Ofir Samba Member
Joined: September 26, 2005 Posts: 460 Location: Israel
Posted: Thu May 24, 2018 10:20 am Post subject: Installation of Steering Lock Housing Assy. w/ Ignition Switch |
Hi,
I would like to know how to remove old Steering Lock Housing Assy. w/ Ignition Switch & installation of new Steering Lock Housing Assy. w/ Ignition Switch?
I mean, I don't understand how to remove the old 2 screws and how to install them.
Thanks |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33882 Location: Conejo Valley, CA
Posted: Thu May 24, 2018 12:20 pm Post subject: Re: Installation of Steering Lock Housing Assy. w/ Ignition Switch |
I think there is a thread about this. But it involves carefully drilling out the breakaway bolts used to install it. New breakaway bolts are available, too. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24670 Location: Olympia Wash Rinse & Repeat
Ofir Samba Member
Posted: Thu May 24, 2018 10:18 pm Post subject: Re: Installation of Steering Lock Housing Assy. w/ Ignition Switch |
Thanks for your answer,
I understand now how to remove the breakaway bolts, but How I install them?
There is only 2 New breakaway bolts and 2 washers, there is no nut?
Thanks again |
Posted: Fri May 25, 2018 7:55 am Post subject: Re: Installation of Steering Lock Housing Assy. w/ Ignition Switch |
Nuts should be welded to the body. _________________ In Stereo, Where Available! |
Ofir Samba Member
Posted: Fri May 25, 2018 10:22 am Post subject: Re: Installation of Steering Lock Housing Assy. w/ Ignition Switch |
Eric&Barb wrote: |
Nuts should be welded to the body. |
So the nuts welded to the body?
When drilling the old screws, those nuts are not damaged? |
Posted: Fri May 25, 2018 10:29 am Post subject: Re: Installation of Steering Lock Housing Assy. w/ Ignition Switch |
Ofir wrote: |
Eric&Barb wrote: |
Yes. Only if one is super duper good at drilling out the bolts. Which is why the other solutions for removing the bolts in that thread would be better. Especially if one is not very experienced at removing threaded fasteners. _________________ In Stereo, Where Available! |
Posted: Fri May 25, 2018 3:11 pm Post subject: Re: Installation of Steering Lock Housing Assy. w/ Ignition Switch |
Ofir wrote: |
Eric&Barb wrote: |
The image above you can see the LH nut in the reinforcement bracket under the speedometer. _________________ In Stereo, Where Available! |
Ofir Samba Member
Posted: Sat May 26, 2018 12:34 am Post subject: Re: Installation of Steering Lock Housing Assy. w/ Ignition Switch |
Thanks much for the picture, it's much more understanding now.
I think this job is not easy, need to drill from the bottom the old screws, and after that need to take out the broken screws that left in the nuts, probably WD40 will help here. (This job should be done very carefully not to damage the nuts) |
Ofir Samba Member
Posted: Sat May 26, 2018 1:48 am Post subject: Re: Installation of Steering Lock Housing Assy. w/ Ignition Switch |
Found picture of the botom of the head screws, it's rounded head
How I can drill it without causing damage ? The drill may slip
Posted: Sat May 26, 2018 8:21 am Post subject: Re: Installation of Steering Lock Housing Assy. w/ Ignition Switch |
Ofir wrote: |
How I can drill it without causing damage ? The drill may slip ] |
Well center punches were created for such, but if you have to ask, it is probably a bad choice for you to drill it out.
Use one of the other solutions in that thread instead. _________________ In Stereo, Where Available! |
Ofir Samba Member
Posted: Sat May 26, 2018 10:23 am Post subject: Re: Installation of Steering Lock Housing Assy. w/ Ignition Switch |
Eric & Barb
Thank you very much for your help!
Ofir |
