Door Seal Glue? Contact Cement vs. RTV?
uglymug
uglymug is offline
PostPosted: Wed May 16, 2018 6:56 am    Post subject: Door Seal Glue? Contact Cement vs. RTV? Reply with quote
PO looks like he used contact cement on the door seals when they were installed. They came off easy-ish enough when I wanted to respray the doors (and fix the rusty bits on the bottoms.)
Now that I'm ready to reinstall, i cleaned up the old seals with some fine sandpaper and some thinner, and would like to glue them back.
Quick question: Contact cement again? OR RTV Glue? I plan on silicone spraying them once i install them so not to mess up mating surfaces.
Thanks!
"Think about this; think about how stupid the average person is, and then realize that half of 'em are stupider than that." - George Carlin
74 Thing
74 Thing is offline
PostPosted: Wed May 16, 2018 2:11 pm    Post subject: Re: Door Seal Glue? Contact Cement vs. RTV? Reply with quote
3M Weatherstrip adhesive-it comes in black or yellow and you can find it online or at your local parts store.
Here is how to properly apply it:
https://www.youtube.com/watch?v=qDBojIza-TA
andk5591 Premium Member
andk5591 is offline
PostPosted: Wed May 16, 2018 5:12 pm    Post subject: Re: Door Seal Glue? Contact Cement vs. RTV? Reply with quote
X2 - amazing stuff
D-Dubya Manx clone - 63 Short pan,1914.
Max - 73 standard Beetle hearse project
There's more, but not keeping them...
uglymug
uglymug is offline
PostPosted: Wed May 16, 2018 5:46 pm    Post subject: Re: Door Seal Glue? Contact Cement vs. RTV? Reply with quote
Hey, this is fantastic! Great tip with the YouTube video, which in case the link gets broken describes applying a thin bead to both mating surfaces, then using a popsicle stick to smear the surfaces. Less is more. When they start getting tacky (a minute or two) apply another thin bead to the rubber side, smearing it again, then immediately adhere the rubber to the substrate (door, in my case.) Like contact cement. I didn't see this at my Napa, so I'll order it from Amazon.
Appreciate the fast response!
