elizer Samba Member
Joined: May 02, 2016 Posts: 1466 Location: Northern Virginia
Posted: Sun May 13, 2018 7:48 pm Post subject: Re: What did YOU do to your van today? |
Finished up rsfab big shot shifter and t3technique shifter guide bushing replacement. Everything feels tight. I am a fan. |
Gemini2 Samba Member
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3803 Location: VA/TN
Posted: Tue May 15, 2018 7:31 am Post subject: Re: What did YOU do to your van today? |
GoWesty has OEM ones for $18 _________________ Brandon
Instagram @joannthevan |
danfromsyr Samba Member
Posted: Tue May 15, 2018 8:40 am Post subject: Re: What did YOU do to your van today? |
just to note that the HF side lights aren't quite right..
in that they don't have a reflective surface..
and that (sorry to say) they come off as cheap.
do they work and will they work for XYZ's van sure thing..
but if a van were forsale with trailer marker lights, like painted rubber trim. I'd be weary and suspect of shortcuts. _________________
Abscate wrote: |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Tue May 15, 2018 11:16 am Post subject: Re: What did YOU do to your van today? |
Bought a stock alloy rim late last year, and told myself I got it so that when I got a flat, I'd be ready with that in the clam on decent rubber.
Well, I just got lucky to have not gotten a flat before the brain power kicked in and I took lunch break to get the spare out, and have a shop swap the rubber onto the new-to-me stock alloy.
On the down side, no lunch hour nap today, awwwww!
Did have a chance to stop by and see my friend who finally got his mint-green '53 oval out of the garage today, first time out in 8 months! Its Reeeeel Purdy! Too bad his next car (now on order) will be a Tesla with all wheel drive... Kind of creeped me out thinking of him in a red T. Says he missed his mid-life crisis, so he's taking it now, but without loosing a wife or gaining a blond teen trophy. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Tue May 15, 2018 12:22 pm Post subject: Re: What did YOU do to your van today? |
I installed the vintage speed torque elbow. It replaces the cast 2->1 piece and the J pipe. Superb quality of materials, craftsmanship, and fit. Increased performance and a smoother more even exhaust note. I have it mated to my Rocky Jennings 2316. I also run a 2.25" high flow cat and straight through muffler.
Paulbeard Samba Member
Posted: Tue May 15, 2018 5:44 pm Post subject: Re: What did YOU do to your van today? |
Peeled off the masking tape from my roof/luggage rack painting exercise…
A few scwewups but overall, an improvement.
Installed the new skylight seal. Took a while to get it seated but I was able to trim it so the two ends are more flush than the old one was. Maybe I don't get woken by a drip…drip…drip when next I try to sleep through the rain. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
regis101 Samba Member
Joined: July 28, 2005 Posts: 2078 Location: Livermore, Ca
Posted: Tue May 15, 2018 5:47 pm Post subject: Re: What did YOU do to your van today? |
Steve Arndt wrote: |
I installed the vintage speed torque elbow. |
Worth the wait, I'm sure. _________________ Peace, Regis |
campism Samba Member
Joined: September 07, 2007 Posts: 4492 Location: Richmond VA
Posted: Tue May 15, 2018 6:52 pm Post subject: Re: What did YOU do to your van today? |
That is a great looking piece of kit. Surprised something like that has not turned up before now.
I did my annual A/C recharge in anticipation of more 90F weather. _________________ '87 Westy in Wolfram Grey Metallic |
ahmadahere Samba Member
Joined: October 20, 2013 Posts: 106 Location: Illinois
Posted: Wed May 16, 2018 8:17 pm Post subject: Re: What did YOU do to your van today? |
Just installed a light kit! Ohhhh so sexy![/img] _________________ A goal without a plan is just a wish. |
elizer Samba Member
Posted: Fri May 18, 2018 6:35 am Post subject: Re: What did YOU do to your van today? |
Filled up the lpg tank for the first time in a while. Noticed a leak at the open /close valve between open and close but no leak when tightened at either end. New O-ring and regulator is going to be happening really soon. The tank itself is in in amazing condition. Only real rust is on the guard. The plates all look good.
The fridge started up on LPG on the 2nd try. I left the ice trays in over night. Bottom tray was frozen solid. Top tray was par frozen. The thermometer read around high 20s low 30s. I put a camco airator in before I left the house this morning to see if it helps not sure if it will. |
82westyrabbit Samba Member
Posted: Sun May 20, 2018 12:02 am Post subject: Re: What did YOU do to your van today? |
I drove it for the first time in two and a half years. It’s good to have it back on the road after all the work. |
calo1956 Samba Member
Joined: April 18, 2011 Posts: 703 Location: long Island new york
Posted: Sun May 20, 2018 3:29 am Post subject: Re: What did YOU do to your van today? |
I feel like a slacker, all i did was check the dwell with my new meter, took 5 times adjusting the pesky lil points to get it with in specs. (47 +/- 4) But then again it rained all day here.... _________________ Enjoy the ride....
72 bug
80 westfalia |
Posted: Sun May 20, 2018 3:39 am Post subject: Re: What did YOU do to your van today? |
Jumping back to the side marker lights, i installed LED ones from The Bus Depot,$40 awesome quality, actually Mercedes Benz lights, awesome! _________________ Enjoy the ride....
72 bug
80 westfalia |
jimf909 Samba Member
Posted: Sun May 20, 2018 4:38 pm Post subject: Re: What did YOU do to your van today? |
Built the start of a box to mount on the RMW swing-out. It’s big and may look like a bit of a wart but that’s why I’m making it and not paying $$475 or $675 for an aluminess box. The idea is to start big and make a smaller one if it doesn’t grow on me. Time will tell.
I still have to build a door, improve the mount, paint and add side marker and tail lights...
It will hold the hot water heater, some water and jack, ramps, straps, etc. A
_________________ - Jim
Abscate wrote: |
Zeitgeist 13 Samba Member
Posted: Mon May 21, 2018 2:52 pm Post subject: Re: What did YOU do to your van today? |
When I made a new hatch panel, I decided to use the available space on the driver side for a first aid box from a '78 MB I parted years ago. I found a VW kit on ebay for cheap.
_________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
-Derek- Samba Member
Joined: February 24, 2009 Posts: 41 Location: Seattle, WA
Posted: Mon May 21, 2018 8:27 pm Post subject: Re: What did YOU do to your van today? |
Put the finishing touches on the restored pop top.
Posted: Tue May 22, 2018 9:48 pm Post subject: Re: What did YOU do to your van today? |
Brought it home with new paint, reinstalled pop top (too dark for good picture).
Posted: Thu May 24, 2018 7:23 pm Post subject: Re: What did YOU do to your van today? |
I got it registered. Installed new tires and wheels. Unfortunately my my 13 year old was a sleep before I got home so pictures will have to wait until tomorrow. |
