varagon Samba Member
Joined: November 03, 2013 Posts: 116 Location: SE Kansas
Posted: Sun Mar 02, 2014 3:22 am Post subject: Speakers in the Front Kickpanels |
I'm seeing a lot of Ghias with speakers in the front kick panels, like in this one:
Are these custom or can you get them somewhere, or are they cut right into the body of the car? _________________ 1973 Karmann Ghia Convertible |
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Kmolenda Samba Member
Joined: June 18, 2013 Posts: 309 Location: Cottage Grove Mn
Posted: Sun Mar 02, 2014 6:54 am Post subject: |
I've always made them, you can put whatever size you want into them. I personally make them out of wooden sticks, make a ring for the speaker to mount to, then use speaker grill fabric (I can't remember the name of it) but it's real stretchy, then staple it to the contours I want, and use some fiberglass resin to give them stiffness, and cover them in vinyl or whatever. The look great, and if done correctly give off some really good acoustics. |
88 E5PR1T Samba Member
Joined: December 31, 2012 Posts: 123 Location: Long Island, NY
Posted: Sun Mar 02, 2014 8:12 am Post subject: |
Yup, I got mine from JBUGS and then ordered an extra yard of carpet with my kit to cover them:
_________________ Rob
'64 Karmann Ghia "40HP VW"
instagram.com/40hpVW |
Greezy Joe Samba Member
Joined: April 12, 2010 Posts: 1534 Location: Crawfordville, Fl
Posted: Tue Mar 04, 2014 7:41 am Post subject: |
I think I got mine from KGPR
_________________ Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
12 Jeep Wrangler
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
" Duct tape can't fix stupid, but it'll muffle the sound". |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Tue Mar 04, 2014 10:27 am Post subject: |
I have used the ones from Glass Action on several cars. They work great and seem to have the best price - maybe because they actually make them:
http://www.glass-action.com/index.php?option=com_h...Itemid=240
The only thing to watch out for are the flimsy ABS plastic ones sold by some vendors. The speaker can make them vibrate. _________________ Ghia Owner Emeritus |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Tue May 30, 2017 3:43 pm Post subject: |
I bought a set of these and when I sit them against the door hinge pillar where the original kick panels went I end up with a large gap at the top on the inside edge of the panel. Do you have a photo of how you modified them to make them fit properly? _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
swavananda Samba Member
Joined: February 14, 2009 Posts: 889 Location: Can o' Scruz
Posted: Wed May 31, 2017 11:21 am Post subject: |
Mellow Yellow 74 wrote: |
I bought a set of these and when I sit them against the door hinge pillar where the original kick panels went I end up with a large gap at the top on the inside edge of the panel. Do you have a photo of how you modified them to make them fit properly? |
I think there are different makers of these panels . I can't remember where i got mine from, but the fit wasn't great. I could not get the carpet (TMI) to go around them without the carpet bulging in awkward ways. So i ended up covering them in matching seat upholstery . |
slalombuggy Samba Member
Posted: Wed May 31, 2017 11:49 am Post subject: Re: Speakers in the Front Kickpanels |
varagon wrote: |
Are these custom or can you get them somewhere, or are they cut right into the body of the car? |
That panel is also your inner fenderwell. cutting a hole for the speaker there will also let your front tires share the tunes.
brad |
crocteau Samba Member
Joined: March 31, 2005 Posts: 1203 Location: Philaburbia
Posted: Thu Jun 01, 2017 4:59 am Post subject: |
Agree; that sums it up. |
Joined: June 05, 2013 Posts: 4 Location: Northridge, Ca
Posted: Fri Apr 27, 2018 11:17 am Post subject: Speaker Panels |
Kmolenda wrote: |
DO YOU HAVE ANY PICS ON HOW YOU MADE YOUR PANELS? I CAN'T SEEM TO FIND ANYONE THAT SELLS THEM NOW AND I HAVE A CONV 72 GHIA. THANKS |
Hokie87 Samba Member
Joined: May 27, 2010 Posts: 280 Location: Richmond, VA
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32433 Location: Reading Pennsylvania
Figment Samba Member
Joined: October 27, 2016 Posts: 218 Location: Connecticut, USA
Posted: Wed May 16, 2018 7:09 am Post subject: Re: Speakers in the Front Kickpanels |
Does anyone have a suggestion for a speaker that's well suited to this location? (where you just KNOW it's going to get kicked at some point) _________________ '71 Ghia coupe |
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Wed May 16, 2018 8:19 am Post subject: Re: Speakers in the Front Kickpanels |
Figment wrote: |
Does anyone have a suggestion for a speaker that's well suited to this location? (where you just KNOW it's going to get kicked at some point) |
Something from THIS Manufacturer would be appropriate for the task at hand? |
Posted: Wed May 16, 2018 9:01 am Post subject: Re: Speakers in the Front Kickpanels |
Figment wrote: |
With the Glass-Action speaker panels I found it was a matter of mounting the speakers as high as possible while still having enough back space for the magnets. The Infinity 6000CS speakers I have mount on the outer surface of the panels so they stick out a bit, but I haven't had any short-legged passengers so kicking the speakers hasn't been an issue. YMMV |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3804 Location: Georgia
Posted: Wed May 16, 2018 2:20 pm Post subject: Re: Speakers in the Front Kickpanels |
I put mine in the door panels.
Keeps people’s feet off of them. |
JayFab Samba Member
Joined: April 29, 2012 Posts: 31 Location: Franklin, TN
Posted: Sat May 19, 2018 7:48 am Post subject: Re: Speakers in the Front Kickpanels |
Here’s how I did mine...
Made a cardboard mock-up, to test fit the speaker.
The magnet needs to miss the defrost tubes. The kick panel is a wainscoting panel from Lowe’s. _________________ Jay’s 1970 Coupe Resto
https://www.thesamba.com/vw/forum/viewtopic.php?t=509874&highlight= |
NoDents Samba Member
Posted: Wed Jun 13, 2018 8:06 pm Post subject: Re: Speakers in the Front Kickpanels |
Question for you VERT guys....
What kind of Wattage output do you suggest for your audio device so you can hear it while on the freeway? I assume an additional AMP is in order. _________________ No Dents
1963 Bug - Sold in 1980
1966 Karmann Ghia Convertible - Stolen in 1988
1971 Karmann Ghia Convertible, resto/mod COMPLETED 10/2020 |
Posted: Thu Jun 14, 2018 7:19 am Post subject: Re: Speakers in the Front Kickpanels |
NoDents wrote: |
What kind of Wattage output do you suggest for your audio device so you can hear it while on the freeway? |
If you're planning to cruise the freeways at 70mph with the top down I think you'll want at least a 4x100W amp plus a 400W amp for a sub if you're into bass (unless you go for the in-seat direct-to-spine system mentioned by BlueDot awhile back). Honestly, as much as I enjoy listening to my tunes, any time the top is down I find it's not so much about the hearing as it is the feeling... you know: the birds, sun, wind, road, dual Webers, exhaust |
