guzzirider Samba Member
Joined: May 01, 2005 Posts: 107 Location: Durango CO at last
Posted: Fri May 18, 2018 3:24 pm Post subject: fixing Bay gauge panel glass |
The glass faces were loose on my gauge cluster. So I took the gauge cluster apart. I appears the glass was originally held in by a metal ring that appeared to rotate and engage a bunch of little plastic bits.
Well all the plastic bits are long gone and rattling around.
Obviously I am not the only one with this issue
I thought I would get some RTV or Silicon and adhere the glass to the plastic panel and then do the same with the metal ring. Do I even need the metal ring
no sense reinventing the wheel again
Thanks _________________ 69 doublecab with 2" lift
Suzuki DR650
2016 Dodge Crew 1500 4x4 |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2541 Location: Ocean Beach in Beautiful BLUE California
Posted: Fri May 18, 2018 4:15 pm Post subject: Re: fixing Bay gauge panel glass |
Those little metal fingers were gone on mine also. I used a few (6-7?) tiny drops of super glue applied with a toothpick carefully around the edge to hold the glass in. Keep the glue away from the inside edge or it will smear and show. (Ask me how I know that.....) _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri May 18, 2018 4:53 pm Post subject: Re: fixing Bay gauge panel glass |
And next time the gas gauge or speedo acts funny don't go tapping the glass to try and smarten it up _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri May 18, 2018 5:11 pm Post subject: Re: fixing Bay gauge panel glass |
SO OB Bus
did you reinstall the metal rings by gluing those to the other side of the glass?
I am thinking they are no longer of any use
Thank you _________________ 69 doublecab with 2" lift
Suzuki DR650
OB Bus Samba Member
Posted: Fri May 18, 2018 7:04 pm Post subject: Re: fixing Bay gauge panel glass |
guzzirider wrote: |
SO OB Bus
Thank you |
This was a few years ago, so..... as best I remember, I did not use the rings. It was a few years ago; my memory is not so good so more. _________________ Larry in OB
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Fri May 18, 2018 7:11 pm Post subject: Re: fixing Bay gauge panel glass |
The rings retain the glass inside the plastic fingers so once the fingers break they serve no purpose. I use a 2 part epoxy in place of the fingers. Just a dab maybe every 30 degrees. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12727 Location: on a bike ride somewhere
Posted: Sat May 19, 2018 3:53 am Post subject: Re: fixing Bay gauge panel glass |
My gas cluster glass clips were broken too, so I made little clips out of thin sheet metal. Holding strong years later:
_________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
SGKent Samba Member
Posted: Sat May 19, 2018 11:28 am Post subject: Re: fixing Bay gauge panel glass |
dashes are also inexpensive coming from classifieds. There are lots of them. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat May 19, 2018 7:49 pm Post subject: Re: fixing Bay gauge panel glass |
So fixed the glass by this method see how it holds up: a) clear gorilla glued glass to plastic dash panel, b) Clear gorilla glued metal rings to glass. c) epoxied the metal rings to plastic panel at places it should have originally had contact
before I button it back up should I lubricate the speedometer
Thanks
Suzuki DR650
Posted: Sat May 19, 2018 8:00 pm Post subject: Re: fixing Bay gauge panel glass |
That’s a good idea but don’t overdo it and use the right lube. This might take some research. The wrong lube could be worse than not doing it at all _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
