Mrfun2fly Samba Member
Joined: November 29, 2015 Posts: 548 Location: New Mexico
Posted: Sun Apr 15, 2018 6:55 pm Post subject: 70 Ghia Door Glass removal??? |
Long story short, I need to remove the door glass on the passenger side of my 70 Ghia but note exactly sure how.
Do I just loosen the two bolts inside the tract and pull it out through the top? Do I need to remove the outer chrome trim?
Also what kind of glass is this? will it shatter if we try to cut it? (need to trim it down some or have my local glass shop cut a new piece just a tad smaller on the side....long story)
Thank you for the inside scoops!! |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Tue Apr 17, 2018 3:39 pm Post subject: Re: 70 Ghia Door Glass removal??? |
Quote: |
Do I need to remove the outer chrome trim? |
Yes, and the inner 'felt' strip too. Then it just will pull out..barely _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
swavananda Samba Member
Joined: February 14, 2009 Posts: 889 Location: Can o' Scruz
Posted: Tue Apr 17, 2018 9:20 pm Post subject: Re: 70 Ghia Door Glass removal??? |
If you can get the glass out of the bracket then you don’t need to remove any thing else. But likely it is caked with years of gunk and the rubber sleeve is swollen and brittle. No way to really get lubricant on the backside of bracket with the glass in the door. So if stuck you’ll need to pull the trim and felts .
The glass is curved so you need the specific replacement. A competent glass cutter should be able to wet grind it down.
But the question is why? There is a number of adjustments you can make to get the glass to better fit. Do tell more. |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2876 Location: Auckland, New Zealand
Posted: Mon Apr 23, 2018 2:48 am Post subject: Re: 70 Ghia Door Glass removal??? |
Swavananda is right:There are a number of adjustments you can undertake to make the original door glass fit properly. These are inside the door and on the mechanism holding the glass. There's a thread about this somewhere.
However, a subject I think may not have been discussed elsewhere is this: The door gaps and the qualities of the rubber into/against which the glass has to fit when the window is closed MAY also play a role. If, for example, the door gaps are too small, the glass may appear to be too big. Conversely, the glass may appear to be too small if the door gaps are too big.
Also, if replacement rubbers framing the window have been fitted, they may be of a different size (profile/thickness) to the originals and that may add to the perception that the glass is of the wrong size. I have exactly this problem with the new rubber on my Ghia. More work - when my wife complained just today that I'm "constantly rebuilding this car!" _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
Posted: Mon Apr 23, 2018 6:10 am Post subject: Re: 70 Ghia Door Glass removal??? |
Quote: |
I'm "constantly rebuilding this car!" |
I've been working on this (my) car for over 38 years and I'm not finished yet. The wife _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Posted: Mon Apr 23, 2018 12:20 pm Post subject: Re: 70 Ghia Door Glass removal??? |
kiwighia68 wrote: |
Also, if replacement rubbers framing the window have been fitted, they may be of a different size (profile/thickness) to the originals and that may add to the perception that the glass is of the wrong size. I have exactly this problem with the new rubber on my Ghia. More work - when my wife complained just today that I'm "constantly rebuilding this car!" |
Thanks for the input, i wasn't aware the glass was curved as it appears to be flat.
I'll try to keep it short and simple as to not confuse anyone:)
New seals all around, all the adjustments that can be made have been made including taking it to my local VW shop. W out any luck the window still hangs over (rear section) about a quarter inch. At some point in its life, the car was in a good size accident so it's apparent the body was not fixed properly of which i didn't notice or forgot when i started this project 2+years ago. And now the paint has been done and 95% completed the restoration.
The only thing i can come up with is shaving the glass down to fit:( |
Posted: Mon Apr 23, 2018 12:23 pm Post subject: Re: 70 Ghia Door Glass removal??? |
runamoc wrote: |
I've been working on this (my) car for over 38 years and I'm not finished yet. The wife |
I feel your pain..lol |
