So I went in to a parts store...
Frodge
Frodge is offline
PostPosted: Wed May 09, 2018 9:06 pm    Post subject: Re: So I went in to a parts store... Reply with quote
Why not buy another oil bath cleaner?
sb001
sb001 is offline
PostPosted: Wed May 09, 2018 9:11 pm    Post subject: Re: So I went in to a parts store... Reply with quote
OOHH, I didn't think about buying a brand new unsoiled oil bath air cleaner brand new from VW-- hang on a sec while I pull out the way back machine and set to mid-70s. Rolling Eyes
1969 autostick sedan, owned since new
1600 SP engine
Solex 30 PICT 3 carburetor
Bosch 113905205AE autostick distributor
Frodge
Frodge is offline
PostPosted: Wed May 09, 2018 9:18 pm    Post subject: Re: So I went in to a parts store... Reply with quote
I didnít say brand new. I. Sure you could find one that works better than yours.
sb001
sb001 is offline
PostPosted: Wed May 09, 2018 9:34 pm    Post subject: Re: So I went in to a parts store... Reply with quote
And just how many am I supposed to keep buying and try out before I get lucky? You think these 40 year old oil baths come with refunds??
"Hey chief, I'd like to buy your oil bath, but here's the deal - I'm going to stick it on my car and see if it wants to stall out- if it does, I'm gonna need to send it back for a full refund so I can try another one... and another.. and another. I mean, I COULD just avoid all this trouble by using a paper filter- but someone on the Samba told me to do this instead."
Rolling Eyes
1600 SP engine
bluebus86
bluebus86 is offline
PostPosted: Wed May 09, 2018 9:42 pm    Post subject: Re: So I went in to a parts store... Reply with quote
many of the chain autostores are getting to be near worthless, unless you want floor mats, seat covers, or air fresheners. Try to buy 6 feet of steel fuel line and they cant help you. Speed shops are still pretty good for now at least.
wanted an oring for a jeep power steering pump pipe seal, only orings were a pack of chinese ones at autozone, no clue as to the material, buna, nitrile, viton, chewing gum, nothing to indicate the material at all on the package. even the jeep dealership did not have the part, its a practically new jeep and they dont stock parts for it, hell it was made in 1990 and they think it is some museum piece, damn it!
another thing, these days we are supposed to be so green and enviromental, but why can you not get wiper blade refills anymore at the parts store like before?, the rubber blade wears out and you have to buy the whole blade assembly, then you end up tossing perfectly good metal blade holders, or like me, stick them in a box, in the hope that one day the store will again carry wiper refills. I must have 20 of them, all perfectly good, awaiting a 50 cent refill blade, ugh!
Bug On, with an oil bath!
sb001
sb001 is offline
PostPosted: Wed May 09, 2018 10:15 pm    Post subject: Re: So I went in to a parts store... Reply with quote
Since you missed the whole discussion:
Paper filter is better, as was stated earlier in this thread even VW switched to it later. More efficient and less complicated, and won't stall your car out because it can't be cleaned out anymore. Time for everyone to change.
1600 SP engine
Keith
Keith is offline
PostPosted: Wed May 09, 2018 10:18 pm    Post subject: Re: So I went in to a parts store... Reply with quote
Xevin wrote:
I remember walking into a well known ACVW shop for transaxle oil on the 72 bus. They recommended GL 5 oil instead of proper Hypoid gear oil. Said thatís all they use now. Shocked canít tell you how many times Iíve gotten poor advice on parts. Are they trying to sabotage my project?
GL-5 IS hypoid gear oil.
Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind
Tim Donahoe
Tim Donahoe is offline
PostPosted: Wed May 09, 2018 11:03 pm    Post subject: Re: So I went in to a parts store... Reply with quote
I put utility before appearance. Steve, if the round paper air cleaner works better for you, then thatís what Iíd use if in your shoes. If you want preheat, however, you might consider a later model VW paper-element air filter. These air cleaners also have a fitting for your oil-filler blow-by hose.
And, since weíre talking parts stores, I went to Wolfgang International today and got a free epoxy-filled Bosch Blue coil. It came with the little electrical ears on the posts, as well as a new bracket. Too bad I donít need it now, but someday I figure itíll come in handy.
At their Show & Shine this year, I won a $100.00 gift certificate. The coil was about $60.00, so I got some other VW stuff I really didnít need to fill out the hundred-dollar limit.
Itís nice to get new, free VW stuff. Itís even nicer to only drive a few minutes away to an actual vintage VW parts vendor Wink .
Tim
Let's do the Time Warp again!
Richard O'Brien
Cusser
Cusser is offline
PostPosted: Thu May 10, 2018 3:06 am    Post subject: Re: So I went in to a parts store... Reply with quote
Just last month for my truck I bought a pack of two 18" wiper blade refills at local O'Reilly, I asked and they had a set behind the counter. And they also got transferred from another store for me a pack of two 19" wiper blade refills for my other truck.
See https://www.oreillyauto.com/search?q=wiper+blade+inserts But you might need to cut a pair smaller for your VW. And my 1971 VW Convertible takes a smaller size insert/refill than my 1970 sedan.
A rear window blade from another vehicle might fit a VW windshield.
1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2005 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
viiking
viiking is offline
PostPosted: Thu May 10, 2018 3:44 am    Post subject: Re: So I went in to a parts store... Reply with quote
Whilst many of you are guffawing at the nonsense of a cartridge air filter, I can confirm that (in Australia at least) the VW dealer that my father went to with our 68 Beetle removed the top of the air filter and replaced it with a paper cartridge type air filter during service. No asking the customer, it just got done.
This would have been perhaps very early in 1970-71. The picture of the air cleaner on a very dirty original engine shows the shape.
I HAVE tried to find an original oil bath top here with no success yet.
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Thu May 10, 2018 4:35 am    Post subject: Re: So I went in to a parts store... Reply with quote
Back on topic I went to Autozone once looking for fuel line. Counter man came back with a length of vacuum hose which as you know would fail rather quickly running gasoline through it. I mentioned this to the counter man and he became confused, in his mind all hoses are the same. Manager may have known better but didnít seem to realize the liability issue of Jethro selling someone what could be a safety hazard with potentially fatal consequences.
The only parts store I trust is a family owned business in which the proprietor has years of experience, you can bank on what he says.
www.bughaus.com
What we think we become- Buddha
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Thu May 10, 2018 4:37 am    Post subject: Re: So I went in to a parts store... Reply with quote
Man, hoses are totally tubular, dude!
Andy T.
-Volunteer Post-Production Sound Editor for Starship Excelsior - A Star Trek Fan Production.
AlmostHeavenWV_VW
AlmostHeavenWV_VW is offline
PostPosted: Thu May 10, 2018 6:56 am    Post subject: Re: So I went in to a parts store... Reply with quote
I often find the best scenario is to just know what I need.
I'm often the more informed party when standing at the FLAPS parts counter. No matter where I've gone, but that's okay.
Considering all the convoluted things that new cars have and considering that simple cars (like our ACVWs) are long out of production and commonplace sights I couldn't reasonably expect the guy to know everything about every single car out there.
For example: I blew 2 workers and 2 manager's minds a few years ago when I told them that my Mazda was a Ford underneath. This came up because I swapped the Mazda cartridge oil filter mount for the Ford Spin-on filter mount.
It just boggled their minds that the 2.3L mazda and 2.3L Ford I4 was the exact same thing.
Then I showed them the "FoMoCo" stamp on my factory brake calipers.
1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor
Cusser
Cusser is offline
PostPosted: Thu May 10, 2018 8:00 am    Post subject: Re: So I went in to a parts store... Reply with quote
wcfvw69 wrote:
Cusser wrote:
Installation of that radiator was straightforward - but I am "The Cuss" !!!
Wink
"Dirty Harry" was a GREAT film. Clint directed the scene where the guy wants to jump and kill himself, the director Don Siegel was sick at that time. Clint learned efficiency and direction working as actor for Sergio Leone and Siegel, always comes in under budget and shoot time.
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Thu May 10, 2018 12:03 pm    Post subject: Re: So I went in to a parts store... Reply with quote
AlmostHeavenWV_VW wrote:
For example: I blew 2 workers and 2 manager's...
Careful how you word those things. Laughing
AlmostHeavenWV_VW
PostPosted: Thu May 10, 2018 12:50 pm    Post subject: Re: So I went in to a parts store... Reply with quote
Careful skipping important entire phrases of the message, could lead to wild misinterpretations Shocked
1600DP AK case
Solex 34PICT3 Carb
TDCTDI
TDCTDI is offline
PostPosted: Thu May 10, 2018 1:08 pm    Post subject: Re: So I went in to a parts store... Reply with quote
The lack of the apostrophe on "workers" did that all by itself. Laughing
joey1320
joey1320 is offline
PostPosted: Thu May 10, 2018 1:37 pm    Post subject: Re: So I went in to a parts store... Reply with quote
Laughing Laughing Laughing
**1971 Super Project
**My VW YouTube Channel - AirCooled-Tech
https://www.youtube.com/channel/UCcaFyFZRSq6BrR8_MO6va8Q
Xevin Premium Member
Xevin is offline
PostPosted: Thu May 10, 2018 2:00 pm    Post subject: Re: So I went in to a parts store... Reply with quote
Embarassed You are correct sir, I was lazy in my comment. I should have elaborated that I asked for a Hypoid compatible gear oil for my bus. Parts guy didnít understand the difference ( or what Hypoid gearing was) and recommended the GL 5 oil. This particular oil could not be verified it was Hypoid compatible on the bottle or the web. So l lost faith in what oil he had to sell. Autozone I understand but a ACVW Shop should know what Iím talking about. And yes people do run GL 5 in ACVWs. I drink the ratwell/Amskeptic coolaid Wink Thanks for the correction Keith.
http://www.ratwell.com/technical/GearOil.html
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
Abscate wrote:
I dont hate anyone on the Samba - except for Xevin - who brought me cold coffee in the morning.
[email protected] wrote:
bluebus86
PostPosted: Thu May 10, 2018 4:32 pm    Post subject: Re: So I went in to a parts store... Reply with quote
My original oil bath still works fine, I dont believe putting a paper filter in there it any better . Oil baths work great. over 300,000 miles and still humming along. Golly its not as if a paper filter never can clog.
Bug On with an oil bath!
Page 3 of 4
