Bus engine seal - how & when to put in.
mr matt
mr matt is offline
PostPosted: Fri May 25, 2018 5:19 pm    Post subject: Bus engine seal - how & when to put in. Reply with quote
Greetings!
Finally will be putting my bus engine back in tomorrow, and was wondering at what point does the foam seal go in ( around the engine) It seems with the engine in, it would be too difficult to get the seal in a that time, yet putting it on when the engine is out, would cause lack of engine maneuverability while the engine is going in
so not sure how to proceed with this
Thanks!
Matt
1955 3-fold semaphore Oval beetle
1971 Convertible beetle
1977 Westfalia, FI, Berlin interior
timvw7476
timvw7476 is offline
PostPosted: Fri May 25, 2018 5:24 pm    Post subject: Re: Bus engine seal - how & when to put in. Reply with quote
six of one half a dozen of the other......
because of the design, you have to hand fit it around the perimeter, so
it gets installed when engine bolts to transaxle. : (
That is only if you want the engine compartment properly sealed.
EDIT: ^ I assumed the transaxle was already bolted to chassis^
mr matt
mr matt is offline
PostPosted: Fri May 25, 2018 5:27 pm    Post subject: Re: Bus engine seal - how & when to put in. Reply with quote
Oh yea, want that engine sealed right!
Ok, so after you put the engine in, and bolt it up, then there is enough room to somehow insert the gasket around the perimeter. Just did not seem like there is much room there.. but enough I guess then.
timvw7476
PostPosted: Fri May 25, 2018 5:31 pm    Post subject: Re: Bus engine seal - how & when to put in. Reply with quote
the foam units have a deep slit on both sides, one to engage engine tin, the
other for the chassis flange, I've got one rotting engine seal myself right now.
mr matt
mr matt is offline
PostPosted: Fri May 25, 2018 5:38 pm    Post subject: Re: Bus engine seal - how & when to put in. Reply with quote
Thanks, I paid attention to how the foam is attached, was just not sure if it can be put in while the engine is in tight. Seems like a real pain. .. have not tried it yet.
A VW manual talks about putting a support bar under the tranny when the engine is out. - or as it is coming out. Did not do this.. never heard of it.
OOops!
Volswagon
Volswagon is offline
PostPosted: Fri May 25, 2018 6:25 pm    Post subject: Re: Bus engine seal - how & when to put in. Reply with quote
After everything is in place, start one lip of the seal onto engine tins, black side towards street, up toward middle of firewall tin. Work it in around motor, while going back to squeeze other seal lip in, stretching it slightly around the turns. Easier if exhaust is not yet installed.
It is surprisingly easy to squeeze it into the gaps as you work your way around the motor back to the firewall. If you're left with a gap, better it be up high, on the firewall tin. When you're done, you realize it was one of the easiest tasks on the motor.
Last in, first out, if you're gentle, it can survive several cycles.
I know the pieces fit, cos I watched them fall away.
Wanna hear God laugh? Just talk about your plans.
'75 Bus https://www.thesamba.com/vw/forum/viewtopic.php?t=697183&highlight=
Wildthings
Wildthings is offline
PostPosted: Fri May 25, 2018 8:05 pm    Post subject: Re: Bus engine seal - how & when to put in. Reply with quote
Once you get the seal most of the way in from the top you can go underneath and pull the edges down from below to neaten the job up.
Volswagon
PostPosted: Fri May 25, 2018 8:20 pm    Post subject: Re: Bus engine seal - how & when to put in. Reply with quote
Bought my first one at the dealer 20 yrs. ago for ~$100. Imagine my shock when my Import Parts guy had it for ~$35. Got another from him last week for $40+tax.
Wildthings
PostPosted: Fri May 25, 2018 9:11 pm    Post subject: Re: Bus engine seal - how & when to put in. Reply with quote
Yeah, they were dirt cheap 30 years ago, maybe $5 at the right place and $8 at others and then over a few years went to $60 or more. Glad they have come back down. You certainly didn't get better quality material for the extra cash Crying or Very sad and the gasket was usually several inches too short to boot. Crying or Very sad
Lil Lulu
Lil Lulu is offline
PostPosted: Sat May 26, 2018 7:24 am    Post subject: Re: Bus engine seal - how & when to put in. Reply with quote
Make sure to untuck the bottom side right away or the damn thing will take a set all crumpled up. Mine was a bitch to get straight again.
'65 Beetle "Lil' Lulu"- Ruby Red
1600 stock from '71 bus
'72 Deluxe - Niagara Blue w/pastelwiess Camper Special 2L dual 40 Webers 002
'74 Hightop Weekender "Dixie" 1800 34 Del singles
mr matt
mr matt is offline
PostPosted: Tue May 29, 2018 5:51 am    Post subject: Re: Bus engine seal - how & when to put in. Reply with quote
OK! Thanks, looking forward to doing this, as it means at this point the engine is in!
Matt
Terminatez
Terminatez is offline
PostPosted: Tue May 29, 2018 10:10 am    Post subject: Re: Bus engine seal - how & when to put in. Reply with quote
Did it last Saturday. Just use your fingers and push/pull/massage it in. Wear gloves so you don't scratch your nails.
1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote:
I don't think I've ever seen an engine in worse shape.
mr matt
mr matt is offline
PostPosted: Tue May 29, 2018 2:39 pm    Post subject: Re: Bus engine seal - how & when to put in. Reply with quote
Thanks Terminatez , no worries, I don't use nail polish!
Seems like it is more an effort of patience.....
Volswagon
PostPosted: Tue May 29, 2018 4:29 pm    Post subject: Re: Bus engine seal - how & when to put in. Reply with quote
Saw that earlier, and as a guitar player I thought Question
Cheers mates.
Terminatez
PostPosted: Tue May 29, 2018 6:02 pm    Post subject: Re: Bus engine seal - how & when to put in. Reply with quote
LOL! That was an auto-corrected typo brought to you by my phone. Laughing
