CHenige Samba Member
Joined: January 06, 2016 Posts: 219 Location: Michigan
Posted: Mon May 14, 2018 6:50 pm Post subject: How the heck do you install this!!!! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76911 Location: Sneaking up behind you
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Mon May 14, 2018 6:59 pm Post subject: Re: How the heck do you install this!!!! |
Well first (if full vw pan) you pull access plate at front frame head, the open up access plate at rear torsion bar and disconnect shift rod coupler, then remove shifter, then slide shift rod out toward front till end pops free of old bushing.... Pop old busting out, pop new bushing in, and then slide shift rod back through new bushing all the way to shift rod coupler, reconnect, replace shifter, replace front cover at frame head....
veeweeman Samba Member
Joined: December 20, 2009 Posts: 940 Location: New Port Richey, FL
Posted: Mon May 14, 2018 8:17 pm Post subject: Re: How the heck do you install this!!!! |
Don't forget the snap ring that keeps the bushing snug against the shift rod. _________________ Never be a follower...Do your own thing, make it your own! |
Posted: Tue May 15, 2018 4:03 am Post subject: Re: How the heck do you install this!!!! |
Ok, maybe I see the issue. I have a sand rail and am trying to slip it over the ~1” rod and slide the bushing into the shifter box. I have tried using a strap clamp to hold it to the rod and then”shift” it into the hole but I just cannot get it to slip in. Does not help it is in between the seats.
Do I need to remove the shaft, insert the bushing and then put the shaft back in? And what snap ring? |
cbeck Samba Member
Posted: Tue May 15, 2018 5:28 am Post subject: Re: How the heck do you install this!!!! |
Can you post a pic of what you have? My box has a 1/8" thick ring around the shift rod hole that just needs a little lube. I have also seen shifter boxes that accept a bolt on composite? bushing. _________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
Posted: Tue May 15, 2018 5:45 am Post subject: Re: How the heck do you install this!!!! |
Yes you will need to remove the shift rod to install the new bushing. ..after the shift rod is back in place there is a small wire clip that is installed over the very end of the bushing, this clip will need to be installed on the new bushing before inserting the shift rod into the new bushing...the purpose of of the clip is to hold the rod snug against the bushing and eliminate shifter slop...usually you get a new clip with the new bushing. ..if your bug was missing the clip when you took it apart, 9.9 times out of ten grab a magnet wand and sweep the area below the shifter hole at the bottom of the tunnel. ..that is where they will usually be cuz previous owner did not know about the clip and it just drops into the tunnel as the shift rod is removed.
Bushing with clip ring installed
Also make sure you use white grease on the bushing and rod.
Helpful tips; before reinstalling the shift rod, it helps to remove any dirt, grime build up and rust from the shaft...steel wool, sos pad, or greed pad and wd-40 will clean the shift rod nice.
Once you get the rod started into the new bushing the best tool to use to push the rod through the bushing is a pair of small channel locks. ..you will also need to manipulate the shaft as you slide it back cuz it is not a straight line, rotating it 90-180 degrees will help clear obstacles in the tunnel.
Also, make sure that the slot in the bushing is facing up.
Have fun! _________________ Never be a follower...Do your own thing, make it your own! |
Posted: Tue May 15, 2018 7:17 am Post subject: Re: How the heck do you install this!!!! |
I need to get the clip and remove the rod.
Thanks. |
cbeck Samba Member
Posted: Tue May 15, 2018 7:44 am Post subject: Re: How the heck do you install this!!!! |
That box takes the bolt on nylon/composite bushing. Those are bolt holes for that style of aftermarket bushing on either side of the shift tube hole. _________________ My cut in half and rebuild thread
Posted: Tue May 15, 2018 1:49 pm Post subject: Re: How the heck do you install this!!!! |
Not so fast. Got home and looked at what I actually have. I think I am back to the old style production bushing? Or do I drill 2 holes for the other bushing?
I Ride Sand Samba Member
Posted: Tue May 15, 2018 3:48 pm Post subject: Re: How the heck do you install this!!!! |
i'd go with the other style bushing (i actually made one out of delrin), but the oem is the one that fits that box. _________________ Just a dirty coyote playing in the desert.
now where'd that dirty badger run off to? |
dustymojave Samba Member
Posted: Tue May 15, 2018 5:15 pm Post subject: Re: How the heck do you install this!!!! |
Yep. Use the stock plastic ring and spring ring. If you WANTED TO, you could drill holes and use one of the urethane block 2-bolt bushings. But that makes for more work.
When you install the new bushing, rotate it so the gap is facing down. That lets dirt and junk fall out, instead of holding it in. _________________ Richard
SoCalBajas Member
Posted: Tue May 15, 2018 6:11 pm Post subject: Re: How the heck do you install this!!!! |
Thanks guys. Drilling means removing seats. Not today!!! |
