Syncronoid Samba Member
Joined: January 21, 2012 Posts: 1111 Location: Stanford, CA and Bend, OR
Posted: Sun Apr 15, 2018 6:11 pm Post subject: If it ain't broken........valve cover bling. |
So, I've been wanting to replace my faded and weathered red valve covers that came with my GW2.5L 60k miles ago. I've got a nice new pair, all painted up to perfection, with new bails and cork gaskets glued in with Gasgacinch, just like 10c recommends here https://www.thesamba.com/vw/forum/viewtopic.php?t=238535 .
Question is, do I risk replacing valve covers that are not leaking and have never leaked for 60k miles for some new ones for vanity?? I do see some very minor seepage along the top of the valve covers, but nothing that causes a drip or anything remotely close to a drip. _________________ '90 Syncro Westy w/GW2.5L |
Gauche1968 Samba Member
Posted: Sun Apr 15, 2018 6:23 pm Post subject: Re: If it ain't broken........valve cover bling. |
What's the risk? _________________ 1984 Vanagon GL
1984 Vanagon Westy |
Posted: Sun Apr 15, 2018 6:57 pm Post subject: Re: If it ain't broken........valve cover bling. |
Leaks. But I think I've prepared everything perfectly. If something can go wrong, it might. Right? Am I just being paranoid? _________________ '90 Syncro Westy w/GW2.5L |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9798 Location: Mt Lemmon, AZ
Posted: Sun Apr 15, 2018 7:06 pm Post subject: Re: If it ain't broken........valve cover bling. |
Leaks are such a minor bother you might as well do it.
Syncronoid wrote: |
...If something can go wrong, it might. Right? Am I just being paranoid? |
I find that things usually go well right up until the moment they don't. |
Posted: Sun Apr 15, 2018 7:22 pm Post subject: Re: If it ain't broken........valve cover bling. |
But I have a perfect track record. No leaks in 60k miles. VC used to say it was one of the driest WBX's they'd seen.
Ahwahnee wrote: |
Syncronoid wrote: |
jimf909 Samba Member
Posted: Sun Apr 15, 2018 10:16 pm Post subject: Re: If it ain't broken........valve cover bling. |
Syncronoid wrote: |
But I have a perfect track record. No leaks in 60k miles. VC used to say it was one of the driest WBX's they'd seen. |
Times are changing. VC moved and you should do something to fix all that dryness. _________________ - Jim
Abscate wrote: |
Posted: Mon Apr 16, 2018 3:45 am Post subject: Re: If it ain't broken........valve cover bling. |
Type 1 owners pop their valve covers every few thousand miles to adjust their valves, sure they sometimes end up with a leak, but if done properly the chances are low. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32584 Location: Reading Pennsylvania
Posted: Sun Apr 22, 2018 3:00 pm Post subject: Re: If it ain't broken........valve cover bling. |
Any recommendations for a good bearing grease to use on the cork gasket? _________________ '90 Syncro Westy w/GW2.5L |
Posted: Sun Apr 22, 2018 4:14 pm Post subject: Re: If it ain't broken........valve cover bling. |
Is bearing grease the goop of choice? I have always used Hylomar. |
Posted: Sun Apr 22, 2018 7:16 pm Post subject: Re: If it ain't broken........valve cover bling. |
For the record, I'm talking about what to put on the cork gasket that will press up against the head. I've heard bearing/axle grease, 20W-50 oil.... I've already used Gasgacinch to mate it with the cover.
Apparently, bearing grease will help keep the cork gasket from drying out. I've heard Hylomar recommended here, too, what is it?
Ahwahnee wrote: |
calo1956 Samba Member
Joined: April 18, 2011 Posts: 700 Location: long Island new york
Posted: Sun Apr 22, 2018 7:41 pm Post subject: Re: If it ain't broken........valve cover bling. |
I have popped my 80 valve covers off 3 times in its short life of 700 miles, and i haven't changed the gaskets, and they don't leak one little bit |
Posted: Sun Apr 22, 2018 8:50 pm Post subject: Re: If it ain't broken........valve cover bling. |
Not sure how that contributes to the discussion.
I just want to do it once and do it right so I get another 60k miles of leak-free operation.
calo1956 wrote: |
danfromsyr Samba Member
Posted: Mon Apr 23, 2018 12:24 pm Post subject: Re: If it ain't broken........valve cover bling. |
yeah good for you.
I've had 2 separate vans suck in the lower edge of the gasket and spew most of it's oil out on the back hatch in a matter of minutes...
now neither of these were set by me, I was the new owner to each van and well there's a 'get acquainted' period with any new adoption.
IMO one should ALWAYS carry a spare gasket in the 'spares kit' along with a waterpump belt.
it's extremely frigging annoying while in the middle of a roadtrip. without the resources to fix it.
calo1956 wrote: |
Abscate wrote: |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10248 Location: N. Idaho
Posted: Mon Apr 23, 2018 8:23 pm Post subject: Re: If it ain't broken........valve cover bling. |
I say go for it. My main thought process is that you're a highly competent wrench (almost said wench) and if it started to drip you would figure it out and we'd all have a good laugh at your expense (after a subdued period while you solved it). A win/win if ever there was one!! And in my version of your future, you will have a pair of blingy valve covers to stare lovingly at when you're doing oil changes.
On the cork, I would actually finger some ordinary motor oil on them before installing them. Grease is just oil with thickeners and the actual lubrication film is handled by the oil in the grease. So if the function of grease is to deliver oil slowly into the cork, then why not get it over with on day 1 and have it uniformly "moistened" against drying?
Anyhow, get those blingy devils on there! _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Mon Apr 23, 2018 8:26 pm Post subject: Re: If it ain't broken........valve cover bling. |
Thanks for the "just f'ing do it' motivation! Well received!
IdahoDoug wrote: |
Anyhow, get those blingy devils on there! |
Posted: Mon Apr 23, 2018 8:39 pm Post subject: Re: If it ain't broken........valve cover bling. |
I was hoping you'd like that! I think it was worth explaining my motives for full disclosure and to appeal to a kindred spirit.
Now I need you to encourage me to "just go for it" with 600 grit and part of a leftover hardwood banister to knock a bit of rust out of the cylinders of the '88 Supra we're working on before I hone them and re-ring. Sat 18 years. Seems sacreligious but talk to someone in their 70s who has done things like new babbit bearings in a car and then dragged it down the street to turn the engine over with great results, and you'll have no more fear. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Mon Apr 23, 2018 8:40 pm Post subject: Re: If it ain't broken........valve cover bling. |
Pics, for shits and giggles........
