KnoxBeetle Samba Member
Joined: October 16, 2016 Posts: 70 Location: Bluffton, South Carolina
Posted: Thu Jul 06, 2017 6:23 am Post subject: I need fog light wiring routing suggestions |
I picked up these awesome vintage IPF Japan fog lights for my 73 super and I'm looking for some suggestions on a good inconspicuous way to route the wires into the trunk. I'll be mounting these on the front bumper. Thanks
_________________ 73 Super beetle |
gt1953 Samba Member
Posted: Thu Jul 06, 2017 6:58 am Post subject: Re: I need fog light wiring routing suggestions |
It is not that hard to figger out. Look under the fender below the head light, you will see the head light drain tube. Run your wire into that which will put it in the head light bucket, then from the head light bucket into the trunk by following the head light wiring. Simple, now from the fog light run along the bumper and into the body along the bumper mounting brackets.
PM me if you need photos. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Thu Jul 06, 2017 7:13 am Post subject: Re: I need fog light wiring routing suggestions |
Figger? Lol. I guess i should've been more specific. I was hoping to get suggestions on where other people with fog lights routed their wires. I'm not saying i don't know how to route wires. I have some ideas but thought maybe someone could have a way i haven't thought of. _________________ 73 Super beetle |
Dodgy Samba Member
Joined: January 30, 2006 Posts: 517 Location: Leicester, UK
Posted: Fri Jul 07, 2017 8:42 am Post subject: Re: I need fog light wiring routing suggestions |
Dodgy wrote: |
Look at a late Super with indicators in the front bumper for ideas.
The wires for the bumper mounted indicators are in a plastic sleeve and follow the bumper bracket through the wing then through the inner wing into the trunk. I can't remember if they merge with the headlight loom or pass through the inner wing via a separate hole. Earth point was a self-tapped screw each side of the trunk, shared with the headlights. |
This is what i was looking for. Thanks! _________________ 73 Super beetle |
Littleeagle28 Samba Member
Joined: April 13, 2017 Posts: 171 Location: U.K. lincs
Posted: Thu May 24, 2018 10:32 am Post subject: Re: I need fog light wiring routing suggestions |
Has anyone got a good suggestion for routing the rear fog light? _________________ 1974 1303 |
bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Thu May 24, 2018 11:08 pm Post subject: Re: I need fog light wiring routing suggestions |
SOmeone recently posted a pic of original VW foglights which had instructions for how to run the wiring. I would copy that. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
Posted: Thu May 24, 2018 11:25 pm Post subject: Re: I need fog light wiring routing suggestions |
bnam wrote: |
SOmeone recently posted a pic of original VW foglights which had instructions for how to run the wiring. I would copy that. |
Great, do you where the link is, also was this for an rear light? Thanks _________________ 1974 1303 |
windfish Samba Member
Posted: Fri May 25, 2018 7:21 am Post subject: Re: I need fog light wiring routing suggestions |
If you want official instructions there's some guides in the technical section, like this (for a reverse light, but same idea) - https://www.thesamba.com/vw/archives/manuals/techbulletins/e3.php
Basically reiterating what was said above, you just follow the existing head/tail-light wire routing and exit through a bumper mount.
bnam Samba Member
Posted: Fri May 25, 2018 8:59 am Post subject: Re: I need fog light wiring routing suggestions |
Littleeagle28 wrote: |
bnam wrote: |
Great, do you where the link is, also was this for an rear light? Thanks |
Sorry, was for the front. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
AlmostHeavenWV_VW Samba Member
Posted: Fri May 25, 2018 9:50 am Post subject: Re: I need fog light wiring routing suggestions |
if you are perplexed to get the wires from the cabin to the trunk, I did this to get some wires to switches for my 12v washer pump. Wires are run through the grommet which was for one of the hoses for the OEM washer bottle to valve on the steering column.
_________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
Posted: Sat May 26, 2018 11:38 am Post subject: Re: I need fog light wiring routing suggestions |
AlmostHeavenWV_VW wrote: |
Mine is for a rear fog light, is your description for the front? _________________ 1974 1303 |
Volks Wagen Samba Member
Joined: February 13, 2013 Posts: 2926 Location: Germany
Posted: Sun May 27, 2018 1:01 pm Post subject: Re: I need fog light wiring routing suggestions |
KnoxBeetle wrote: |
I was hoping to get suggestions on where other people with fog lights routed their wires. I'm not saying i don't know how to route wires. I have some ideas but thought maybe someone could have a way i haven't thought of. |
List out all the ways of routing the wires you thought of so far so that other people don't have to waste their time. _________________ 1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile. |
Posted: Sun May 27, 2018 3:25 pm Post subject: Re: I need fog light wiring routing suggestions |
Mine is for a rear fog light, is your description for the front? |
My example gets your wire from your switch into the trunk for further wiring without having to cut or drill.
Sorry, I don't have any ideas on how to route a wire from front to back. _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
