jpstewart19 Samba Member
Joined: May 10, 2011 Posts: 253 Location: Chapel Hill, NC
Posted: Wed May 16, 2018 6:54 am Post subject: Truckfridge + Propex + GoWesty Larger Propane Tank? |
I am getting ready to install my new TF49 with a Propex underneath like many of the folks here have done. However, my propane tank is I terrible shape (tag 1/2 rusted off, old regulator, etc).
I am looking at getting a new tank and considering the larger tank. Has anyone done this with the Propex location here? I am concerned that the larger tank will block the routing of Propex vent tubes.
Any feedback would be appreciated. _________________ 1985 Vanagon Westfalia Subie
1972 Super Beetle Convertible
1990 Vanagon GL "Winston" (Sold)
1980 Vanagon Westfalia “Rusty” (Sold)
1982 Vanagon Westfalia “Rusty II” (Sold)
1977 Smurf Blue Campmobile (Sold) |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3795 Location: VA/TN
Posted: Wed May 16, 2018 7:03 am Post subject: Re: Truckfridge + Propex + GoWesty Larger Propane Tank? |
Well, I am in a similar boat. I have a chest fridge. Going to be adding a gas heater before winter. Will probably need to replace my tank also.
I am considering getting a gasoline powered heater (Espar I think). I'd rather more frequently put gas into my van than a heater. I think it uses like a gallon a night? I use my van for weekends. Not going off the grid for many days.
I'd rather frequently refill my gas tank than the propane tank. Plus I can carry Jerry cans with gas in it. _________________ Brandon
Instagram @joannthevan |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16501 Location: Brookeville, MD
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Wed May 16, 2018 7:41 am Post subject: Re: Truckfridge + Propex + GoWesty Larger Propane Tank? |
dobryan wrote: |
I added a second propane tank on the passenger side. This way I can run the first tank dry then switch to the second tank and get the first tank refilled next time I pass a filling station. Never have to worry about running out of propane for the propex or stove. YMMV. |
Xs 2. Plus i added an external T to the secondary tank for running a bbq or fire pit etc, mr buddy heater inside wall tent etc....
Posted: Wed May 16, 2018 7:45 am Post subject: Re: Truckfridge + Propex + GoWesty Larger Propane Tank? |
So I also have a second tank which is in good condition. However, I think the primary needs to be replaced. If I am going to replace it, I might as well go with the bigger tank for an extra $100, but want to make sure it won’t block the Propex _________________ 1985 Vanagon Westfalia Subie
jimf909 Samba Member
Posted: Wed May 16, 2018 9:10 pm Post subject: Re: Truckfridge + Propex + GoWesty Larger Propane Tank? |
Based on your title, I’m assuming that you’re installing the Propex under the TF (as opposed to installing the Propex under the rear bench, under the bus mounted externally, etc)?
You may want to call some of our excellent vendors such as WestyVentures, Peacevans, etc. They have a ton of experience with Propex and TF installs. Karl at Westyvenutes in particular is very helpful and supportive here. If you haven’t bought the Propex or TF yet, I highly recommend buying from Karl. He’s helped me problem-solve. Ping him and my guess is that he knows the answer and will assist with a good path forward.
http://www.westyventures.com/ _________________ - Jim
Abscate wrote: |
westyventures Samba Member
Joined: December 29, 2004 Posts: 2306 Location: Oregon Outback
Posted: Thu May 17, 2018 11:12 am Post subject: Re: Truckfridge + Propex + GoWesty Larger Propane Tank? |
The downsides to the larger 'GW' (Manchester) tank are two-fold: Increased tank height, greatly reduced ground clearance. The tank was not meant to fit a Vanagon so 'changes' are required to make it work and some of them I would never perform in my own shop for customer's safety reasons. I don't believe there will be sufficient space for the Propex pipes to clear the larger tank either. If you need more capacity, add a second tank on the right and tie the two together post-regulator. FYI, the Propex will run approximately 40 hours on a full tank. |
Posted: Thu May 17, 2018 8:45 pm Post subject: Re: Truckfridge + Propex + GoWesty Larger Propane Tank? |
Thank you so much for the info. This is exactly what I was hoping for. Based on this, it sounds like my best bet is to go with the smaller tank.
you are correct that I am planning to put the propex directly under the TF49, along with a converter.
Unfortunately I already have the TF and Propex in my garage ready to go, but have bookmarked your site for future projects. _________________ 1985 Vanagon Westfalia Subie
danfromsyr Samba Member
Posted: Fri May 18, 2018 7:02 am Post subject: Re: Truckfridge + Propex + GoWesty Larger Propane Tank? |
fwiw I have a larger propane tank mounted onto the passanger side by the sliding door.
it's not difficult to extend the lines to the other side. there are flare to flare couplers available. I ran flexible rubber from the tank to the copper. that's how my ASI Riviera model came from the factory.
https://www.google.com/search?q=flare+to+flare+cou...p;ie=UTF-8
yes it hangs lower.
yes it's nice to have 30# equiv in propane. sometimes.
all depends on your needs, wants and uses. _________________
Abscate wrote: |
Altoona Samba Member
Posted: Fri May 18, 2018 9:11 am Post subject: Re: Truckfridge + Propex + GoWesty Larger Propane Tank? |
westyventures wrote: |
The tank was not meant to fit a Vanagon so 'changes' are required to make it work and some of them I would never perform in my own shop for customer's safety reasons. |
What changes do you feel are not safe? |
Posted: Fri May 18, 2018 9:35 am Post subject: Re: Truckfridge + Propex + GoWesty Larger Propane Tank? |
Altoona wrote: |
Too many connections, most of which can be eliminated. It could be made safer - what I don't like is that humongous amount of brass hanging off the side, flexing. If the valve were rotated slightly the regulator could be connected directly w/o all that mess of additional fittings. I also wouldn't install one of those tiny fragile Chinese regulators. I've already replaced a few failed ones at my shop. The mounting brackets supplied also don't appear to use the actual mounting points. How secure is it really, especially with the decreased clearance and greater chance of being snagged off-road. |
Posted: Fri May 18, 2018 9:40 am Post subject: Re: Truckfridge + Propex + GoWesty Larger Propane Tank? |
so your gripe is with installation procedures/practices..
and likely justified.
it's rare I see something someone else installed and go, dang they nailed it right.
I imagine that may the same thing the next guy says on my stuff too. _________________
Abscate wrote: |
Posted: Fri May 18, 2018 9:44 am Post subject: Re: Truckfridge + Propex + GoWesty Larger Propane Tank? |
Altoona wrote: |
Well, to each their own on comfort with additional fittings, but I can say that it does use the factory mount points and is quite secure. |
Posted: Fri May 18, 2018 10:12 am Post subject: Re: Truckfridge + Propex + GoWesty Larger Propane Tank? |
The mounting points of the TANK.
Safety of my customers is priority. If the mass of fittings were all supported by a proper bracket, it might be another thing. But the reality is most of the fittings are unnecessary and the regulator could be screwed directly into the tank valve. |
Posted: Fri May 18, 2018 10:22 am Post subject: Re: Truckfridge + Propex + GoWesty Larger Propane Tank? |
The mounting points of the TANK. |
Ah. Two of the four tank mounts are used on one bracket and the other bracket cradles it tightly to the underside of the van. Personally, I am quite comfortable with the set-up, but I can certainly respect your position. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9603 Location: Western WA
Posted: Sat May 19, 2018 8:18 am Post subject: Re: Truckfridge + Propex + GoWesty Larger Propane Tank? |
Altoona wrote: |
Perhaps welding two westy propane tanks together the full-length of the vanagon underfloor? That would be at least 50% more propane.
You'd wanna pressure-test to 480psi (=2x 240psi service pressure)
Here's a pic of Hodakaguy's new 10% larger tank. The mounting looks easy enough to accommodate.
If'n a fellers OK with an increase of a paltry 10%.
I didn't see mention of where this one came from, it looks like a good replacement.
....KTMs, GasGas, SPOT mtb |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4086 Location: East Kootenay, British Columbia
Posted: Sat May 19, 2018 9:49 am Post subject: Re: Truckfridge + Propex + GoWesty Larger Propane Tank? |
Sodo wrote: |
I didn't see mention of where this one came from, it looks like a good replacement. |
Looks like the standard replacement tank sold by VC and GW
http://www.gowesty.com/product/lp-tank/2447/lpg-tank-with-regulator-?v=
http://www.van-cafe.com/page_1235_1123/new-propane-tank
I have one, nice replacement. I did give it an extra lick of paint. _________________ Currently:
jberger Samba Member
Posted: Mon May 21, 2018 8:33 am Post subject: Re: Truckfridge + Propex + GoWesty Larger Propane Tank? |
I installed a GW larger tank for a friend yesterday. It is mounted securely enough for my peace of mind. It is actually a bit tight to the floor, compressing the sheet metal slightly. I plan to also install a propex but will be putting it in the pantry cabinet forward of the water tank. There is JUST enough room to route the flue and combustion air behind the tank and in front of the water tank... or so it looks.
J |
