Deluxe rear shelf luggage rails; dimensions needed please!
busben
busben is offline
PostPosted: Sun Apr 29, 2018 10:33 am    Post subject: Deluxe rear shelf luggage rails; dimensions needed please! Reply with quote
Yep, me again. Sorry Rolling Eyes
So we're getting close now but one more thing I'm stuck on is the placing of the three chrome luggage rails and the luggage bar itself on the deluxe rear shelf. Does anyone have any dimensions / photos without upholstery / etc?
Looks like all are held in place with bolts through the rear shelf rather than screws?
The location seems different in various buses. Top photo is Si Hitchmans old restored deluxe. Bottom photo more likely original. Positioning seems quite off between the two?!
Thanks so much to anyone who can help with this finishing touch!
Ben
busben
busben is offline
PostPosted: Sun Apr 29, 2018 10:39 am    Post subject: Re: deluxe rear shelf luggage rails; dimensions needed please! Reply with quote
the rails themselves seem to use bolts as discussed in this thread. Still need the positioning etc thank Wink
https://www.thesamba.com/vw/forum/viewtopic.php?t=401714&highlight=luggage+rails
Lazaa
Lazaa is offline
PostPosted: Mon Apr 30, 2018 12:59 am    Post subject: Re: deluxe rear shelf luggage rails; dimensions needed please! Reply with quote
The center one is obviously centered on the bus and here is the measurement for the side ones... The rails are on top of the 4th ribs from each side (which make the middle one lower than side ones !), as shown on the pictures :
busben
busben is offline
PostPosted: Mon Apr 30, 2018 2:12 am    Post subject: Re: deluxe rear shelf luggage rails; dimensions needed please! Reply with quote
Thanks a lot Florian, really helpful. Thanks also to Dave Hall, Rockstock, and especially 10' Doug who took a bunch of photos after removing his engine ..... although I'm not sure he did that just for me Laughing
RockStock
RockStock is offline
PostPosted: Mon Apr 30, 2018 8:51 am    Post subject: Re: deluxe rear shelf luggage rails; dimensions needed please! Reply with quote
Okay, this is a good one.
It's exposed another little known detail - the positioning of the left/right luggage rails and the left/right luggage bar uprights.
Early (narrow)
Middle rail positioned in the centre dip of the luggage shelf panel.
Left/right rails positioned on top of the 6th rib out from centre of the rear shelf.
These rails butt right up to the corresponding upright in front.
The rails point towards the centre of the rear window pillars.
1951-1954
Late (wide)
Left/right rails positioned in the 6th dip out from centre dip of the rear shelf.
These rails (held with 4 scews/nuts) butt right up to the corresponding upright in front.
The rails point towards the outer edge of the rear window pillars.
1954-1955
So the wide upright spacing appears narrower on earlier deluxes.
The change looks to have happened mid-late 1954.
I have seen a 52, a 53, and a few 54s (ie the example shown above) with the early narrow positioning.
All 55s seem to have the wide positioning.
(Btw, on my 55, the lhs rail holes are not in the centre of the dip)
The rails propably wouldn't have been at different heights to each other in the earlier narrow version as the horsehair sound deadening strips, fitted in all the dips, would have padded out the centre rail area.
Cue everyone with replaced luggage shelf panels - or tribute deluxe owners - rushing out to their garage to check their rail positioning! Smile
-StockRocks-
RockStock
PostPosted: Mon Apr 30, 2018 10:45 am    Post subject: Re: deluxe rear shelf luggage rails; dimensions needed please! Reply with quote
-StockRocks-
busben
busben is offline
PostPosted: Mon Apr 30, 2018 2:59 pm    Post subject: Re: deluxe rear shelf luggage rails; dimensions needed please! Reply with quote
Just cracked a beer and logged on to explain the early / late difference. Low and behold ..... you've beaten me to it dude Cool
The bother now is that my deluxe was manufactured in the first week of September 1954, just about the time of your predicted changeover. In the absence of any further knowledge I think I'm going to go with the late set up. Maybe rikkis bus will give up some more accurate dating answers this weekend at stanny hall 😉 Don't suppose you know the chassis number of the above pictured '54, or any other later 54's with the "late" setup Chris?
Wonder why this changed so late into production? Did horsehair definately phase out in '54? If so I guess you've nailed it!
Lowdown Dirty Rat
Lowdown Dirty Rat is offline
PostPosted: Tue May 01, 2018 1:29 am    Post subject: Re: deluxe rear shelf luggage rails; dimensions needed please! Reply with quote
The uprights on Rikkis bus might help. But if I remember rightly he had no luggage rails from factory. So perhaps the uprights May be atypically?
1951 Samba 20-017894
1952 Samba 20-028952
RockStock
PostPosted: Tue May 01, 2018 9:38 am    Post subject: Re: deluxe rear shelf luggage rails; dimensions needed please! Reply with quote
The sound deadening was used throughout the bus years.
Yes, Rikki's bus doesnt currently have luggage rails fitted - but Im sure it would have done when new.
Completing this chart should help close in on the changever date:
20-093558 - August 54 - Milan Deluxe - Early narrow version
20-095904 - early Sept 54 - Rikki James Deluxe - Early narrow version
20-096323 - Sept 54 - Landbergsson Deluxe - Early narrow version
20-097352 - Sept 54 - Hausmann Deluxe - Early narrow version
20-099127 - late Sept 54 - TomTom Deluxe - Early narrow version
20-100396 - Oct 54 - Richie King Deluxe - Early narrow version
20-107934 - Dec 54 - Thom F Deluxe - version tbc
20-112232 - Jan 55 - 10ft Doug Deluxe - Late wide version
Rikki James' Deluxe:
Chart suggests it should be the Early narrow version...picture is a bit inconclusive. Guess the difference is only 30mm or so.
*Update 06 May 18: from looking in the engine bay, Rikki's bus has the holes there for the rails. The holes are drilled into the 6th rib, so Early narrow version.
Whilst looking through my pictures I've also concluded the Hornbecker and Milan Deluxes are ridiculously clean!
-StockRocks-
Lowdown Dirty Rat
PostPosted: Tue May 01, 2018 12:42 pm    Post subject: Re: deluxe rear shelf luggage rails; dimensions needed please! Reply with quote
Tom Tom is also early style. And so is the ex Andy Carol/Matt Keene bus. So I think your safe to go early Ben.
Last edited by Lowdown Dirty Rat on Tue May 01, 2018 3:16 pm; edited 1 time in total
Lowdown Dirty Rat
PostPosted: Tue May 01, 2018 1:38 pm    Post subject: Re: deluxe rear shelf luggage rails; dimensions needed please! Reply with quote
And Daves Oct 54 is still early style.
oring71
oring71 is offline
PostPosted: Tue May 01, 2018 2:26 pm    Post subject: Re: deluxe rear shelf luggage rails; dimensions needed please! Reply with quote
March 54
Just noticed the luggage bar uprights are on backwards Embarassed
Das Maltese Kruizers
Lowdown Dirty Rat
PostPosted: Tue May 01, 2018 2:38 pm    Post subject: Re: deluxe rear shelf luggage rails; dimensions needed please! Reply with quote
Best pic I could find of wisks Barndoor of the Woods in a hurry.
Hard to tell. Not outside the sixth, so still early?
Lowdown Dirty Rat
PostPosted: Tue May 01, 2018 3:02 pm    Post subject: Re: deluxe rear shelf luggage rails; dimensions needed please! Reply with quote
10 foot dougs jan 55 is definitely late style and OG.
busben
busben is offline
PostPosted: Tue May 01, 2018 4:07 pm    Post subject: Re: deluxe rear shelf luggage rails; dimensions needed please! Reply with quote
Mine's a little earlier in September than TomTom so that's all great info. Thanks Rob Wink
PostPosted: Tue May 01, 2018 9:39 pm    Post subject: Re: deluxe rear shelf luggage rails; dimensions needed please! Reply with quote
My 2/55 23-Window just for reference, it's the wider style
RockStock
PostPosted: Fri May 04, 2018 5:03 pm    Post subject: Re: deluxe rear shelf luggage rails; dimensions needed please! Reply with quote
The change looks like it happened in Nov 54.
Maybe this was when the old driller got promoted, with the new guy wanting to make his mark.
Last Oct 54 bus was 20-102992.
20-104350 - Early narrow version (Nov 54)
20-104459 - ?
20-104503 - ?
20-106353 - ? (looks Late wide version)
20-107185 - Late wide version (very early Dec 54)
Last Nov 54 bus was 20-106736.
-StockRocks-
YuichiroM
YuichiroM is offline
PostPosted: Mon Oct 14, 2019 7:49 pm    Post subject: Re: deluxe rear shelf luggage rails; dimensions needed please! Reply with quote
Hello
My 20106934 3.dec.54 - late wide version.
