jason Samba Member
Posted: Thu Aug 31, 2017 5:49 pm Post subject: What gas cap to use on 59 |
What gas caps are you guys using? Tired of the gas smell in my garage. I tried the Stant 10623 but it seems to be too large and doesn't get a good seal. |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Pinetops Samba Member
Posted: Fri Sep 01, 2017 8:25 am Post subject: Re: What gas cap to use on 59 |
I had a stant that works but it's too wide and too tight for my liking. A new gasket in an original cap is probably your best bet, that's what I'm using now. I'm sure the WW would be a better fit than the stant.
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211201551
Bus depot has this German one at a good price:
http://www.busdepot.com/211201551 _________________ "A rolling bus gathers no rust." |
jason Samba Member
Posted: Fri Sep 01, 2017 10:18 am Post subject: Re: What gas cap to use on 59 |
Not in stock at WW. My stock cap has a new seal but it still stinks. Im assuming the bypass is leaking. I found that the oil fill cap is a perfect fit. Non bypass though. |
Posted: Fri Sep 01, 2017 11:14 am Post subject: Re: What gas cap to use on 59 |
Have you checked your fuel lines for leaks? _________________ "A rolling bus gathers no rust." |
jason Samba Member
Posted: Fri Sep 01, 2017 5:25 pm Post subject: Re: What gas cap to use on 59 |
$13 shipping. No leaks on fuel lines. I changed over to teflon lined stainless with AN ends. I was changing the lines every 6 months here in Ca. It would crack really quick. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14193 Location: Casa de Oro, California
otis_bartleh Samba Member
Joined: August 19, 2009 Posts: 1105 Location: Martinez, CA
Posted: Wed Sep 06, 2017 12:03 pm Post subject: Re: What gas cap to use on 59 |
SamboSamba22 wrote: |
That Bus Depot cap for $6 is looking pretty good, looks to be what I picked from WW for less...of course you don’t want to spend $6 and then same on shipping, might as well make a little list... |
The Bus Depot cap is now $10.95. They almost doubled their price on this in the past week?! _________________ -Adam
'59 Mango Bus
'69 Bug |
Posted: Wed Sep 06, 2017 2:16 pm Post subject: Re: What gas cap to use on 59 |
otis_bartleh wrote: |
The Bus Depot cap is now $10.95. They almost doubled their price on this in the past week?! |
Ron and his crew are pretty good folks, my guess on the price change was focus around availability and/or actual inventory cost being raised from said vendor.
For humor sake, sounds like you should've bought one last week _________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
Posted: Wed Sep 06, 2017 2:23 pm Post subject: Re: What gas cap to use on 59 |
Ron and his crew are pretty good folks, my guess on the price change was focus around availability and/or actual inventory cost being raised from said vendor. |
Probably... Hopefully!
Quote: |
For humor sake, sounds like you should've bought one last week |
No kidding! _________________ -Adam
'59 Mango Bus
'69 Bug |
jason Samba Member
Posted: Thu May 10, 2018 2:56 pm Post subject: Re: What gas cap to use on 59 |
I tried the stant and the f100 cap. The stant was loose side to side and the rubber rode on the ends. It fit terrible. The F100 depth made it unusable. I bought the oe brazilian one and that fits ok but still get gas smell. I thought maybe the neck is leaking but if I put the oil filler cap on the smell goes away. Any other caps to try? I measured the spout at 53 mm where the rubber rides. |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19670 Location: Land of Whine and Phonies
Posted: Thu May 10, 2018 3:37 pm Post subject: Re: What gas cap to use on 59 |
NAPA 703-1220 _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
BarryL Samba Member
Posted: Fri May 11, 2018 10:12 am Post subject: Re: What gas cap to use on 59 |
jason wrote: |
Can you post up photos of the caps you purchased?
Here are the three you mentioned off my vehicles. '66 Ford is left, Stant is right, OG VW is lowest.
This picture the '66 Ford is top left, VW is top right, Stant is bottom
All fit each other.
How does your neck opening look? This is my '65 bus'.
Are the ramps in good shape or thrashed? Is it an original tank?
Yes, the Stant and Ford tended to go off center a teeny bit but they still sealed.
All three caps allow fumes to escape so you will still smell gas. What density is the gas you're smelling?
I suspect the new iterations of gascaps have been made to different fitment standards.
I'm also sorry for your troubles...I hate leading someone down a wrong path if it was me. |
