Dustman985 Samba Member
Posted: Mon Apr 23, 2018 8:11 am Post subject: Axle tube problems |
So I pulled the trans out of this '63 Ghia for a client because the axle tube flanges were leaking oil like crazy. I got them sealed up with new gaskets and reinstalled. The left side went together fine, but I'm fighting with the right. I got the tube on, but when I reinstall the bearing and cover and torque them down, it binds. I pulled the bearing to inspect it. It looked fine, and sure enough, the axle isn't clearing the tube. I may just be special enough for a helmet, but what am I doing wrong here?
_________________ 1971 Standard Beetle "The Bombshell"
1995 Ford Aspire (Kia Avella) |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Mon Apr 23, 2018 8:24 am Post subject: Re: Axle tube problems |
Have the fulcrum plates slipped? _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Mon Apr 23, 2018 8:31 am Post subject: Re: Axle tube problems |
Man, I sure hope not. How can I tell for sure? _________________ 1971 Standard Beetle "The Bombshell"
Posted: Mon Apr 23, 2018 8:37 am Post subject: Re: Axle tube problems |
The only sure way to tell is to pull the flange and look. You still have the trans out ? _________________ Rick
tasb wrote: |
sb001 wrote: |
Posted: Mon Apr 23, 2018 8:57 am Post subject: Re: Axle tube problems |
Yep! I pulled the tube off and ran it through its range of motion. Probably also a stupid question, thing ring goes under the bearing, right?
Posted: Mon Apr 23, 2018 9:26 am Post subject: Re: Axle tube problems |
yes the spacer goes under the bearing but it is hard to tell from the pics, it looks like one of the fulcrum plates has slipped. _________________ Rick
tasb wrote: |
sb001 wrote: |
Posted: Mon Apr 23, 2018 9:34 am Post subject: Re: Axle tube problems |
I kinda thought so. They are supposed to lay flush with the spade on the axle, right? I don't have my repair manual on me _________________ 1971 Standard Beetle "The Bombshell"
