Erik G Samba Member
Joined: October 16, 2002 Posts: 13280 Location: Tejas!
ConcreteAce Samba Member
Joined: May 19, 2005 Posts: 856 Location: Spring, Texas
Erik G Samba Member
Posted: Fri Apr 27, 2018 1:33 pm Post subject: Re: ConcreteAce's '51 build |
ConcreteAce wrote: |
They don't make those in a 16 |
DOH - I know better than that
my bad! my lady friends always complained as well - Sports Bra. Not great far a car with no AC _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Sat Apr 28, 2018 8:24 pm Post subject: Re: ConcreteAce's '51 build |
After running for a while, then stopping and restarting. Try just turning the key, no pedal.
My 54 with Okrasa heads/dual 36IDFs hated when I pressed the gas during warm start ups...just turn the key and it would start right up
For cold starts I would pump the pedal once and start.
Congrats on the trip! |
geneL3c Samba Member
Joined: October 08, 2007 Posts: 296 Location: Bridgehampton,NY
Posted: Sun Apr 29, 2018 8:59 am Post subject: Re: ConcreteAce's '51 build |
Ethan, Having previously had a '50 Deluxe and now a '50 Standard, I can assure you that the less than comfortable ride, handling and brakes of the Splits is the price you have to pay for all the attention you ( deservedly ) get. I sold my first '50 BECAUSE of the horrible ride, but could not resist the more recent acquisition of the '50 Standard knowing this time what I was likely to experience. There was a reason VW went from the ( really ) short front shocks and lever action rears to the longer telescope shocks that came later. If I remember correctly, I would usually take something to settle my stomach if the trip was over a half hour or so ! I'm sure riding in the rear could be nothing short of torturous. Congratulations on a spectacular resurrection of flood victim. Gene |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Thu May 03, 2018 6:26 pm Post subject: Re: ConcreteAce's '51 build |
A little late, but congrats on completion of the split, and a very bold inaugural run. Car looks AWESOME. So glad to have played a small part/contribution, it is the most rewarding thing for me. And oh yeah, there are farm tractors that ride better then splits. The suspension is very stiff... but as Gene said, that is part of the split experience. That and shifting a crash case, and if you are so lucky, driving a cable brake car!!!!
Enjoy it, you earned it. And thanks for sharing the journey.... _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Fri May 04, 2018 7:24 am Post subject: Re: ConcreteAce's '51 build |
BTW, our farm tractor in Texas ( primary residence, Long Island, NY ) has ride, handling and brakes that I can only dream about for the Split. Lucky for you the Deluxe has the so much superior ( ? ) hydraulic brakes ! The Standard cable brakes take a different driving technique, wait and hope ! Enjoy your ride, you've certainly earned it. Gene |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Fri May 04, 2018 7:48 am Post subject: Re: ConcreteAce's '51 build |
Coker makes a 5.50/16 blackwall
Brand: Coker Classic
SKU: 64308
GTIN UPC: 00842199100129
DOT Approved: Yes
Product Size: 550R16
Rim Diameter: 16
UTQG rating: 400 BB
Tread Width: 4.53
Section Width (Actual): 5.25
Overall Diameter: 26.88
Load Index: 91
Speed Rating: P
Max Load Capacity: 1355@41PSI
Recommended Rim Width: 3.25 - 4.00
Tube Type or Tubeless: Tube Type
Michelin still has the good old Michelin X in the same size:
https://classic.michelin.com/en/Classic-Tyre-range/X _________________ regards
Uli
Erik G Samba Member
Posted: Fri May 04, 2018 9:52 am Post subject: Re: ConcreteAce's '51 build |
mandraks wrote: |
SKU: 64308
DOT Approved: Yes
Rim Diameter: 16
UTQG rating: 400 BB
Tread Width: 4.53
Load Index: 91
Speed Rating: P
https://classic.michelin.com/en/Classic-Tyre-range/X |
we were discussing the new bias look radials. those are not available (yet) _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Fri May 04, 2018 10:38 am Post subject: Re: ConcreteAce's '51 build |
Erik G wrote: |
we were discussing the new bias look radials. those are not available (yet) |
i do like the look of those as well, just thought that the Michelin X is definitely a "classic tire" and a radial, and skinny. _________________ regards
Uli
René R. Samba Member
Joined: July 06, 2015 Posts: 1711 Location: No. Calif.
Posted: Tue May 29, 2018 4:33 pm Post subject: Re: ConcreteAce's '51 build |
That's great -- matching original engine, and a Hoffman car to boot! _________________ Gone but not forgotten: 1950 Hoffman split (restored in 1966) - another 1950 Hoffman split (restored in 1996) |
sled Samba Member
Posted: Fri Aug 17, 2018 7:23 am Post subject: Re: ConcreteAce's '51 build |
Ethan, hows this car treating you?
can't wait to see the 25hp fully dressed and full crashbox installed! _________________ drive your split. |
Posted: Fri Aug 17, 2018 9:22 am Post subject: Re: ConcreteAce's '51 build |
sled wrote: |
can't wait to see the 25hp fully dressed and full crashbox installed! |
It has been a joy to drive.It did leave me stranded once, it was faulty plug wires. I had the cool looking cloth braided lines. That was the second set the first set was arcing and I replaced it. I now have the bosch second generation wires on there now. I am taking it on a couple of long trips this next few months. It will be a few years before the big rebuild. I have to recoup from the purchase and what I have done to it so far. _________________ Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'68 Turbo Diesel Baja
'64 Ghia Vert
'61 Baja Build |
sled Samba Member
Posted: Fri Aug 17, 2018 5:04 pm Post subject: Re: ConcreteAce's '51 build |
Have you tried the correct style from Mika Virtanen in Finland? I have a set on my 51 that has about 5500 miles with not a single hiccup. They look correct, unlike all those frilly colored ones
https://www.thesamba.com/vw/classifieds/detail.php?id=1450828 _________________ drive your split. |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Wed Oct 17, 2018 8:02 am Post subject: Re: ConcreteAce's '51 build |
Well on another note does anyone have a lead on a trunkliner. I emailed Wolfgang Gips and he said that they are no longer available. but he did send me a picture of the one I need, but I can not find any other source.
Any help would be great if you know of a source. |
These come in the right type of material and are disassembled. the rivets they send along are wrong, but you can use staple gun staples to assemble as needed
http://www.johnnylawmotors.com/catalog/interior/in...er-mat-kit |
Posted: Wed Apr 24, 2019 2:18 pm Post subject: Re: ConcreteAce's '51 build |
Well doing some preventative maintenance before I take it on a six hour cruise from Houston to Dallas this coming weekend. So far she is running strong, I did have a an issue with the generator nut backing off. I switched to a big nut pulley and so far so good. I am still throwing a tad bit of oil out of the ISP OT pulley, so far every person I know running those have had the same issue. I did get one of those vintage speed oil filler given to me by a friend. I am on the fence about it, I am not sure it is the look I want , I wish it didnt have the holes drilled in the top piece.
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
Ted2 Samba Member
Posted: Wed Apr 24, 2019 3:27 pm Post subject: Re: ConcreteAce's '51 build |
Hi Ethan,
What exhaust are yourunning with this? |
Ted2 Samba Member
Posted: Wed Apr 24, 2019 5:05 pm Post subject: Re: ConcreteAce's '51 build |
Do you like it? |
