jtchristopher Samba Member
Joined: July 07, 2011 Posts: 55 Location: Ortonville, MI
Posted: Fri May 04, 2018 9:23 am Post subject: Sink Water Pump |
Hi All -
Interesting dilemma.... A couple of days ago I used the potable water system as part of my annual sanitizing of the system and water flowed to each faucet.
I drained the system and flushed with clean water after about 24 hours of letting things sit. Now when I turn on the pump, I hear it run but have no water pressure -- nothing shoots out of the faucets....
Does the system need to prime...I'm a bit confounded and hope someone may have an insight.
Thanks! _________________ 1975 Campmobile; Brilliant Orange (Celeste)
1986 Vanagon Camper; (Clark)
1995 Eurovan Camper; White (Edgar) |
tds3pete Samba Member
Joined: April 04, 2004 Posts: 914 Location: Seattle, WA
Posted: Sun May 20, 2018 4:54 pm Post subject: Re: Sink Water Pump |
When you first use it after draining the tank, turn it on then go back and open the rear sprayer for a second. This it what it take to prime mine. _________________ '58 Westy camper-come and gone
'73 Westy-bought new in Holland,now gone
'86 Syncro weekender-come and gone
'79 Westy...Oscar
'95 Eurovan Camper/5 spd...Marsha Mellow |
Posted: Mon May 21, 2018 7:28 am Post subject: Re: Sink Water Pump |
Thanks -- followed the suggestion and voila...works well. Thanks again! _________________ 1975 Campmobile; Brilliant Orange (Celeste)
CdeSimas Samba Member
Joined: September 03, 2018 Posts: 2 Location: Gig Harbor
Posted: Mon Sep 03, 2018 2:40 pm Post subject: Re: Sink Water Pump |
My sink/sprayer pump stopped working altogether after working fine. Could this be as simple as a bad pump or are there other symptoms I should be looking for? I remember reading something about an in-line fuse but have not been able to locate it. New to me 1999 EVC. Thx! _________________ ‘74 Super Beetle - Little Buffalo - Gone
‘73 Bus - Mookie - RIP
‘66 Split Bus - The Beast - Gone
‘99 Eurovan Camper - Albi |
Posted: Mon Sep 03, 2018 6:46 pm Post subject: Re: Sink Water Pump |
Well, I'm a tinkerer and have not had this happen. But I will look into the fuse thing sometime tomorrow to check if I can find one and report back. I believe my pump is in a niche not easily accessed - I'll look at this as well.... Perhaps there might be a way to get power or a volt-ohm to the connections to test for proper function.
Stay tuned. _________________ 1975 Campmobile; Brilliant Orange (Celeste)
Posted: Tue Sep 04, 2018 11:17 am Post subject: Re: Sink Water Pump |
Thanks for the reply! Yes, on the ‘95 I think the pump is under the left rear bed panel. The drain valve can be accessed through the furnace return vent I believe. I did get a multimeter on mine and, if I’m using it correctly, I get 13 volts when it’s connected to the van’s wiring but I get no ohms when it’s disconnected. My assumption is the pump has died but that is really just a guess based on my laymen’s analysis. I still have not located a fuse if there is one. _________________ ‘74 Super Beetle - Little Buffalo - Gone
Posted: Sun Sep 09, 2018 1:06 pm Post subject: Re: Sink Water Pump |
I found the pump just fine but haven't been able to track down the wiring to the power source. Can't find a fuse either. _________________ 1975 Campmobile; Brilliant Orange (Celeste)
relwok Samba Member
Joined: May 07, 2013 Posts: 1 Location: United States
Posted: Sun Sep 30, 2018 11:55 am Post subject: Re: Sink Water Pump |
This is a very interesting post. Same issue. Just all of a sudden seemed to stop working? I can't find an inline fuse. I read the ShurFlo spec sheet and it states the pumps resets itself after it is overloaded. All fuses in back end look fine. Pump looks fine. Have not put a multimeter to it yet. Seems very odd. |
Euroski Samba Member
Posted: Sun Sep 30, 2018 5:58 pm Post subject: Re: Sink Water Pump |
My pump is out too, but on my '99. Not sure yet what I'm going to do. Also my inverter seems to be out as well. |
rbarbera Samba Member
Joined: April 13, 2014 Posts: 2 Location: Colorado Springs
Posted: Tue Apr 26, 2022 4:17 pm Post subject: Re: Sink Water Pump |
I’m simply trying to locate the fresh water tank on a 99 EuroVan. I don’t have Bentley’s but have scoured the internet looking for any documentation that gives the location of the water tanks to no avail. Does anyone have a EuroVan and can shed some light? |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2796 Location: North Carolina
Posted: Wed Apr 27, 2022 7:15 am Post subject: Re: Sink Water Pump |
rbarbera wrote: |
If you have a Eurovan camper model (with the kitchen, fridge, etc) the house water tank is beneath the rear closet. You have to remove the driver side plastic shell beneath the bed, then the furnace duct work, then a plywood piece to access it.
The gray water tank is located beneath the van on the driver's side. The wastegate is behind the propane tank.
If you don't have a camper model, no water tank(s). _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
Posted: Mon May 02, 2022 8:39 am Post subject: Re: Sink Water Pump |
Thank you! I also found a Winnebago service training manual on eBay with schematics l, etc. I think I’ll be ok. Again, thanks! |
Shovel Knight Samba Member
Posted: Fri Aug 11, 2023 1:12 pm Post subject: Re: Sink Water Pump |
Here to revive this topic! I have a 1993 Eurovan. No rear sprayer that some of you seem to be referring to. Water tank is on the rear passenger side.
Fill it up, I can hear the pump running when I turn on the faucet, put nothing coming out. Can’t even hear water gurgling in the line.
Anyone else have this issue?
Thanks! |
TalonDriver Samba Member
Posted: Wed Aug 16, 2023 3:36 pm Post subject: Re: Sink Water Pump |
Hi Guys, newbie here, just got my Canadian '92
My sink water pump is on the passenger side in the far back. The fuse (between the sink and the driver's seat, near the floor) was fried, replaced fuse, it fried immediately. Removed the pump by unscrewing the large plastic lid on the top of the water tank. Ordered a new pump off of amazon. My brother screwed around with the old one, overcame some resistance, and got it going again. We replaced it anyway and kept the old one as a spare. YMMV
PS Does anyone know what that rounded out area on the plywood top to the water tank is for? It almost looks like there was supposed to be a pull out shower? There is a tee visible down there with a little valve on one of the lines, I'm assuming it's for shore water??
This forum is a life saver.
Edit: geez, I realized I didn't even respond directly to Shovel. I would consider checking the fuse where I mentioned. If power to the fuse, I would consider disconnecting the electrical connector that is on top of the water tank, put a multi-meter and check for voltage when someone turns on the faucet. If there is power there, I would consider opening up the lid on top of the water tank, pulling out the pump, and inspecting for obstructions/movement, etc. If it's getting power and fiddling with it gets you nowhere, buy a new one. Cheers! _________________ 92 Eurovan
Full Westfalia pop up camper |
Bodyzoom Samba Member
Joined: October 12, 2010 Posts: 19 Location: Athens, Georgia
Posted: Mon Feb 05, 2024 7:38 am Post subject: Re: Sink Water Pump |
Not sure if this fits here. I'm having trouble with the faucet, most of the time it doesn't work. The pump works fine all the time when using the back sprayer. It seems like an electrical issue. I've traced the wires, checked the sink wire connections nothing seems to change. Is it the sink faucet or....? |
