been a big bigger, but VW made it the opposite?
I wonder why?
Maybe in development they made the dual port intake bigger enough that it had more power than the SP, because people would be disappointed if it didn't.
Emissions KILLED the singleport, but in mild form a SP bug could have outrun a DP Just building it like it should have been. |
