gitchesum Samba Member
Joined: November 10, 2003 Posts: 513 Location: North Cali
Posted: Tue Dec 28, 2004 2:49 pm Post subject: 55 seat rails |
My 55 has a later pan..as you know, if you try to use the 55 seats..they sit up too high in front...anybody have a close up pic of the 55 rails..I have the drivers rails out now and I'd like to cut 'em down in front but I don't know the dimension......or I could use later seats.... _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 rag w/356B brakes
61 356B
Honda XLR 250, 69 Z50, Yamaha 100 Enduro...and others.
GMC SLT 4x4 Dmax
Kubota L3710, not enuf attachments.
And various VW's that come and go... |
Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Tue Dec 28, 2004 5:41 pm Post subject: |
its hard to tell from the pic but the rail on the driver side closest to the door is raised higher than the rest of the rails.
_________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
Joshua B Samba Member
Joined: January 03, 2004 Posts: 273 Location: Colorado
Posted: Tue Dec 28, 2004 9:07 pm Post subject: 55 and earlier seat frame rails |
You know I was checking out the pan on my '51 about a month ago and noticed the driver side outer rail was taller than the other three. At first I thought someone had done some pan modification and I was pissed. But after some research and 55 Bundt's reassurance I was positive it was correct. So what is the deal, why did VW make them this way? DId they do this so if the driver was "heavy" the seat wouldn't sag to the outside ? Also, does this mean right hand drive cars have the big seat rail on the right hand outside instead of the left.
Just curious
Later |
Valmir Azevedo Samba Member
Joined: January 08, 2007 Posts: 15 Location: Santos - Brasil
Posted: Wed May 23, 2018 7:48 pm Post subject: Re: 55 seat rails |
I need the drawing with the correct measurements of the correct position of the rails on the bench and on the floor. Would someone have to post here? Thank you ! |
