What to do with air snorkels?
4118thing
4118thing is offline
PostPosted: Sun Apr 29, 2018 6:58 am    Post subject: What to do with air snorkels? Reply with quote
In a recent thread I learned one thing. “Thou shall not cap off air snorkels “.
So my question is what are the alternatives. I’d like to have the engine compartment as clean as possible. Also would like to have a clean breast plate at the rear of the engine.
1. Can I run the hoses around the back side of the fan shroud and just let the air “recycle”.
2. I’d like to replace the heater boxes with j tubes. If I push the air out through the breast plate, I don’t have as clean look.
3. What happens if I just leave the snorkels open? Presumably, it’s just pushing ambient air around.
Captain Spalding
Captain Spalding is offline
PostPosted: Sun Apr 29, 2018 2:57 pm    Post subject: Re: What to do with air snorkels? Reply with quote
What is a breast plate?
Mal evolent
Mal evolent is offline
PostPosted: Sun Apr 29, 2018 4:12 pm    Post subject: Re: What to do with air snorkels? Reply with quote
you may remember this singer from the '80s, called herself Madonna...
73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index
HMVWNAB
HMVWNAB is offline
PostPosted: Mon Apr 30, 2018 7:14 am    Post subject: Re: What to do with air snorkels? Reply with quote
Think he’s referring to the tin that covers the exhaust and butts up to pulley.
What are the last 2 words of the National Anthem?
PLAY BALL!
CraigInPA
CraigInPA is offline
PostPosted: Mon Apr 30, 2018 7:33 am    Post subject: Re: What to do with air snorkels? Reply with quote
Assuming by "snorkels" you mean the aluminized tubes from the heater boxes, I think your best solution would be to change the heater boxes to J jubes, the "breast plate" to a 1973 "breast plate" without the holes, and a 1973 fan shroud without the ducts.
74 Thing
74 Thing is offline
PostPosted: Mon Apr 30, 2018 8:25 am    Post subject: Re: What to do with air snorkels? Reply with quote
I think he is referring to the heater outlets on the fan shroud.
73 Things used a doghouse shroud without heater outlets
https://www.thesamba.com/vw/classifieds/detail.php?id=2166284
FYI-front refers to front of the car when seated in the car and rear is the back of the car. It is always as seated and facing forward.
HMVWNAB
HMVWNAB is offline
PostPosted: Mon Apr 30, 2018 11:44 am    Post subject: Re: What to do with air snorkels? Reply with quote
PLAY BALL!
Captain Spalding
PostPosted: Mon Apr 30, 2018 2:55 pm    Post subject: Re: What to do with air snorkels? Reply with quote
Ah. Breast plate. I get it. In that case Craig has it right. New fan shroud, new breast plate.
4118thing
PostPosted: Mon Apr 30, 2018 5:28 pm    Post subject: Re: What to do with air snorkels? Reply with quote
The rear plate, the one closest to the rear of the car.
4118thing
PostPosted: Mon Apr 30, 2018 5:30 pm    Post subject: Re: What to do with air snorkels? Reply with quote
Hoping to avoid the cost of a 73 fan shroud.
