Tourabout Samba Member
Joined: December 30, 2017 Posts: 46 Location: Tennessee
Posted: Mon May 07, 2018 2:37 am Post subject: Generator |
Do they make a genernator for the Ovals?
This is where they put an alternator inside an original generator housing.
I didn't know if it was possible to put an alternator in a generator so small. |
billb Samba Member
Joined: October 23, 2005 Posts: 369 Location: Austin, Texas
Posted: Mon May 07, 2018 9:26 am Post subject: Re: Generator |
The new alternators will not fit in the older 36 HP generator stand. If you want a 12 volt generator there is a Porsche one that fits but they are much more expensive. |
mkbug Samba Member
Joined: October 12, 2004 Posts: 145 Location: Northern California
Ovally Samba Member
Posted: Mon May 07, 2018 9:43 pm Post subject: Re: Generator |
The Gener-Nator looks and mounts the same as the original generator because it is the original generator but converted internally to an alternator.
You can ask here :
https://www.gener-nator.com/
Regards. |
lucille66 Samba Member
Joined: June 29, 2008 Posts: 633 Location: ORANGE COUNTY
Posted: Tue May 08, 2018 1:39 pm Post subject: Re: Generator |
You need the 90mm small case generator 12v Porsche. it came on 914 models. as previously said, these are extremely expensive. Or, have yours converted to 12 volts. There is an old Bosch technician in Los Angeles where I picked mine up from. He is old school, very knowledgeable. Ill see if I can find his # for you. He made my 12 volt generator for me that fits the 36hp stand. _________________ my first bug 66' build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=438348&highlight=lucille66 |
vdubmyk Samba Member
Joined: October 24, 2008 Posts: 508 Location: Corona, CA
Posted: Wed May 16, 2018 1:55 pm Post subject: Re: Generator |
This is my 90mm 12v converted generator, I got it off of EBay from BNR parts, I believe they are in Van Nuys.
_________________ 64 stock bug, 12V (converted 6v unit), 40 hp, all documents even sales contract and dealer window sticker! |
rlmartinez Samba Member
Joined: December 09, 2005 Posts: 233 Location: Whittier, CA
Posted: Wed May 16, 2018 4:16 pm Post subject: Re: Generator |
Ovally wrote: |
You can ask here :
Regards. |
Has anyone tried this application? _________________ 54 Bug
56 convertible |
Posted: Thu May 17, 2018 9:02 am Post subject: Re: Generator |
vdubmyk wrote: |
Is this the same 90mm (small case) measurement for the 36hp generator stand that's integrated into the case? _________________ my first bug 66' build:
Posted: Sun Jun 03, 2018 2:27 pm Post subject: Re: Generator |
Ovally wrote: |
You can ask here :
Regards. |
Actually I watched an episode of Jay Leno and a guy who had a 1955 bug . Jay said Don Allen could take your generator and install an alternator inside of it. He calls it a gener-nator. I contacted Don Allen and he said the VW generators are too small to install the parts to turn them into an alternator.
He said he can rebuild the generator and convert the original voltage regulator to electronic. It will put out 60 A @ 6 volts.
I don't want to convert to 12 V, I want to keep mine at 6 V.
Has anyone tried an electronic voltage regulator ? |
