syncrogreg Samba Member
Joined: November 08, 2009 Posts: 742 Location: USA (Nashville TN)
Posted: Fri Apr 27, 2018 7:42 am Post subject: Re: Pastis, The Ultimate Subaru Boxer diesel EE20 Vanagon Syncro |
So I'm trying to reuse the stock cruise control switch for my new "Crawl control" that is a sort of an RPM freeze but the fueling will follow as needed. . even though it stay at the given RPM.
Anyway, I pulled my multimeter and Bentley and I cannot find the action that the "SET" button does. It looks like the BK wire and R/Y would contact but nothing happens. I tried 2 switches in case this one was bad. . But no luck!
I tried all combinations possible with my multimeter and nothing happen when that "SET" button is pushed! So annoying.
Let me know if you have any ideas! Any gurus out there?
Greg _________________ conversions: www.boxeer.com Common rail TDI and NOW PDK transmissions!!
travel pictures:
http://instagram.com/crepeattack/
- the Pastis build: http://www.thesamba.com/vw/forum/viewtopic.php?t=434656&highlight=subaru+diesel |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6347 Location: Honolulu,Hawaii and France
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Fri Apr 27, 2018 12:03 pm Post subject: Re: Pastis the Syncro with 2.0 TDI Common rail conversion |
Pin 1: (Black / Blue OR White) = Switched on/off from CC Unit
Pin 2: (Blue) = Resume
Pin 3: (Red / Yellow OR Red) = Set
Pin 4: (Black) = Power +12V w/ Ignition On (15)
Before installing the cruise stalk I hooked pin 4 up to 12v, pressed the buttons, and verified with a multimeter that it was sending power out where it should. You should see +12v out of Pin 3 when you press Set.
Before testing mine I sprayed MFA cleaner in it and worked all the buttons, spraying a lot more, doing it again, etc. After seeing the thread ALIKA posted, I didn't want to take that thing apart to really clean it... Luckily mine worked.
It sounds like you've already tested the switch with the multimeter... So, sorry if none of this is helpful! |
HBB Samba Member
Posted: Fri Apr 27, 2018 1:16 pm Post subject: Re: Pastis, The Ultimate Subaru Boxer diesel EE20 Vanagon Syncro |
syncrogreg wrote: |
So I'm trying to reuse the stock cruise control switch for my new "Crawl control" that is a sort of an RPM freeze but the fueling will follow as needed. . even though it stay at the given RPM. |
I'm not sure if I fully understand what you are trying to do, but the ECU will already provide fueling to maintain idle RPM regardless of load.
With my ALH-equipped Syncro, I can just let the clutch out and crawl along at 903 RPM up reasonably steep hills. On flatter ground, I can work through the gears and get up to about 20 MPH without touching the accelerator. It's actually darn near impossible to stall. If I want to go faster, well, there's already a dedicated system for that under my right foot.
One caveat: I am not familiar with the CR engines, but this definitely works on the AHU and ALH.
Edit: In certain fault conditions the ECU (at least on the AHU and ALH) will revert to a fixed 1200 RPM's. I ran into this with a short at one point and chugged home in city traffic with little problem, it was actually sort of fun to put around with no accelerator input. I am sure that someone out there has figured out a way to either exploit this feature or create a similar high idle condition. Maybe a tuner would have some suggestions? I think this mode is triggered when the ECU sees brake and accelerator input at the same time, so there is also the possibility of rigging up some sort of switched mode as well, where you can flip a toggle and get into a high idle. |
mackaymanx Samba Member
Joined: October 12, 2006 Posts: 479 Location: Australia
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17112 Location: Retired South Florida
Posted: Tue Jul 03, 2018 10:21 am Post subject: Re: Pastis the Syncro with 2.0 TDI Common rail conversion |
Tachs from the digijet vanagons seem to work with the output from the tach output of the ALH ECU. Not sure why. It is not 100% accurate though. I have it adjusted to be accurate at 3000 rpm. Its mostly visual vs a dead gauge.
My cruise control will not engage below a certain mph. That said, it might be the relationship to the VW VSS and how the ECU interprets the mph. For my scan gauge to be accurate, I had to put in a lot of adjustment for it to match my GPS.
The VCDS shows the indicated MPH that the ECU is processing. I understand there is no way to adjust what the ECU displays. My chip is stock and is one of those early ones that has the chip soldered to the ECU board. _________________ ☮️ |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Tue Jul 03, 2018 1:51 pm Post subject: Re: Pastis the Syncro with 2.0 TDI Common rail conversion |
syncrogreg wrote: |
Thanks! Just ordered 220Kohms online.. because RadioShack ran out of business...now it's big wait for just a resistor . Where do you guys find resistor locally now that RadioShack is gone???
Thanks |
I got mine off the shelf at Hardware sales in Bellingham - best store in the whole world!! _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
OddN Samba Member
Joined: August 19, 2010 Posts: 690 Location: Northern Norway
Posted: Wed Jul 04, 2018 2:49 am Post subject: Re: Pastis the Syncro with 2.0 TDI Common rail conversion |
Fascinating idea with that Crawl Control.
Are you using the built in cruise control feature in the TDI software, and if so how are you altering the minimum speed requirement within the software? Can it be changed via VCDS or other diagnostics tools, or are you manipulating the speed signal from the speedometer? _________________ 1991 VW Multivan syncro 1,9 TD |
Posted: Wed Sep 19, 2018 12:33 pm Post subject: Re: Pastis the Syncro with 2.0 TDI Common rail conversion |
After 70000miles old CV boot shot!! New CV axles(32.3mm) GKN have wider diameter than stock (28.6mm). They will not clear the FOC SHOX... I asked Gowesty and they recommend to take the lower suspension bushings and grind one side and add a washer on the other side. To make a shift and clear the fox shox...
So here I am digging deep into the front end to replace that CV. It was time anyway because I noticed lower and upper ball joints shot also my studs started to get some play and would move around some when I would change a wheel I could just shake these studs a bit!!
travel pictures:
Pcforno Samba Member
Joined: October 14, 2014 Posts: 575 Location: Santa Fe, nm
Posted: Wed Sep 19, 2018 3:49 pm Post subject: Re: Pastis the Syncro with 2.0 TDI Common rail conversion |
Greg- where is the axle rubbing? On the shock body or the perch? check your alignment, especially the radius rod as it could be too far forward allowing it to rub - I run 930s up front (gkn) and there is plenty of clearance with my foxes. Just don’t want you to start grinding unnecesarily🤓 |
Posted: Wed Sep 19, 2018 3:50 pm Post subject: Re: Pastis the Syncro with 2.0 TDI Common rail conversion |
Posted: Wed Sep 04, 2019 7:37 pm Post subject: Re: Pastis the Syncro with 2.0 TDI Common rail conversion |
Pcforno wrote: |
hey there! year later... the axle was rubbing on the axle but turns out you can loosen the whole controle arm and links and "make some room" with a pry bar...
thx for checking bud!
travel pictures:
Posted: Wed Sep 04, 2019 7:48 pm Post subject: Re: Pastis the Syncro with 2.0 TDI Common rail conversion |
I have recently investigated the possibility to re-gear the transmission to be able to hit the Syncroranch property with ease.... it is very steep and I would like to use max potential of my syncro. that said i do like to cruise on interstate.
i have found that the 6.17 final drive on 30.5' tires and 0.70 4th would let me cruise at 70 mph at 3300 rpm
it's reasonable I think.... i love the idea to go a whole 1 mph slower in granny gear than the current setup.
travel pictures:
Posted: Mon May 04, 2020 8:33 pm Post subject: Re: Pastis the Syncro with 2.0 TDI Common rail conversion |
So I'm going to try something new and I hope it will work otherwise no big problem i'll go back.
Here is the plan: to link one of my most powerfull version TDI CR code CUAA with 340HP and a lot of torque and boost right from 1100 RPM to the Porsche PDK AWD which has 7 speed and dual clutch.
I have 2x trans for this project one that is going to stay on the R&D Lab and the other one mounted in my van.
Originally I'll drive the transmission in the stock form to proof of concept and if all the initial requirements check just fine I'll make the custom R&P to be best scenario of 7 gears usage wich will be crawl in 1st gear at 1000 rpm @ 4MPH and 7th gear with 3000RPM @ 75mph
I already opened the 2nd PDK AWD for Diff analysis and it's super promising with a HUGE diff in the PDK and a R&P that is a pinion shaft with only one gear reducing gear mounted. so as a result super short!
Here you can compare both rings and I have to say if I can brake that PDK one I'll be surprised!
Please take care these days
travel pictures:
D Clymer Samba Member
Joined: December 22, 2005 Posts: 2978 Location: Issaquah, WA
Posted: Mon May 04, 2020 8:50 pm Post subject: Re: Pastis the Syncro with 2.0 TDI Common rail conversion |
You go, Greg! I'm not too surprised by how robust the diff is considering the power that's meant to harness in a rear heavy 991 with super wide tires. How are the external dimensions looking for installation into a Vanagon? The length looks reasonable, but is the height going to work out?
Keep up the good work. I love seeing new drive train adaptations into these Vanagons. |
