84 Vanagon stuck in gear
Trueblue84
Trueblue84 is offline
PostPosted: Mon May 21, 2018 11:44 am    Post subject: 84 Vanagon stuck in gear Reply with quote
I was driving in 4th gear and went to downshift into 3rd and the shift level stuck. It will not unstick now.
We know the clutch works, as while the tranny is stuck in gear we can run the engine with the clutch depressed. Shift linkage seems fine. No obstructions in the front. When I pull the linkage from the shaft on the tranny I still cannot move the shaft with pliers.
Could this be the notorious disintegrating 4th gear synchro issue? Seems like the research would support this
borninabus
Samba R&D Dept.
borninabus is offline
PostPosted: Mon May 21, 2018 11:56 am    Post subject: Re: 84 Vanagon stuck in gear Reply with quote
it's actually the 3-4 slider hub. but yes, you are most likely right.
sorry Sad
88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport
Trueblue84
PostPosted: Mon May 21, 2018 12:01 pm    Post subject: Re: 84 Vanagon stuck in gear Reply with quote
sorry Sad
Any other tests I can do, or other advice?
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Mon May 21, 2018 12:57 pm    Post subject: Re: 84 Vanagon stuck in gear Reply with quote
The trans needs to come out and be rebuilt or replaced. Sorry.
Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE.
dhaavers
dhaavers is offline
PostPosted: Mon May 21, 2018 12:59 pm    Post subject: Re: 84 Vanagon stuck in gear Reply with quote
^^^ Stop driving before you grenade the whole thing & still have a rebuild-able core...
Embarassed
- Dave
"The WonderVan"
Trueblue84
PostPosted: Mon May 21, 2018 6:22 pm    Post subject: Re: 84 Vanagon stuck in gear Reply with quote
Thanks for the quick replies everyone. Sounds like the jury is in agreement. It's been towed to my trusted VW shop for further inspection. Will update if it's some kind of curveball.
markswagen
markswagen is offline
PostPosted: Tue May 22, 2018 7:29 am    Post subject: Re: 84 Vanagon stuck in gear Reply with quote
Before you drop the transmission, take the linkage off first, I have seen them bind and stick giving the feeling of being stuck in gear.
With the linkage off, can you move through the gears, on the linkage on the side of the transmission, if no, now you need to drop the transmission.
619 201 0310
