fastback 71 brakes
ronbug73
ronbug73 is offline
PostPosted: Sun May 13, 2018 11:36 am    Post subject: fastback 71 brakes Reply with quote
HI I finished washing my fasty and one wheel brakes dont move the drum is not moving. Shocked
what to do?
Mike Fisher
Mike Fisher is offline
PostPosted: Sun May 13, 2018 1:22 pm    Post subject: Re: fastback 71 brakes Reply with quote
My rear drums get rusted to brake shoes, when it sits in the wet winter. I have to rock it back and forth to get them freed up.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
KTPhil Premium Member
KTPhil is offline
PostPosted: Sun May 13, 2018 1:43 pm    Post subject: Re: fastback 71 brakes Reply with quote
Lots of threads on this:
https://www.thesamba.com/vw/forum/search.php?searc..._chars=200
This is common after car wash or rain, and then engaging the emergency brake. The shoes rust to the drum. It can take a surprising amount of force to free them! In the future, leave it in gear, maybe block the wheels, but don't put the parking brake on.
Banging on the drum at the right point, and brute-force popping it in gear, are two common approaches. Rather than repeat them all here, I suggest you scan through these and choose the best method for your particular cause and situation.
ronbug73
ronbug73 is offline
PostPosted: Mon May 14, 2018 1:33 pm    Post subject: Re: fastback 71 brakes Reply with quote
thank you
Ron
Multi69s
Multi69s is offline
PostPosted: Mon May 14, 2018 4:39 pm    Post subject: Re: fastback 71 brakes Reply with quote
The ironic part is that my two Type 1s have NEVER done this, but my square does.
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
ronbug73
ronbug73 is offline
PostPosted: Thu May 17, 2018 1:17 pm    Post subject: Re: fastback 71 brakes Reply with quote
ok
after some back and foreword the drum started to move
i decided to renew the rear brakes the shoes where very thin
thank you
Ron
Max Welton
Max Welton is offline
PostPosted: Thu May 17, 2018 3:45 pm    Post subject: Re: fastback 71 brakes Reply with quote
After getting things wet, drive around enough to heat the brakes up a bit so everything dries off.
You know ... next time. Smile
Max
1967 Type-3 Fastback
