/New-to-Me Engine, what's missing
Page: Previous  1, 2, 3 ... 8, 9, 10, 11  Next
Goach2
Goach2 is offline
PostPosted: Sat Mar 17, 2018 12:25 pm    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
So... Is this a total rebuild?
1977 FI Westfalia
Goach2
Goach2 is offline
PostPosted: Sun Mar 18, 2018 7:28 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
<crickets> <crickets>
1977 FI Westfalia
busdaddy
busdaddy is offline
PostPosted: Sun Mar 18, 2018 9:42 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
I'm not sure it qualifies for a "total" rebuild, but the top end shows high time and rough use. The bottom end is strong and may not need much, but from what I see so far I'd splt the case and do some measuring and inspecting iin there to assess.
Aren't you glad you opted to look now?, that valve wouldn't have lasted "a summer or two for local trips" .
Слава Україні!
Goach2
Goach2 is offline
PostPosted: Sun Mar 18, 2018 6:09 pm    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Well, I can't say that I'm 'happy' to find these issues, but it does feel better knowing that it's not going to implode far from home with my young family.
Now to decide which arm/leg to give for a rebuild...
1977 FI Westfalia
tommu
tommu is offline
PostPosted: Tue Mar 20, 2018 3:22 pm    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Maybe I missed it, but how do the Cam and lifters look? What's the endplay like? It really would be a shame not to split the case - but once you do that it is going to take your time and money to do it right. Good luck!
Green Bay Bus Yellow Ghia Blue Bug
Clatter
Clatter is offline
PostPosted: Tue Mar 20, 2018 10:45 pm    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Oo.. Missed this one..
Didja look at the bus motor build in my sig?
I'd be gearing up for to take it all apart and see what's up.
Sometimes you can get lucky,
And not have to spend too much coin.
The hard part is done, the rest isn't heavy lifting, just for your wallet.
Heads are expensive; most expensive part, actually.
You might send those to Adrian at Headflow Masters in LA if you are on a budget.
If he will do them; be ready for him to not do them if they are too far gone.
At that point, you can get a set of new AMC heads from any of the regular vendors.
I might be getting a set of 1.7 heads if you go that way,
They have bigger valves, but you will need them cut for your bigger cylinders.
The best is to get new HAM heads from the type4store.com
But be ready to pay...
Like said by these guys above, get it apart, and check the end play.
At this point, you might still be able to save this and that, so disassemble carefully.
You can usually free a cylinder stuck in a head by -very- -carefully- tapping sideways on it with a rubber mallet this way n that.
The John Muir 'Idiot Manual' has some good tips if yo are new to the rebuild game, and writes it all out really well step-by-step that you won't get in the Bentley.
I'd be finding your local automotive machine shop,
And be getting things cleaned up.
Get it all apart,
And get it all clean.
Any V8 shop can also measure cylinders, and maybe measure bearings and/or rebuild rods.
Then take some pics of the cleaned parts, so we can offer a few tidbits.
And save your money...
Sorry that i was right again,
But,
What you are seeing here is perfectly normal.
Par for the course...
You will be WAY better off in the long run if you go clear through it.
There are some great builds on here.
KentPS and riverside66 are a couple that come to mind recently.
If it was easy, all kinds of people would be doing it.
Bus Motor Build
What’s That Noise?!?
Goach2
Goach2 is offline
PostPosted: Wed Mar 21, 2018 5:45 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Thanks for the suggestions, at this point I'm getting out of my comfort zone (as far as splitting the case goes). I will be sending this out to be rebuilt by someone who knows what needs to be done. I will update with pics as they come.
1977 FI Westfalia
Goach2
Goach2 is offline
PostPosted: Tue Mar 27, 2018 5:56 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Here's an update from the rebuilder;
Cylinder #2 was fried, worst he's seen. The crank is good, looks like cam and lifters are trash. Crank and case out for machining. Here's the proof..
1977 FI Westfalia
busdaddy
busdaddy is offline
PostPosted: Tue Mar 27, 2018 7:51 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Nothing shocking there, looks like the typical used and abused bus motor, good thing you caught it now before it grenaded and there's still some useable parts Wink
Слава Україні!
Goach2
Goach2 is offline
PostPosted: Thu Apr 12, 2018 7:24 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
UPDATE: Heads are warped.
1977 FI Westfalia
Randy in Maine
Randy in Maine is offline
PostPosted: Thu Apr 12, 2018 7:40 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Just a suggestion....
Usually the 2.0L heads are easily cracked also.
My suggestion would be to just plan on replacing the heads, and the camshaft/lifters combo (you want the camshaft and lifters to have the same Rockwell hardness so you buy them from the same supplier).
If it were me, I would just plan on buying heads with the "improved valve guides" (the improved valve guides contain more zinc in the alloy to actually retain heat longer when you come down the hill so they won't drop into the cylinder).
williamM
williamM is offline
PostPosted: Thu Apr 12, 2018 7:41 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Think you will find the 1700 heads have small valves and it's the 1800 that have the biggest valves, however that comes with a different volume so you need flat tops with that- My 2lts with flat tops and 1800 heads just finished a 1000 mile trip (I know not much) with just the Chinese ele foot adjuster getting loose - reports were the thing had lots of power and decent torque- which could have been improved with the small valve 1700 heads.
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
Goach2
Goach2 is offline
PostPosted: Tue May 22, 2018 10:38 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Quick update... Parts are back from machining. Reassembly is underway!
In the meantime, brakes continue... slowly...
1977 FI Westfalia
Wildthings
Wildthings is offline
PostPosted: Tue May 22, 2018 10:53 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Did you replace the three big galley plugs behind the flywheel. They either must be replaced or at least carefully peened in place.
Goach2
Goach2 is offline
PostPosted: Tue May 22, 2018 11:37 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
I will ask the builder, thanks.
1977 FI Westfalia
Goach2
Goach2 is offline
PostPosted: Tue May 22, 2018 11:53 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Peened is the word.
1977 FI Westfalia
Randy in Maine
PostPosted: Tue May 22, 2018 2:12 pm    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Might want to go here and read up some on installing the galley plugs.
https://www.thesamba.com/vw/forum/viewtopic.php?t=671543&highlight=galley+plugs
I used the steel plugs myself....
http://vwparts.aircooled.net/Type-4-Engine-Oil-Galley-Gallery-Plug-Kit-p/galleyplugst4.htm
Goach2
Goach2 is offline
PostPosted: Fri Jan 29, 2021 9:30 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Hello all,
Been a while since I was on this thread, but I figured I'd rather post to it now, instead of starting a new one.
So my 2.0L Jetronic was completely rebuilt by a local VW resource. Since then, I've only put about 1000kms on it, but have yet to change the oil or filter. The builder was going to come by and walk me through some maintenance, but unfortunately COVID happened and his health is already not very good. I already have the Mele filter and gaskets ready to go and I can change the oil and check the strainer as well. I just wanted to ask the hive if there was anything in particular that I need to check on the first change of a new rebuild?
Also, the fuel economy is terrible, though it doesn't seem to smoke at all. Are there things that can be done to 'dial-in' the engine for optimal performance? I'm assuming I should adjust the valves at this time as well.
All advice is appreciated and welcome!
1977 FI Westfalia
SGKent Premium Member
SGKent is offline
PostPosted: Fri Jan 29, 2021 2:30 pm    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Be sure that if you ever pull the oil strainer you NEVER torque the nut to more than 9 ft lbs or permanent damage will occur that will require tearing the engine down again.
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
Clatter
Clatter is offline
PostPosted: Sun Jan 31, 2021 12:47 pm    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Having the motor itself rebuilt is about 61% of the project.
You'll want to make sure the cooling tin that was lost by the PO is all back in place,
And al of the broken/rotten fuel and ignition systems are the correct parts, refurbished, and working correctly.
The Fi system has it's own chapter in the book.
Almost all would have the injectors cleaned and flow-matched (cheap to do).
I'd get a new FI harness from Kyle before doing anything.
You'll need to check every part number, test every component, and seal every air leak.
Get a wideband, learn to use it.
There are a LOT if things you need to do to tune these,
And if it's not tuned right, you'll just kill your new motor.
Sorry to be the curmudgeon again,
But you'll need to continue on.
You're past the halfway point, likely, though..
Usually these motors are killed by a bad tune.
Bus Motor Build
Page 9 of 11
