cdnltded Samba Member
Joined: March 13, 2015 Posts: 381 Location: Pincher Creek, Alberta
Posted: Thu Apr 19, 2018 6:21 am Post subject: Re: My project Doom Buggy |
It’s almost like the new Plum Crazy Purple.
Hopefully it looks ok in the sun. Like not being able to see the lines as this stuff cane from a cattle can. |
Firebuggy Samba Member
Joined: November 16, 2010 Posts: 122 Location: Black's Corners, Ontario Canada
Posted: Thu Apr 19, 2018 12:22 pm Post subject: Re: My project Doom Buggy |
I like it too. Gonna look great in the sun! |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Posted: Thu Apr 19, 2018 1:22 pm Post subject: Re: My project Doom Buggy |
if you really want flake, this is what I do.
base color
flake of whatever color and a flake cannon ( easy to build ) and a can of clear.
i used a princess auto cheap disposable gun on my last project with a quart of inexpensive sherwin williams 2 part clear from the local auto supply, way cheaper than buying rattle cans
spray clear wet a couple square feet, flake cannon the clear, move to the next dry spot. then once you're done you'll have to lay a couple coats of clear to bury the flake.
some video after laying the flake on the sidecar
https://www.instagram.com/p/BThndVyA8mI/?taken-by=mark_witwicki _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Posted: Thu Apr 19, 2018 3:34 pm Post subject: Re: My project Doom Buggy |
W1K1 wrote: |
base color
https://www.instagram.com/p/BThndVyA8mI/?taken-by=mark_witwicki |
great idea
but i am using a product caled protectdip, it like plastidip but cheaper, if i dont like i will peel off and paint with real auto paint |
oprn Samba Member
Joined: November 13, 2016 Posts: 12744 Location: Western Canada
Posted: Thu Apr 19, 2018 8:37 pm Post subject: Re: My project Doom Buggy |
Got my engine in but there is lots of wiring to sort out and an exhaust to build. The race is on to see who its the pavement first! |
Posted: Sat Apr 21, 2018 12:03 am Post subject: Re: My project Doom Buggy |
Paint is done.
I don’t think it’s gonna win any beauty contests. But I am ok with the results.
I really like the color and how the flake turned out
oprn Samba Member
Posted: Sat Apr 21, 2018 4:46 pm Post subject: Re: My project Doom Buggy |
I wonder if that clear coat will buff up a bit once it has cured well? It looks a wee bit flat ( well more like semi gloss), mind you the flat look is kind of "in" just now.
And once it's all dressed up it will look different too! |
Posted: Sat Apr 21, 2018 6:36 pm Post subject: Re: My project Doom Buggy |
No it won’t buff up. It’s a rubber type based removal paint. It’s shinnier now then it was. Can’t wait to get it back together and out in the natural light |
oprn Samba Member
Posted: Sat Apr 21, 2018 9:08 pm Post subject: Re: My project Doom Buggy |
It will be just fine! |
Posted: Mon Apr 23, 2018 4:50 pm Post subject: Re: My project Doom Buggy |
Ok i need some of the knowledgeable guys help
its almost time to mate the body back to the chassis for the last time. i have heard many talk about you need to seal the body to the chassis.
Is that true? or does it really matter?
and if true what is the best recommendation? |
slalombuggy Samba Member
Posted: Mon Apr 23, 2018 5:22 pm Post subject: Re: My project Doom Buggy |
Buy a roll of stock VW body gasket rubber. The stuff they used Beetles and Ghias. CIP1 carries it. Glue it to the pan with some Permatex Right Stuff urethane sealant, tape it down to hold it in place and let it set up, then bolt the body down. Don't glue the body down just put it on the bare rubber.
brad |
Posted: Tue Apr 24, 2018 11:47 am Post subject: Re: My project Doom Buggy |
One rear rim done. I like how it has turned out. Now I wait for the parts to show up. Then rims and tires will be out on as well as the body for good
Posted: Tue May 01, 2018 9:04 am Post subject: Re: My project Doom Buggy |
have to stay with a narrower tire in the rear, not much clearance.
got the new snubbers installed too
front tire mounted
and the "rollbar" is all ready too
Hot Air Samba Member
Joined: February 25, 2007 Posts: 664 Location: Baltimore, Maryland
Posted: Tue May 01, 2018 11:33 am Post subject: Re: My project Doom Buggy |
That is way to close on the rear rim. The tire is going to flex when taking corners and is going to rubbbbbbbbb. what is the offset on the rim ? _________________ 73' Bug
85' Porsche 911 Carrera 3.2 |
Posted: Tue May 01, 2018 5:24 pm Post subject: Re: My project Doom Buggy |
Hot Air wrote: |
That is way to close on the rear rim. The tire is going to flex when taking corners and is going to rubbbbbbbbb. what is the offset on the rim ? |
Not sure. Custom made I bought from a guy. I have some tires mounted on the rims. Gonna try them in a day or 2. Might have to get some spacers and longer nuts. 🤞🏻🤞🏻 |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Wed May 02, 2018 11:27 am Post subject: Re: My project Doom Buggy |
cdnltded wrote: |
Hot Air wrote: |
Swap the axles!
1967 axles/tubes will give ya about an inch and a half more room right where ya need it!
'68 axles/tubes can also be used if you get some spacers for the axle nuts.
Do it now before ya get everything assembled! _________________ Jesucristo es mi Señor y Salvador! |
Posted: Wed May 02, 2018 11:50 am Post subject: Re: My project Doom Buggy |
well i tried them, with the 275/60R15 on the wheels.
NO GO
so now i am gonna try some 255 and maybe some 245 if i can find a set of used
57BLITZ wrote: |
cdnltded wrote: |
Swap the axles!
Do it now before ya get everything assembled! |
if i changed the axle and tubes that requires removing them from the tranny correct. and 67 still has the wide 5 pattern correct |
Posted: Wed May 02, 2018 12:37 pm Post subject: Re: My project Doom Buggy |
cdnltded wrote: |
. . . if i changed the axle and tubes that requires removing them from the tranny correct. and 67 still has the wide 5 pattern correct |
YES and YES . . .
As I mentioned, 1968 axle/tubes can also be used with your "wide-five" drums if you buy a pair of these . . . http://www2.cip1.com/ProductDetails.asp?ProductCode=C13%2D22%2D5281%2D7
Remove the transaxle and it will take a couple hours to swap the axles . . . MUCH, much better than super long studs with super thick wheel spacers! _________________ Jesucristo es mi Señor y Salvador! |
Posted: Thu May 03, 2018 1:46 pm Post subject: Re: My project Doom Buggy |
57BLITZ wrote: |
YES and YES . . .
Remove the transaxle and it will take a couple hours to swap the axles . . . MUCH, much better than super long studs with super thick wheel spacers! |
so if i can find a set of 68 axles.
can changing the axles be done without removing the tranny? i know it would be easier out
second this spacer you mention it just goes between the nut and the drum allowing me to use all my existing backing plate and brake setup? |
Posted: Wed May 09, 2018 11:58 pm Post subject: Re: My project Doom Buggy |
Started reassembling tonight
The rear rims are just for moving the buggy around |
