Checking the transmission oil in a 5-speed Cabriolet?
Forum Index -> Water-cooled VW Share: Facebook Twitter
kirk knighton
kirk knighton is offline
PostPosted: Tue Apr 17, 2018 3:18 pm    Post subject: Checking the transmission oil in a 5-speed Cabriolet? Reply with quote
Basically my question is, how do you do it? And do they need checking all that often?
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Tue Apr 17, 2018 3:33 pm    Post subject: Re: Checking the transmission oil in a 5-speed Cabriolet? Reply with quote
Turn steering wheel hard left & look into the wheel well just in front of the driver side tire, you will see a 3" green cap with a VW emblem on it. Just to the rear of that at about the 4 O'clock position on the cap is a 17mm allen plug, remove plug & if fluid comes out you have plenty, if not, add some until it does. If its dark, find the other 17mm plug on the bottom of trans, remove it & let it drain, reinstall plug & fill through first plug at end of transmission (just shy of 2 qts.).
kirk knighton
PostPosted: Tue Apr 17, 2018 4:01 pm    Post subject: Re: Checking the transmission oil in a 5-speed Cabriolet? Reply with quote
Thanks!
oprn
oprn is online now
PostPosted: Wed Apr 18, 2018 3:46 pm    Post subject: Re: Checking the transmission oil in a 5-speed Cabriolet? Reply with quote
Don't let it run low on oil as the 5th gear is in a separate compartment and is the first to suffer from a lack of oil. The needle bearing cages are plastic and the get hot and melt. The first indication of this is it keeps popping out of 5th gear on the highway.
Don't ask me how I know!
volksworld
volksworld is offline
PostPosted: Thu Apr 19, 2018 8:44 pm    Post subject: Re: Checking the transmission oil in a 5-speed Cabriolet? Reply with quote
my all time favorite idiot customer had a slipping clutch...his equally intelligent friend who had driven automatics all his life told him it must need fluid...so he managed to unscrew the plastic plug for the timing access hole and poured a quart of gear oil in the bellhousing....you can't make this stuff up
TDCTDI
TDCTDI is offline
PostPosted: Fri Apr 20, 2018 4:11 am    Post subject: Re: Checking the transmission oil in a 5-speed Cabriolet? Reply with quote
There was a guy locally that stuck his finger in that hole while the engine was running to check the fluid level. I’ve also replaced a couple of clutches due to people trying to use the timing inspection role as a fill plug.
Butcher
Butcher is offline
PostPosted: Fri Apr 20, 2018 5:58 am    Post subject: Re: Checking the transmission oil in a 5-speed Cabriolet? Reply with quote
Finger? Hole? Running? OMG!
Is there any common sense any more?
sgnimj96
sgnimj96 is offline
PostPosted: Sat Apr 21, 2018 6:16 am    Post subject: Re: Checking the transmission oil in a 5-speed Cabriolet? Reply with quote
http://www.brokevw.com/020oil.html
pulling the speedo gear is a way to check it if you are careful, and you can give it the slight over-fill if you need to.
Butcher
Butcher is offline
PostPosted: Sat Apr 21, 2018 7:34 am    Post subject: Re: Checking the transmission oil in a 5-speed Cabriolet? Reply with quote
FYI, if that speedo gear falls off, then you must remove and disassemble the transmission to get it out. Trust me, that is not a good idea, it's not worth the risk. Yes, I was careful.
Never again.
MrPapageorgio
MrPapageorgio is offline
PostPosted: Sun Apr 22, 2018 10:33 am    Post subject: Re: Checking the transmission oil in a 5-speed Cabriolet? Reply with quote
All (well about all) your Cabriolet questions are answered here
http://www.cabby-info.com/index.htm
sgnimj96
sgnimj96 is offline
PostPosted: Mon Apr 23, 2018 6:05 am    Post subject: Re: Checking the transmission oil in a 5-speed Cabriolet? Reply with quote
Never again.
Yikes - good counterpoint
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
