wrenchnride247 Samba Member
Joined: August 17, 2010 Posts: 251 Location: Cleveland, TN
Posted: Sun May 10, 2015 6:48 pm Post subject: |
bikerbus wrote: |
wrenchnride247 wrote: |
electronictofu wrote: |
That Bug Tech shifter looks pretty bad ass. I have an EMPI, which some may not like. I like it a lot, I have the same adjustment issues I did with a stock shifter, but the EMPI does shit better than my stock one did.
This Bug Tech looks different than all shifters I've seen. Are they offering screws on the sides for fine tuning adjustments? So you mount it, it's set, then you do your adjustments on those screws? If so that's pretty damn cool. I'd like to find one! I haven't seen them listed anywhere online other than overseas. |
They are made in Germany by Marcus, but his US rep is a close friend of mine in GA http://dtmengineering.com/Bug-Tech_Shifters.php They are fully adjustable. The screws you see are for reverse adjustments. Mine are fine from factory setting with 3000 miles now. Setting the depth of shift ball in shift rod can take some time. |
Is the shift pattern the same as stock, e.g., reverse is left, push down, and back? I can't tell from the video how reverse works.
Thanks!
m |
Yes, the pattern is the same. Reverse works by overcoming the spring tension on the bar that rides next to the shifter on passenger side. You can adjust the pressure to suit how you put it in reverse. You don't push down, just push left towards you (in left hand drive T2's anyway) and then back. _________________ SPL
'62 SC 69x90.5 SP TI
'70 T1 84x105 DP T4 |
MrPolak Samba Member
Joined: June 20, 2004 Posts: 1337 Location: AG ,atnaltA
Posted: Mon May 11, 2015 5:51 am Post subject: |
My sloppy shifter is a theft-deterring device. That's my line and I'm sticking to it. |
Das67bus Samba Member
Joined: April 06, 2008 Posts: 242 Location: Prescott, AZ
Posted: Mon Apr 23, 2018 8:01 pm Post subject: Re: After-market gear shifts |
So it's been awhile and I still have my stock shifter. But, check these out:
https://www.thesamba.com/vw/classifieds/detail.php?id=2145197
A little pricey but they look great!! Wish they were a little less expensive. _________________ SLOW RIDE........TAKE IT EASY!!!
-Foghat
COMFORTABLY NUMB!!
-Pink Floyd |
otis_bartleh Samba Member
Joined: August 19, 2009 Posts: 1106 Location: Burlington, WA
Posted: Thu Apr 26, 2018 11:27 am Post subject: Re: After-market gear shifts |
MrPolak wrote: |
Personally, not a huge fan of that style, I like how the VintageSpeed ones are stock style looking, same reason I got their exhaust... But in my bus, I don't mind the stock shifter, my bug will probably get a VintageSpeed... _________________ -Adam
'59 Mango Bus
'11 Golf TDI 6-speed
'69 Bug |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Thu Apr 26, 2018 11:37 am Post subject: Re: After-market gear shifts |
otis_bartleh wrote: |
Personally, not a huge fan of that style, I like how the VintageSpeed ones are stock style looking, same reason I got their exhaust... |
Fancy-dancy shifters are like fashionable clothes and hair-dos. They're cool and make perfect sense at the moment... but when you look back... they're out of fashion & you're like... "What was I thinking?" Stock-ish / simple is cool... Berg, etc...
Example: bell bottoms, lamb chops, victorian corsets... yikes)
_________________ aka: Evan
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Thu Apr 26, 2018 11:44 am Post subject: Re: After-market gear shifts |
easy e wrote: |
Well, that's a vivid analogy...too bad I'll never have those hips with or without the corset hahaha. _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
JonnyCJ Samba Member
Posted: Thu Apr 26, 2018 12:13 pm Post subject: Re: After-market gear shifts |
I’m running an OG vintage Hurst shifter. It’s really solid, shifts great and so good that empi copied it for their design (allegedly)
Help Help Samba Member
Joined: May 03, 2013 Posts: 117 Location: Running willy-nilly with scissors in So Cal
Posted: Thu Apr 26, 2018 10:04 pm Post subject: Re: After-market gear shifts |
Are there any other reasonable alternatives to the Berg locker? Been lusting after one for while be putting my $$ elsewhere. |
easy e Samba Member
