?Waldo? Samba Member
Posted: Thu May 10, 2018 11:18 am Post subject: Vanagon Fuel Fill "BURP" - SOLVED! |
My '85 has had the all-too-common fuel fill-up puke. When filling up at full speed, just after the pump auto shut-off stops the pump, a bunch of gasoline would puke out of the filler. This issue occurs because the max fill rate of the fuel pumps has been increased since the van was made and the venting system can't keep up with the mild pressure build-up in the tank and so, after the pump shuts off, the pressure in the tank is enough to push some fuel back out. I've seen various recommendations on this forum to fill at a slow rate, hold the nozzle just right, etc... but I'm not really a fan of making the process of filling up the vehicle require special skills/knowledge. To that end, I did some looking online and found that splash-back is very common in the boating community (where boats are typically kept in service for more years than automobiles) and where fuel spilling is even more dangerous and detrimental to the environment than it is with land vehicles. Because of that, the boating community has developed various fixes for the issue in older boats. I settled on the Perko anti fuel spash back valve. http://www.perko.com/catalog/fuel_system_component...per_valve/
It is a one-way flapper valve that allows the fuel to flow into the tank, but as soon as the pump shuts off and fuel begins to flow back the other direction, the flapper valve shuts and stops the fuel from puking out the filler.
I got around to installing it in the filler tube last weekend. The Perko valve is designed to be installed in 1-1/2" ID marine fuel hose. Conveniently, there is a section of the vanagon filler that is a straight section that is 1-1/2" OD. I picked up a foot of 1-1/2" marine fuel hose, sliced out a section of the vanagon filler tube exactly the length of the flapper valve, cut a section of the marine fuel hose to the appropriate length, installed the flapper in the middle of it, installed the vanagon filler tube pieces on either side of the flapper valve, and installed three clamps to finish the assembly. The two outer clamps seal the marine hose to the vanagon pieces and the center clamp seals the hose to the flapper valve. Here's a pic with it installed.
I'm pleased to report that I filled up last night with the pump on full blast and when the auto shutoff clicked it off, no more puking of fuel.
Total cost was ~$30 shipped for the valve and the foot of marine fuel hose.
I call that a win.
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Thu May 10, 2018 11:23 am Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
Brilliant! _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
Zeitgeist 13 Samba Member
Posted: Thu May 10, 2018 11:46 am Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
That's really cool. My '89 has a check valve at the base of the fill tube, which I haven't seen on earlier models. I assume it serves a similar function. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Vanagon Nut Samba Member
Posted: Thu May 10, 2018 11:48 am Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
Thanks for sharing that.
Do you think Fill-up Puke (FUP) is more likely to happen on Vanagons with the smaller diameter fill pipe and nozzle hole flap?
My guess is that earlier Vanagons with the larger diameter fill pipe (up to 1984 ? mid '85 ?) and no "nozzle hole flap" may allow for some venting between the gas pump nozzle and fill pipe so less chance of FUP.
Neil.
edited for clarity _________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Thu May 10, 2018 11:52 am Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
This is awesome ! Thank you for this . Its such a headache filling up with having to hold the nozzle just right etc... this fix will be in my future |
Posted: Thu May 10, 2018 12:10 pm Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
Vanagon Nut wrote: |
Neil.
edited for clarity |
Yeah, I remember in an old Samba thread it was mentioned that early Vanagons did not have this problem and that it seems to only occur on smaller diameter fill pipes. VW added a ball valve (ping pong ball) to the bottom of the filler tube starting in '89 which solved the problem, but those filler tubes are fairly hard to find. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Joined: April 29, 2015 Posts: 704 Location: Berkeley Ca
Posted: Thu May 10, 2018 12:30 pm Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
Sweet thanks, great solution for us with this issue. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Thu May 10, 2018 1:10 pm Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
My 84 will certainly puke if I fill until the pump shuts off - can usually be avoided if I position the nozzle handle raised - i.e. get the nozzle end against the lower side of the fill tube.
This valve intrigues me, but I wonder if it helps with those ridiculous nozzles used in California that seemed designed to assure you spill fuel every time you use them on a Vanagon.
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
raoul mitgong Samba Member
Joined: July 05, 2009 Posts: 1338 Location: Denver, CO
Posted: Thu May 10, 2018 1:30 pm Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
So much simpler to just buy a Syncro.
-d _________________ 84 Westy with a 2.1 (Groover)
86 Tintop Syncro (Crow)
86 Tintop Syncro to Westy project (Tom Servo)
91 Westy (Only the top 12 inches of this van (a burn victim)) |
Posted: Thu May 10, 2018 1:50 pm Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
raoul mitgong wrote: |
-d |
I get lulled to sleep by the Syncro then end up with gas all over my shoes when I fill up the 2wd...That and forgetting where the filler is... _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Posted: Thu May 10, 2018 2:43 pm Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
-d |
Silliest thing I've seen posted all week. Thanks for that. |
Posted: Thu May 10, 2018 2:47 pm Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
Ahwahnee wrote: |
My '84 is exactly the same way.
Cool solution, Andrew! Thanks! _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
B.O.B.Wanders Samba Member
Joined: July 22, 2014 Posts: 351 Location: Atlanta, GA USA
Posted: Thu May 10, 2018 3:02 pm Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
Interesting solution! Good thinking.
On a semi-related note: when I replaced the gas tank lines and fittings on my 83.5 Westy, I ordered a new rubber filler neck while I was at it. When I removed the old one and compared, the old one had a sort of one-way valve built in. but the new one was wide open. Anyone else have this?
I had been having the classic fill-up leakage problem, not the puking issue, so I don't know if the filler neck valve was actually effective or not. A new filler tube grommet and crossover line did the trick for me. No more puddles or guessing how many gallons would fit.
New on the left; old on the right (from "inside")
Old filler neck from "outside"
I had been having the overfill problem, but the new crossover line must have done the trick. No more puddles or guessing how many gallons would fit. _________________ 83.5 WBX 2WD Assuan Brown Westy, B.O.B.
"It feels good to be lost in the right direction” - unknown |
metropoj Samba Member
Posted: Fri May 11, 2018 9:31 am Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
Damn, I thought this fuel puking thing was a standard feature on my 86 !
Thanks Andrew, this thread is bookmarked and added to the to do list ! _________________ John.
86 TiiCo powered Westy. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17154 Location: Retired South Florida
Posted: Fri May 11, 2018 9:52 am Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
When I worked for VW back in the day, there was a recall for the Rabbit and Scirocco filler necks. It involved removing the filler neck and pressing in a metal flapper valve in the far end of the filler neck. Got pretty fast at doing them. Same idea as above. Thanks for posting. _________________ ☮️ |
Slimvest Samba Member
Joined: March 20, 2014 Posts: 431 Location: Portland, OR
Posted: Fri May 11, 2018 1:51 pm Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
Pretty darn cool. What are the chances of the junction leaking over time? _________________ '87 GL w/ Reimo top |
Posted: Fri May 11, 2018 2:38 pm Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
Eternity is long... Considering that the filler tube seems no worse for wear after 33 years and the hose I used is marine fuel hose, I don't foresee any issues with it in the time before manually driven vehicles and/or internal combustion engines become illegal. |
RichBenn Samba Member
Joined: November 16, 2005 Posts: 703 Location: Lake Tahoe, NV
Posted: Fri May 11, 2018 9:48 pm Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
Christopher Schimke wrote: |
Ahwahnee wrote: |
Cool solution, Andrew! Thanks! |
'84', I think, came in "federal"(49 state?) and California emissions versions. One had the narrower neck; one the wider one. May explain why some older ones did not have the problem and some did.
In my own '84, I noticed the overflow problem was much worse before I fixed the fuel tank venting system (the second, and hopefully last time). Still not perfect, however. _________________ Rich |
uberaudi Samba Member
Joined: June 24, 2013 Posts: 503 Location: Hi-top Country
Great solution! My 84 pukes at every fill up if I don't listen for the change in pitch as the fuel nears the top. I'll add it to the list! |
