iamdonquixote Samba Member
Joined: January 28, 2003 Posts: 2041 Location: M*ssholia
Posted: Sun May 20, 2018 7:18 am Post subject: shift: can't find 3 & 4th (unknown transmission) |
I'm putting back together a bus that I know nothing about its transmission. I installed the transmission and can't find 3rd & 4th. I removed the gear shift and went underneath and couldn't seem to get it in 3/4 there either. Its built the same day as my other 67' and I could put it in to 3/4 from underneath. All grub screws on the couplers are tight.
I tried to shift it from the nose code with shift rod disconnected to no avail, its __seemed__ like I could only get 1/2 and reverse.
I can remove the tranny if needed, is there a way to check shifting with the tranny out ? And, how can I remove the noise cone and check shifting? |
oldeskooloval Samba Member
Posted: Sun May 20, 2018 10:44 am Post subject: Re: shift: can't find 3 & 4th (unknown transmission) |
This happened to me. It was a broken nosecone. _________________ so fresh and so clean |
Posted: Sun May 20, 2018 5:23 pm Post subject: Re: shift: can't find 3 & 4th (unknown transmission) |
oldeskooloval wrote: |
This happened to me. It was a broken nosecone. |
Thanks for tbe reply, how was it broken? |
Posted: Tue May 29, 2018 6:32 pm Post subject: Re: shift: can't find 3 & 4th (unknown transmission) |
Which of these selectors is third/forth ?
Busted-bolt Samba Member
Joined: April 14, 2018 Posts: 514 Location: minnesoota
Posted: Tue May 29, 2018 6:43 pm Post subject: Re: shift: can't find 3 & 4th (unknown transmission) |
Gosh I hope that is not the transmission you intend to use in you're bus! It has a lot of corrosion issues. To answer you're question Im pretty sure its the top shifter rod that operates the 3/4 fork. _________________ Vw collection 60 combi ,61 panel ,62 deluxe micro,82 diesel Westfalia,88 Vanagon synchro,98 Jetta tdi,11 Jetta tdi mt ,11 Jetta tdi dsg.
I do all my own work,body,engine and transmission. |
Posted: Wed May 30, 2018 3:52 am Post subject: Re: shift: can't find 3 & 4th (unknown transmission) |
Busted-bolt wrote: |
Gosh I hope that is not the transmission you intend to use in you're bus! It has a lot of corrosion issues. To answer you're question Im pretty sure its the top shifter rod that operates the 3/4 fork. |
It was . I cant move the top selectir which is consistent with my 3/4 shifting issues. |
Posted: Wed Jun 06, 2018 3:18 pm Post subject: Re: shift: can't find 3 & 4th (unknown transmission) |
I did a search but inconclusive:
selector for 3/4 doesn't move, are there some simple things to do to try and address this? |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14255 Location: Casa de Oro, California
Posted: Wed Jun 06, 2018 6:48 pm Post subject: Re: shift: can't find 3 & 4th (unknown transmission) |
Does it jiggle at all in a rotational manner or fore-and-aft or is it rock solid frozen? |
Posted: Wed Jun 06, 2018 7:02 pm Post subject: Re: shift: can't find 3 & 4th (unknown transmission) |
BarryL wrote: |
I learned a lot from reading your other transmission posts : thanks.
its pretty stuck, no rotation |
Joined: January 01, 2007 Posts: 16855 Location: sticksville, ct.
Posted: Wed Jun 06, 2018 7:35 pm Post subject: Re: shift: can't find 3 & 4th (unknown transmission) |
dude...that thing is 100% junk....I can see the pits on the main bearing from here.
holy crap, did that come out of the boston harbor _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Wed Jun 06, 2018 7:51 pm Post subject: Re: shift: can't find 3 & 4th (unknown transmission) |
The outside of the transmission is cleaner than the inside... _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Posted: Thu Jun 07, 2018 8:25 am Post subject: Re: shift: can't find 3 & 4th (unknown transmission) |
skills@eurocarsplus wrote: |
holy crap, did that come out of the boston harbor |
Joey wrote: |
The outside of the transmission is cleaner than the inside... |
yeah, I neglected to take off the nose cone and take a look before cleaning the outside and installing it . It was removed from the bus and left inside the bus, but all the windows of the bus were removed. I still can't figure out how it got so rusty inside.
I'm in process of getting another trans, but in the meantime, I'm still wondering what causes the selector to sieze. |
Posted: Thu Jun 07, 2018 9:07 am Post subject: Re: shift: can't find 3 & 4th (unknown transmission) |
iamdonquixote wrote: |
it's a pretty precise bore. best guess is there is rust on the shaft where it passes into it's bore, or there is so much garbage in the transmission the bore corroded and locked the shaft tight.
either way, no easy solution. in a perfect world you would have a bit of fore/aft play and some rotational movement before it would move the fork. the shaft doesn't rotate, but slides in/out but there is a bit of rotational play for lack of a better term _________________
Jake Raby wrote: |
Brian wrote: |
60vwnewengland Twin #2
Joined: June 25, 2003 Posts: 1784 Location: District of Columbia & Cape Cod
Posted: Thu Jun 07, 2018 7:25 pm Post subject: Re: shift: can't find 3 & 4th (unknown transmission) |
in a perfect world you would have a bit of fore/aft play and some rotational movement ... the shaft doesn't rotate, but slides in/out but there is a bit of rotational play for lack of a better term |
this thread is should be rated "R" for sexual language and content. _________________ 77 Westy - Cape Cod Sage
LLAP |
