Body Repair Panels? FAQ
Page: Previous  1, 2, 3 ... 38, 39, 40, 41  Next
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Wed Sep 13, 2017 12:23 pm    Post subject: Re: Body Repair Panels? FAQ Reply with quote
Unfortunately, so is Wolfsburg West.
Does putting your sticker as far away as possible on the same part as the crappy manufacturer's sticker make it any less crappy?
skills@eurocarsplus
Samba Peckerhead
lil-jinx wrote:
Here is an example of the one of the best panel on the market,Gerson panel,it is too short and the body lines are off,
No its not...you're not laying it in there right
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
obx71super
obx71super is offline
PostPosted: Wed Sep 13, 2017 12:28 pm    Post subject: Re: Body Repair Panels? FAQ Reply with quote
Well, that settles that! That's really a bummer to see the klassic fab panel leave something to be desired as well. Need to order a bunch of metal for my 73 riviera. Guess I'm just gonna go with bus depot and get the "best" quality of everything I need. That funky green panel not fitting right is disheartening, thought Gerson had his stuff well dialed in....poop!!
71 super auto stick basically original minus a couple resprays
73 Westy automatic with a 2 liter gex, soon to be a 1.8 liter Headflow masters
Newest Addition!! Solid straight 74 thing totally disassembled!! YEEEWWWW
obx71super
PostPosted: Wed Sep 13, 2017 12:31 pm    Post subject: Re: Body Repair Panels? FAQ Reply with quote
Ah thanks for clarifying skills! So in your opinion, since you know what you're doing, will it be worth the money to get what Gerson offers that I need for my 73, then get the best quality bus depot offers for the rest? Thanks for everyone's input!
lil-jinx
lil-jinx is offline
PostPosted: Wed Sep 13, 2017 3:44 pm    Post subject: Re: Body Repair Panels? FAQ Reply with quote
Skills I hope your right,would you be kind enough to provide a link or info on how it should go on.
1968 Dune Buggy
1974 parts bus
skills@eurocarsplus
Samba Peckerhead
PostPosted: Wed Sep 13, 2017 4:15 pm    Post subject: Re: Body Repair Panels? FAQ Reply with quote
no link...
typically you can't overlay a panel and have it "line up" very well. it's hard to tell from your pic, but the short rocker side of the cheater panel *may* be a little short in the seam...
if you can hold the edge of the panel (the top edge that you'd weld to the bus) to the side of the bus you can probably see if it lines up. the fold in the seam where you are suppose to spot weld it makes it hard to do an overlay.
I have done about 6 of those panels and never an issue...not to say you may have gotten a sloppy one
Jake Raby wrote:
Brian wrote:
lil-jinx
lil-jinx is offline
PostPosted: Wed Sep 13, 2017 6:33 pm    Post subject: Re: Body Repair Panels? FAQ Reply with quote
This may show it a little better,still come up a bit short,but it is a good solid panel and I will make it look ok,when I compare the piece to the Gerson outer rocker,the rocker is also a little longer.
I did try to adjust the seam profile on the panel,but there is not much give in it.
In the above picture it looks to be a bit short,but after I cleaned out 4 coats of paint and filler from the body lines,the panel was/is the proper length.
This picture shows the body line on the repair panel,the bend where I have marked it was to sharp [90 degrees]I have hammered it out some and will have to give it a few more taps to get it to more closely match the og panel.
Over all I am pleased with it.
1968 Dune Buggy
1974 parts bus
cd sullivan
cd sullivan is offline
PostPosted: Thu May 03, 2018 11:26 am    Post subject: Re: Body Repair Panels? FAQ Reply with quote
Please help.
I need to know if the length of treasure chest louvers on a 1969.
Are the same length as the engine bay louvers??
I do not have access to a reference vehicle to measure them and mine came with out them...
I have searched
Thx!
C
It's not finished until its Pinstriped!
orwell84
orwell84 is offline
PostPosted: Wed May 23, 2018 10:19 am    Post subject: Re: Body Repair Panels? FAQ Reply with quote
I'm looking for a left side cargo floor edge for a 73 Baywindow. It looks to be about 12" wide. I have seen it at Schofield's and JK in the UK but not in the US. Bus Depot offers a cargo floor half as does WW. Both seem to have vague stampings in the area I'm looking for. Anyone know of a source for this part in the US? Thanks.
jtauxe Premium Member
jtauxe is offline
PostPosted: Wed May 23, 2018 12:37 pm    Post subject: Re: Body Repair Panels? FAQ Reply with quote
cd sullivan wrote:
Please help.
I have searched
Thx!
C
I could take some measurements from my 1975 single cab:
(more photos at http://vw.tauxe.net/arandano ),
but I am not sure if that is the same for 1969.
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
cd sullivan
PostPosted: Fri May 25, 2018 9:47 am    Post subject: Re: Body Repair Panels? FAQ Reply with quote
That would be great!!!!, Thank you
I have purchased the engine louvers from Auto Craft Engineering, I just need a reference length, I can't see VW making different tooling for the louvers as it would be inefficient...my assumption is there are the same.
jtauxe is offline
PostPosted: Fri May 25, 2018 11:55 am    Post subject: Re: Body Repair Panels? FAQ Reply with quote
Louvers for the engine compartment are 278 mm long, arranged in a 3 x 3 grid.
Louvers for the storage compartment are 298 mm long, arranged in a 2 x 1 grid.
The measurements are +/- a couple of mm, since the edges are rounded and all, but the bottom line is that the storage compartment louvers are 20 mm longer than the engine compartment ones.
John
http://vw.tauxe.net
Yarkle
Yarkle is offline
PostPosted: Fri May 25, 2018 1:39 pm    Post subject: Re: Body Repair Panels? FAQ Reply with quote
if i only have rust below the tail light, could i use theses klassicfab panels on my 73 bus? it says 68-71, but i dont see a difference between them below the lights? One side is damaged so i have to use the thinner ones, but if i could use a gherson product on the other side?
https://www.klassicfab.com/product-category/bay-window-bus/rear-corners/
Tilda the Mustard Tigress 1973 Squareback (o'''^'''o)
https://www.thesamba.com/vw/forum/viewtopic.php?t=771024&highlight=
Tcash
Tcash is offline
PostPosted: Fri May 25, 2018 2:09 pm    Post subject: Re: Body Repair Panels? FAQ Reply with quote
Here r the 2. The 68-71 looks rounder. Im sure if they fit both Klassic Fab would advertise as such.
https://www.thesamba.com/vw/forum/album_search.php...t_dir=DESC
Yarkle
Yarkle is offline
PostPosted: Fri May 25, 2018 5:49 pm    Post subject: Re: Body Repair Panels? FAQ Reply with quote
bummer.... this one busdepot is selling:
http://www.busdepot.com/j39782
"Very nice quality, much better than the versions previously available."
Is thicker than previous klokkerholm panels ive seen, but still thinner than the stock ones.
i didnt think about how the removable rear apron might/would/could affect the shape of the corners
busdaddy
busdaddy is offline
PostPosted: Fri May 25, 2018 6:16 pm    Post subject: Re: Body Repair Panels? FAQ Reply with quote
It depends on your metal skills, the early corner is different on the back edge and where it meets the rear seam, there's lots of meat to trim and reshape it but it's not going to fit or look right if you just slap it on as is.
There's also that bump for the bumper pan the later ones lack.
Слава Україні!
cd sullivan
PostPosted: Mon May 28, 2018 8:19 am    Post subject: Re: Body Repair Panels? FAQ Reply with quote
WOW THANKS!!!!!!
20mm is a massive difference,
this was the last pieces of info. i needed to start on the door.
Thank you again.
Tcash
Tcash is offline
PostPosted: Wed Jun 13, 2018 7:47 am    Post subject: NOS Body Repair Panels Reply with quote
NOS Body Repair Panel Pictures
orwell84
orwell84 is offline
PostPosted: Wed Jul 25, 2018 6:32 pm    Post subject: Re: Body Repair Panels? FAQ Reply with quote
I am considering replacing a cab doorskin for a 73 bus. As far as I can tell the only available doorskins are made by Klokkerholm, both for the U.S. and Europe/UK. Does anyone else make doorskins of the same thickness as orignal? I am fighting a stubborn dent repair, but the rest of the door is original and in good condition. I have heard the Klokkerholm skins are a good fit. Fitting a new skin looks fairly straightforward. It looks to be mostly a measure twice, cut once kind of thing. Any pitfalls/downsides to replacing one vs finding a good used door?
Thanks for the help.
VWsArent4Hippies
VWsArent4Hippies is offline
PostPosted: Fri Oct 05, 2018 7:46 am    Post subject: Re: Body Repair Panels? FAQ Reply with quote
New early and late nose skins from WW
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211805035H
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211805031J
aeromech wrote:
in my opinion you don't know shit
Page 39 of 41
