Frodge Samba Member
Posted: Wed May 09, 2018 9:06 pm Post subject: Re: So I went in to a parts store... |
Why not buy another oil bath cleaner? |
sb001 Samba Member
Posted: Wed May 09, 2018 9:11 pm Post subject: Re: So I went in to a parts store... |
Frodge wrote: |
OOHH, I didn't think about buying a brand new unsoiled oil bath air cleaner brand new from VW-- hang on a sec while I pull out the way back machine and set to mid-70s. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Frodge Samba Member
Posted: Wed May 09, 2018 9:18 pm Post subject: Re: So I went in to a parts store... |
I didn’t say brand new. I. Sure you could find one that works better than yours. |
sb001 Samba Member
Posted: Wed May 09, 2018 9:34 pm Post subject: Re: So I went in to a parts store... |
Frodge wrote: |
And just how many am I supposed to keep buying and try out before I get lucky? You think these 40 year old oil baths come with refunds??
"Hey chief, I'd like to buy your oil bath, but here's the deal - I'm going to stick it on my car and see if it wants to stall out- if it does, I'm gonna need to send it back for a full refund so I can try another one... and another.. and another. I mean, I COULD just avoid all this trouble by using a paper filter- but someone on the Samba told me to do this instead."
1600 SP engine
bluebus86 Banned
Posted: Wed May 09, 2018 9:42 pm Post subject: Re: So I went in to a parts store... |
many of the chain autostores are getting to be near worthless, unless you want floor mats, seat covers, or air fresheners. Try to buy 6 feet of steel fuel line and they cant help you. Speed shops are still pretty good for now at least.
wanted an oring for a jeep power steering pump pipe seal, only orings were a pack of chinese ones at autozone, no clue as to the material, buna, nitrile, viton, chewing gum, nothing to indicate the material at all on the package. even the jeep dealership did not have the part, its a practically new jeep and they dont stock parts for it, hell it was made in 1990 and they think it is some museum piece, damn it!
another thing, these days we are supposed to be so green and enviromental, but why can you not get wiper blade refills anymore at the parts store like before?, the rubber blade wears out and you have to buy the whole blade assembly, then you end up tossing perfectly good metal blade holders, or like me, stick them in a box, in the hope that one day the store will again carry wiper refills. I must have 20 of them, all perfectly good, awaiting a 50 cent refill blade, ugh!
Bug On, with an oil bath! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
sb001 Samba Member
Posted: Wed May 09, 2018 10:15 pm Post subject: Re: So I went in to a parts store... |
bluebus86 wrote: |
Bug On, with an oil bath! |
Since you missed the whole discussion:
Paper filter is better, as was stated earlier in this thread even VW switched to it later. More efficient and less complicated, and won't stall your car out because it can't be cleaned out anymore. Time for everyone to change. _________________ I'm the humblest guy on this board.
1600 SP engine
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Wed May 09, 2018 10:18 pm Post subject: Re: So I went in to a parts store... |
Xevin wrote: |
I remember walking into a well known ACVW shop for transaxle oil on the 72 bus. They recommended GL 5 oil instead of proper Hypoid gear oil. Said that’s all they use now. can’t tell you how many times I’ve gotten poor advice on parts. Are they trying to sabotage my project? |
GL-5 IS hypoid gear oil. _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Wed May 09, 2018 11:03 pm Post subject: Re: So I went in to a parts store... |
I put utility before appearance. Steve, if the round paper air cleaner works better for you, then that’s what I’d use if in your shoes. If you want preheat, however, you might consider a later model VW paper-element air filter. These air cleaners also have a fitting for your oil-filler blow-by hose.
And, since we’re talking parts stores, I went to Wolfgang International today and got a free epoxy-filled Bosch Blue coil. It came with the little electrical ears on the posts, as well as a new bracket. Too bad I don’t need it now, but someday I figure it’ll come in handy.
At their Show & Shine this year, I won a $100.00 gift certificate. The coil was about $60.00, so I got some other VW stuff I really didn’t need to fill out the hundred-dollar limit.
It’s nice to get new, free VW stuff. It’s even nicer to only drive a few minutes away to an actual vintage VW parts vendor .
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Thu May 10, 2018 3:06 am Post subject: Re: So I went in to a parts store... |
bluebus86 wrote: |
another thing, these days we are supposed to be so green and enviromental, but why can you not get wiper blade refills anymore at the parts store like before?, the rubber blade wears out and you have to buy the whole blade assembly, then you end up tossing perfectly good metal blade holders, or like me, stick them in a box, in the hope that one day the store will again carry wiper refills. I must have 20 of them, all perfectly good, awaiting a 50 cent refill blade, ugh! |
Just last month for my truck I bought a pack of two 18" wiper blade refills at local O'Reilly, I asked and they had a set behind the counter. And they also got transferred from another store for me a pack of two 19" wiper blade refills for my other truck.
See https://www.oreillyauto.com/search?q=wiper+blade+inserts But you might need to cut a pair smaller for your VW. And my 1971 VW Convertible takes a smaller size insert/refill than my 1970 sedan.
A rear window blade from another vehicle might fit a VW windshield. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Thu May 10, 2018 3:44 am Post subject: Re: So I went in to a parts store... |
Whilst many of you are guffawing at the nonsense of a cartridge air filter, I can confirm that (in Australia at least) the VW dealer that my father went to with our 68 Beetle removed the top of the air filter and replaced it with a paper cartridge type air filter during service. No asking the customer, it just got done.
This would have been perhaps very early in 1970-71. The picture of the air cleaner on a very dirty original engine shows the shape.
I HAVE tried to find an original oil bath top here with no success yet.
Zundfolge1432 Samba Member
Posted: Thu May 10, 2018 4:35 am Post subject: Re: So I went in to a parts store... |
Back on topic I went to Autozone once looking for fuel line. Counter man came back with a length of vacuum hose which as you know would fail rather quickly running gasoline through it. I mentioned this to the counter man and he became confused, in his mind all hoses are the same. Manager may have known better but didn’t seem to realize the liability issue of Jethro selling someone what could be a safety hazard with potentially fatal consequences.
The only parts store I trust is a family owned business in which the proprietor has years of experience, you can bank on what he says.
www.bughaus.com |
glutamodo The Android
Joined: July 13, 2004 Posts: 26323 Location: Douglas, WY
Posted: Thu May 10, 2018 4:37 am Post subject: Re: So I went in to a parts store... |
Man, hoses are totally tubular, dude! _________________ Andy T.
AlmostHeavenWV_VW Samba Member
Posted: Thu May 10, 2018 6:56 am Post subject: Re: So I went in to a parts store... |
I often find the best scenario is to just know what I need.
I'm often the more informed party when standing at the FLAPS parts counter. No matter where I've gone, but that's okay.
Considering all the convoluted things that new cars have and considering that simple cars (like our ACVWs) are long out of production and commonplace sights I couldn't reasonably expect the guy to know everything about every single car out there.
For example: I blew 2 workers and 2 manager's minds a few years ago when I told them that my Mazda was a Ford underneath. This came up because I swapped the Mazda cartridge oil filter mount for the Ford Spin-on filter mount.
It just boggled their minds that the 2.3L mazda and 2.3L Ford I4 was the exact same thing.
Then I showed them the "FoMoCo" stamp on my factory brake calipers. _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
Cusser Samba Member
Posted: Thu May 10, 2018 8:00 am Post subject: Re: So I went in to a parts store... |
wcfvw69 wrote: |
Cusser wrote: |
Installation of that radiator was straightforward - but I am "The Cuss" !!! |
"Dirty Harry" was a GREAT film. Clint directed the scene where the guy wants to jump and kill himself, the director Don Siegel was sick at that time. Clint learned efficiency and direction working as actor for Sergio Leone and Siegel, always comes in under budget and shoot time. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Thu May 10, 2018 12:03 pm Post subject: Re: So I went in to a parts store... |
AlmostHeavenWV_VW wrote: |
For example: I blew 2 workers and 2 manager's... |
Careful how you word those things. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Thu May 10, 2018 12:50 pm Post subject: Re: So I went in to a parts store... |
TDCTDI wrote: |
Careful how you word those things. |
Careful skipping important entire phrases of the message, could lead to wild misinterpretations _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Posted: Thu May 10, 2018 1:08 pm Post subject: Re: So I went in to a parts store... |
The lack of the apostrophe on "workers" did that all by itself. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Posted: Thu May 10, 2018 1:37 pm Post subject: Re: So I went in to a parts store... |
sb001 wrote: |
Frodge wrote: |
OOHH, I didn't think about buying a brand new unsoiled oil bath air cleaner brand new from VW-- hang on a sec while I pull out the way back machine and set to mid-70s. |
_________________ **1971 Super Project
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
Xevin Samba Member
Posted: Thu May 10, 2018 2:00 pm Post subject: Re: So I went in to a parts store... |
Keith wrote: |
Xevin wrote: |
GL-5 IS hypoid gear oil. |
You are correct sir, I was lazy in my comment. I should have elaborated that I asked for a Hypoid compatible gear oil for my bus. Parts guy didn’t understand the difference ( or what Hypoid gearing was) and recommended the GL 5 oil. This particular oil could not be verified it was Hypoid compatible on the bottle or the web. So l lost faith in what oil he had to sell. Autozone I understand but a ACVW Shop should know what I’m talking about. And yes people do run GL 5 in ACVWs. I drink the ratwell/Amskeptic coolaid Thanks for the correction Keith.
http://www.ratwell.com/technical/GearOil.html _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
bluebus86 Banned
Posted: Thu May 10, 2018 4:32 pm Post subject: Re: So I went in to a parts store... |
sb001 wrote: |
bluebus86 wrote: |
Paper filter is better, as was stated earlier in this thread even VW switched to it later. More efficient and less complicated, and won't stall your car out because it can't be cleaned out anymore. Time for everyone to change. |
My original oil bath still works fine, I dont believe putting a paper filter in there it any better . Oil baths work great. over 300,000 miles and still humming along. Golly its not as if a paper filter never can clog.
Bug On with an oil bath! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
