calfredson Samba Member
Joined: January 21, 2015 Posts: 70 Location: Vancouver, BC
Posted: Wed May 16, 2018 8:16 pm Post subject: Transaxle issues possibly related to Kennedy adapter plate? |
86 Syncro with Subaru 2.2 conversion
Vancouver BC
Long story short:
Last fall I had my transmission rebuilt after a faulty oil slinger caused a bunch of havoc. About a month ago, I noticed a small transmission oil leak. I took it in to the same shop to have it looked at. They dropped the transmission today and they are claiming that there is too much play with the Kennedy adapter plate and that it is the cause of all the issues. Their claim is that the studs on the adapter plate are too small diameter and therefore allow movement between the transmission and the motor, causing things to fail.
This seems bogus to me and I feel like they are just trying to shift blame away from the work that they did. That being said, the issues now are very similar to the original issue that caused the need for the rebuild. Perhaps there is something else that has been overlooked?
Possibly pertinent, the transmission has shifted roughly since the rebuild and there seems to be more vibration around 300rpm than there used to be.
Any opinions are welcome. I'm also not sure what to do if they claim the issue is not covered by their warranty? How do I go about contesting that?
Thanks,
Craig |
Posted: Wed May 16, 2018 9:27 pm Post subject: Re: Transaxle issues possibly related to Kennedy adapter plate? |
When I did my conversion 10'ish years ago, I immediately recognized the weakness in the way the studs were installed and made changes to the design. I believe that the adapter kits have been changed since then to address this problem. How old is your conversion?
danfromsyr Samba Member
Posted: Thu May 17, 2018 5:38 am Post subject: Re: Transaxle issues possibly related to Kennedy adapter plate? |
the adapter plate should have a ring/ridge that sits into the bellhousing..
that is the centering/locating piece.
it's quite small though and if the 4 mounting studs are slightly loose that allow some or any movement between the transaxle and the plate..
you can lose that alignment slightly.
but it would be obvious in wear patterns on the plate's centering ring..
use lock nuts & lock-tite on the studs. _________________
Abscate wrote: |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Thu May 17, 2018 7:21 am Post subject: Re: Transaxle issues possibly related to Kennedy adapter plate? |
This may be a silly question, but is this shop well versed in VW transaxles, and well aware of the slop required of the input shaft? The quill shaft design does not allow for the input shaft to be tightly screwed on, an error I have seen before. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Thu May 17, 2018 8:24 am Post subject: Re: Transaxle issues possibly related to Kennedy adapter plate? |
The crankshaft and input shaft must be at the same center line. If not, it does not matter who makes the engine or transmission, something will break. Typically it's the transmission/clutch side.
Sounds like the shop is spot on. If anything they may have done wrong is not to mention it the first time around. Using stock stuff, it rarely happens. |
gears Samba Member
Posted: Thu May 17, 2018 11:46 am Post subject: Re: Transaxle issues possibly related to Kennedy adapter plate? |
The alignment of crankshaft and input shaft is VERY forgiving, due to the "quill shaft" design. However, if the design is defeated because the input shaft is screwed tightly to the mainshaft (without having backed off 2 or 3 spline-width during installation), THAT is when problems occur. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
Posted: Thu May 17, 2018 11:56 am Post subject: Re: Transaxle issues possibly related to Kennedy adapter plate? |
I wonder is the adapter plate may not have been properly machined and thus not mate properly with the bellhousing. If the setup was only depending on the bolts for alignment that would not work well. |
Posted: Thu May 17, 2018 1:44 pm Post subject: Re: Transaxle issues possibly related to Kennedy adapter plate? |
Thank you for all the responses.
The adapter plate looks to be in good shape with proper mating to the bellhousing and the engine. The original conversion was done around 2008, so it could be the "old" design of the studs from Kennedy. They are shipping up some new studs, in case this is the problem. Though the van ran perfectly fine for 9 or so years before this became a problem.
The shop is a transmission specialist, this is definitely not the first Syncro transaxle they have seen, but they are not a VW specific shop. |
Posted: Thu May 17, 2018 2:00 pm Post subject: Re: Transaxle issues possibly related to Kennedy adapter plate? |
Here are some photos I took with my phone, for what they are worth. Not sure if they indicate that anything is amiss.
gears Samba Member
Posted: Thu May 17, 2018 3:06 pm Post subject: Re: Transaxle issues possibly related to Kennedy adapter plate? |
It's quite simple to shake the input shaft and see if it feels sloppy (as it should). No VW manual talks about the need for a sloppy shaft, so it's often overlooked by shops who are not "VW specific". This design feature is unique to VW (although it has been adapted by aftermarket). _________________ aka Pablo, Geary
'87 Syncro GL 2.5
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Thu May 17, 2018 3:44 pm Post subject: Re: Transaxle issues possibly related to Kennedy adapter plate? |
gears wrote: |
It's quite simple to shake the input shaft and see if it feels sloppy (as it should). No VW manual talks about the need for a sloppy shaft, so it's often overlooked by shops who are not "VW specific". This design feature is unique to VW (although it has been adapted by aftermarket). |
Yeah, at first I thought that my transaxle was pooched - but they're really ALL like that! _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
gears Samba Member
Posted: Thu May 17, 2018 4:07 pm Post subject: Re: Transaxle issues possibly related to Kennedy adapter plate? |
They have to be like that, or the symptoms described by the OP (vibrations, oil leak, and more) will occur. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
vwoldbug Samba Member
Posted: Thu May 17, 2018 6:29 pm Post subject: Re: Transaxle issues possibly related to Kennedy adapter plate? |
Is the clutch disc not in the center or is that an illusion . |
Posted: Thu May 17, 2018 8:23 pm Post subject: Re: Transaxle issues possibly related to Kennedy adapter plate? |
Is there a pilot bearing in your crank? |
Jon_slider Samba Member
Posted: Sun May 20, 2018 1:43 pm Post subject: Re: Transaxle issues possibly related to Kennedy adapter plate? |
good luck w the tranny leak.. listen to "gears" and verify w your shop that they understand this:
gears wrote: |
The alignment of crankshaft and input shaft is VERY forgiving, due to the "quill shaft" design. However, if the design is defeated because the input shaft is screwed tightly to the mainshaft (without having backed off 2 or 3 spline-width during installation), THAT is when problems occur. |
once you know the back end of the tranny is properly mated,
Assess any changes to inputs at the front end of the tranny, from the VC and PropShaft
calfredson wrote: |
there seems to be more vibration … than there used to be.
Though the van ran perfectly fine for 9 or so years before this became a problem. |
9 happy years, Congratulations!
What changed at the front end of the tranny?
Has the VC become more aggressive?
Are propshaft U joints, and or the original bronze bushing in the guibo, wobbling more than before?
Does removing the prop shaft eliminate the bad vibes?
other factors to consider:
How are your tranny bushings, and front diff bushings?
how are your propshaft angles?
see: https://shufti.blog/2013/01/13/vanagon-syncro-propshaft-angle-measurements-again/
How are your tires, are they wearing evenly, do the tread depths match within 2/32nd?
It may be that something connected to the front of the tranny needs updating, unrelated to the kennedy adapter.
I look forward to hearing of your success! _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Mon May 21, 2018 10:09 am Post subject: Re: Transaxle issues possibly related to Kennedy adapter plate? |
I can see a step on the adapter plate that centers the transaxle regardless of the size of bolts used. Sounds like someone is trying to get out from standing behind the last job. _________________ ☮️ |
