apocacist Samba Member
Joined: May 26, 2018 Posts: 12 Location: Pittsburg, TX
Posted: Sat May 26, 2018 10:58 am Post subject: Fuel Injectors not firing, bad ECU?? |
I'm sure this type of thing has been covered ad nauseum here, and believe me I've spent countless hours reading through things and searching. There is one thing that I cannot find: how do you test if the ECU is bad?
I have gone through every test in the L-Jet manual. Everything looks good, the FI wiring harness is good, etc etc. Here's what I'm seeing:
I pull the injectors out, place them in containers, turn the key and nothing sprays. If I bridge the terminals in the ECU harness to the injectors, and turn the key, they spray great.
Now, if the ground pulse from the "-" terminal of the coil isn't getting fed into the ECU, then that could explain this. However, my multimeter just isn't fast enough to measure that quick of a drop. I have a 3.5V-120V test light that does indeed flicker... but I can't tell if the 12V signal is dropping to 0V as it should or just dropping to a lower value.
The other problem I'm seeing is that I get a nice bright blue spark off the main coil wire but only a bright yellow spark off of the spark plug wires. (new cap, rotors, wires, electronic ignition instead of points/condensor). Is it possible that the coil (also new) somehow isn't getting fully discharged and therefore the signal going into the ECU isn't dropping all the way to 0V?
And here's one more thing, which is ultimately making me hesitate to buy a new ECU: the bus was running great but would horribly misfire and buck at high speeds once warmed up (I have a new and tested T2 sensor) and also couldn't hold an idle when warmed up. When it died, I was driving it much longer than I should have been (about 45 mins) and it was bucking terribly. It hasn't started since.
Any help would be greatly appreciated!! |
raygreenwood Samba Member
Posted: Sat May 26, 2018 11:19 am Post subject: Re: Fuel Injectors not firing, bad ECU?? |
You cannot fire the injectors just by turning the key on. You "might" get them to fire once ...as you note with a dumped coil...but as you surmise you will not be fast enough.
Putting things really crudely....First....the ECU needs to see air movement with flow through the meter to turn on the pump. The ECU sees the firing cycle of the coil....creates a square wave to run the injectors...injectors open...coil cycles...wave collapses...injectors close (might be vice versa)..cycle starts over.
First...pull your injectors out of the ports and lay them on rags. Hot wire your pump direct to battery and check you fuel pressure both with no vacuum at the FPR and with vacuum using a hand vacuum pump. Turn the pump off and time how long it takes to bleed down. If you correct pressure and are not losing pressure too fast after shut down and your injectors are not leaking from the tips....the pump, the regulator and injectors are at least sound for fuel flow.
Check the resistance of your injectors. If they match the book....and can be clicked open with a 9V battery...and in those 2-3 seconds they have a good spray pattern....they are good and no further testing is needed unless you send them out for cleaning.
I suspect you have a loose ground...and this can include the ground strap at the battery or transmission...or even a poor ground at the fuel pump or main system power relay.
Or a bad spot on the carbon trace in the AFM....this will cause bucking at certain throttle positions....but this usually will not cause lack of start.
Other common items that can cause bucking and "may" digress to a very hard start condition is a torn or frayed copper ground braid on the distributor breaker plates.
This bucking can also be caused by bad connections at the female connectors inside the harness...when they crack or fray in the strain relief area. They can easily escape detection with a volt meter because their connection issue is caused by vibration while running.
The bucking and then no start...is also a common feature of a plugged up sock filter in the fuel tank. Ray |
Posted: Sat May 26, 2018 11:42 am Post subject: Re: Fuel Injectors not firing, bad ECU?? |
Thanks for the input, Ray. I'm 99% sure that the fuel delivery system is okay. If I bridge terminals 36 and 39 in the AFM connector (to turn on the pump) and then bridge the injector terminals in the ECU connector, they spray great. And I've somewhat verified fuel pump and pressure by connecting a hose to the fuel line, turning they key and aiming the hose away from me... it sprayed like 15 feet.
A test light flickers on the injectors, but again, i cannot tell if they are actually going all the way to ground or not. As best as I can tell, the signal only drops to about .5V (again, REALLY hard to tell with my multimeter) which I don't think is enough to fire the injectors.
(edit) I have a new FI wiring harness. When I tested my 40 year old one, I found leaking current all over the place... pins connected with 40ish ohm resistances when they shouldn't be. So, I'm glad I got the new harness, even if it wasn't the ultimate culprit. (end edit)
I've been strongly suspecting something with the distributor. It has a single vacuum advance and when I hook up a hose and suck as hard as I can, it only moves a degree or so. I don't think this would prevent starting though.
Is there any way to measure the pulse coming off the distributor/coil accurately without using a professional oscilliscope? |
Tcash Samba Member
Posted: Sat May 26, 2018 12:28 pm Post subject: Re: Fuel Injectors not firing, bad ECU?? |
I have a brand new, within spec, bosch blue coil.
I'm using "hot spark" https://www.hot-spark.com/1-air-cooled-vw.htm
It is sparking... again, not sure why i'm not getting a bright blue spark. I do have a new set of points/condenser as a backup... But to be honest, and perhaps a little bit embarrassed, I'm not exactly confident I'm setting the gap correctly. If the points are opening and closing, is that at least good enough to get a rough start/idle?
I'll step out to my shop in a bit and take a hard/close look at my distributor. |
SGKent Samba Member
Posted: Sat May 26, 2018 12:39 pm Post subject: Re: Fuel Injectors not firing, bad ECU?? |
many electronic ignitions won't work right with FI. L-jet relies on the pulse from the points going into the coil primary to tell it that it is time to open the injectors. Why some people have no trouble with electronic ignitions and others do I can't fully tell you. See the Probst book for an explanation how L-jet works. Make sure the trigger wire to the ECU is connected to the correct terminal on the coil. You can pour a table spoon of gas into the plenum etc and see if the bus will run on that for a few seconds. If so then for sure you have a fuel problem. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat May 26, 2018 12:42 pm Post subject: Re: Fuel Injectors not firing, bad ECU?? |
apocacist wrote: |
Thats nice that it sprays...but that is not a proper test. EFI has to have CORRECT pressure...and not just some.
Even a cheap 60 psi water pressure gauge (even though it has accuracy issues of its own)..can tell you if you are in the right range.
I am going off memory here...but I "think" that brand of ignition points replacement module you linked to has had known issues with the pins in the plug causing off again on again running.
If your coil sparks...meaning it will discharge a spark and re-saturate to discharge another spark....then its not the coil.
The ECU is not seeing a "quality" or strength of pulse. Its simply seeing the on/off of current flow into the coil.
What Tcash noted....about electronic ignitions not working with L-jet...is ONLY correct for some replacement electronic distributors that use logic control for advance curves and bypass the switching signal from the coil.....or use a Hall effect module that generates a signal to the module . Those do not use coil signal and will not work with l-jet...without a lot of wiring.
A simple magnetic pickup...like the one shown in your link...is just like the Pertronix or compufire magnetic switches. They will work fine with L-jet. They are just a cleaner switch than pints but a switch nonetheless. They still create a coil off/on pulse for the L-jet system.
I agree for now....go back to points to see if that cleans it up. Ray |
Tcash Samba Member
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Sat May 26, 2018 1:20 pm Post subject: Re: Fuel Injectors not firing, bad ECU?? |
Why people choose to replace points with the distributor installed is beyond me. Just so much easier to do off the engine. You’re supposed to reset the timing after changing points anyhow. So much easier to clean and lube. The find high lobe and set the .016 gap. Place a dab of distributor grease on the cam and spin it around. Recheck the gap and install back into the engine. It’s not possible to index it wrong like some other engines. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
mikewire Samba Member
Joined: March 22, 2010 Posts: 805 Location: San Antonio, TX
furgo Samba Member
Joined: September 06, 2016 Posts: 944 Location: Southern Germany
Posted: Sat May 26, 2018 4:07 pm Post subject: Re: Fuel Injectors not firing, bad ECU?? |
I can only offer an answer to one of your questions myself. Hopefully what others have said can steer you in the right direction.
apocacist wrote: |
In short, if you really want to measure the signal at terminal #1, you can only accurately do it with a scope. That said, a) I'm not sure one could make much sense of the reading as there are no specs to compare to and b) there are probably other ways to diagnose your issue, the scope is generally not part of the toolset of the automotive hobbyist, and I'd say not even of the shops.
The long answer: you cannot really measure the signal at terminal #1 with a multimeter. It's essentially a short pulse in the order of hundreds of Volts during a millisecond or two. Even if measuring its RMS value, I'm not sure you would get anything meaningful out of it.
You might have luck with a multimeter that measures frequency, though. Conceivably that could measure the frequency of the signal at terminal #1 while cranking: if you get a reading, you know the signal is there, whereas if the reading is 0 Hz, there would be no signal. I haven't tried this, though, and I'm not sure it'd work –also, again watch out that the pulse is hundreds of Volts, and that the multimeter inputs can withstand it.
But essentially, you've already proved that there is a periodic signal with your test light and the fact that there is spark; the frequency reading would only attach a fancy figure to it.
Another idea: if you happen to have a tachometer, you can hook it up and see if there is a reading while cranking. That's not without caveats, though. I found that on my tach, while the lowest reading on the dial is 400 rpm, the needle does not move until 500 rpm. I don't know what rpm value you get while cranking, but I'd say it's well below that, so you might not get a reading after all.
To me, the most interesting bit is that you get a flicker on the test light while measuring at the injector connectors. That would prove that the ECU is seeing the signal from terminal #1 and at least generating some sort of injector pulses. Their magnitude, frequency and duty cycle are unknown, though. _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Decode your M-Plate |
Posted: Sat May 26, 2018 11:24 pm Post subject: Re: Fuel Injectors not firing, bad ECU?? |
Gents, I haven't looked at my distributor yet. I took my well needed 7th day of rest today
I've seen some conflicting things about how the coil operates. Here's my understanding, and I would be grateful if anyone with expertise could confirm or correct me:
The coil has a "+", "-", and center (high voltage) terminal. 12V is applied to the "+" which very quickly brings the "-" up to 12V. At that point, the coil is energized. When the coil is discharged through the distributor, that causes the "-" terminal to drop to 0V or ground. It then is quickly brought back up to 12V as the coil is re-energized and the cycle continues. Therefore, the "-" terminal ought to have a 12V to ground square wave type of signal coming off of it. This connects to ECU pin #1 through the wiring harness. The ECU uses this signal to time the injector pulses and the length of each injector pulse is determined by a myriad of other signals input into the ECU from the various other senors attached.
Based on the behavior before it died, I really strongly suspect it's related to the distributor signal and not the ECU, despite all the L-Jet tests telling me to replace the ECU. I don't know exactly what the ECU does with the ground pulse from the distributor/coil, but if it redirects that pulse to the injectors to make them fire, then if that pulse isn't going all the way to ground, neither would the injectors.
I'll get out there and do my points/condenser in the morning, check the braided copper wire inside the distributor, and check the one ground that I haven't yet checked (the one for the transmission?). Unfortunately though, without a good way to test the coil/distributor pulse, I will have no way of knowing if I even did my points correctly . Well, unless it starts after that. |
Tcash Samba Member
Posted: Sun May 27, 2018 6:30 am Post subject: Re: Fuel Injectors not firing, bad ECU?? |
furgo Samba Member
Posted: Sun May 27, 2018 7:00 am Post subject: Re: Fuel Injectors not firing, bad ECU?? |
apocacist wrote: |
The coil has a "+", "-", and center (high voltage) terminal. |
On the coil's construction
The ignition coil has actually two coils inside:
• The primary coil (low voltage), with a "+" terminal (#15) that is applied battery voltage with the ignition key in the "ON" position. And a "-" terminal (#1), which is alternatively pulled to ground or opened by a switch (breaker points) governed by the distributor cam, at twice the engine speed. It's a low resistance (I measured 3.2 Ω on mine), thick wire with few turns.
• The secondary coil (high voltage, high resistance), with the "+" terminal (#15) shared with the primary, and a high voltage (HV) terminal (#4), which delivers the HV pulses that are fed to the spark plugs via the distributor's rotor to generate the spark on each of them. It's a higher resistance (I measured 96.3 kΩ on mine), thin wire with many turns.
I modified an old Bosch diagram to resemble the 4-cylinder ignition system in our busses:
To me personally, it helps giving name to the terminals to better understand what they do and at the same time make sure I've connected them correctly: terminal 15 (voltage supply), terminal 1 (contact breaker), and terminal 4 (high-voltage connection).
On the ignition system and injector pulse train generation
To put it simple, the action that sets all in motion happens at the primary coil: opening and closing the contact points generates a voltage pulse.
That pulse is then "mirrored" by induction at the secondary coil. For the sake of the example, if the turn ratio between coils is 1:100, the resulting secondary voltage will be increased 100 times to produce enough kilovolts to generate the spark.
apocacist wrote: |
Therefore, the "-" terminal ought to have a 12V to ground square wave type of signal coming off of it. |
All that intro was to better explain that it's not a digital signal. Turning on and off a switch connected to a reactive component (coil) does not end up in a square on/off signal. The coil opposes to current changes and it affects its voltage accordingly. As mentioned, the voltage waveform is more pulse-like, in the order of hundreds of volts at max peak (see below).
apocacist wrote: |
This connects to ECU pin #1 through the wiring harness. The ECU uses this signal to time the injector pulses and the length of each injector pulse is determined by a myriad of other signals input into the ECU from the various other senors attached. |
I generally visualize things better with diagrams:
• The waveform on the second row is the voltage from the primary coil, at terminal #1 (-)
• The waveform on the last row is the resulting voltage applied to the injectors, all at the same time.
I hope this helps with the general concept's understanding.
Tcash wrote: |
A dwell meter will tell you if you have a signal and if the points r set right |
Indeed, good point. With the caveat that if he can only use the dwell meter while cranking, the reading will be a bit all over the place. At least that was my experience at one time trying to read the dwell time when the motor did not start.
I think has to do with the fact that the meter cannot see a periodic signal to calculate: the small starter motor cannot give a smooth enough torque for constant speed due to the pistons' compression but no power stroke with the engine off. _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Decode your M-Plate
Posted: Sun May 27, 2018 7:05 am Post subject: Re: Fuel Injectors not firing, bad ECU?? |
apocacist wrote: |
Do a search on your brand of points replacement distributor module in this forum and in the performance engine forum.
I am 100% for sure that a discussion ensued about "non-function" issues with this mode lr brand of points replacement module....because I remember commenting on the really poor design of comnector pins it had in the plug which.....if this is the same model.....has the Molex type round pins.....which suck, suck, suck.....for use on anything automotive. In fact there are no modern critical systems in auto or aircraft that use this pin style because it is not a "spring" backed system.....and has problems with vibration, plugging/unplugging cycles and heat expansion.
Actually here is that conversation....and it was a Mallory system that had an issue with modules burning out.....but the connector system they use is poor and can cause that.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=20
Also....with any of these simple magnetic ignition modules.....ANY poor connections or grounds in the loop will run them hot and they can burn out. And....if at any time while testing.....you hooked the wires up backward as a check and turned on the power.....you just burned it up.
Ray |
furgo Samba Member
Posted: Sun May 27, 2018 7:18 am Post subject: Re: Fuel Injectors not firing, bad ECU?? |
(double post, sorry) _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Decode your M-Plate
Tcash Samba Member
Posted: Sun May 27, 2018 7:40 am Post subject: Re: Fuel Injectors not firing, bad ECU?? |
Tcash wrote: |
I think has to do with the fact that the meter cannot see a periodic signal to calculate: the small starter motor cannot give a smooth enough torque for constant speed due to the pistons' compression but no power stroke with the engine off.[/quote]
The dwell meter will work while cranking. Done it multiple times.
You may have had a problem when you did it.
Tcash |
Posted: Sun May 27, 2018 12:31 pm Post subject: Re: Fuel Injectors not firing, bad ECU?? |
Thanks everyone for all the info. And especially those graphs showing the coil and injector pulses. Those are awesome and exactly what I was looking for. It really helps me to understand how the L-Jet system works.
Well, I took out my distributor and completely broke it down, cleaned and lubed every part, and put it all back together with new points and condenser. The copper braided wire connecting the breaker plates looked good and was well soldered onto both plates.
I don't have a dwell meter, but I am getting sparks. I was unable to locate any ground underneath the bus near and on the transmission though. However, I have checked the 3 sensor grounds underneath the #3 intake manifold, the system ground off of the double relay, and the battery ground. If I'm not mistaken, this takes care of all the grounds used by the FI system.
Still nothing. The engine is turning over from the starter but it doesn't sound like any ignition is taking place. I'm going to go through all the checks in the L-Jet manual one more time before I replace the ECU.
P.S. I removed the ECU, took the cover off of it, and visually inspected the components. I'm not seeing anything obvious. However, there is one transistor on the side that appears to be connected to all four injector pins that cannot be simply visually inspected. It looks like this: https://radio-antigua.com/images/10814%2027.JPG
I am unsure at this point if I feel like it will be worth trying to replace that one component. It's worth noting, however, that the ECU from BusDepot.com has a core deposit which means they intend to fix them... I'd really like to know how they do that!
I will post again after running all the L-Jet tests. Thanks everyone! |
Posted: Sun May 27, 2018 12:55 pm Post subject: Re: Fuel Injectors not firing, bad ECU?? |
I found a mechanic that specializes in old VWs nearby in Longview, TX. I kind of thought I was all alone out here in East Texas! I will probably give them a call and see if I can bring them my ECU to have them test it. |
Posted: Sun May 27, 2018 1:25 pm Post subject: Re: Fuel Injectors not firing, bad ECU?? |
These ECU’s are pretty tough. Before dong anything else open up the ecu and take a close look at the circuit board. Look for burned areas/broken solder joints. Do the sniff test. Usually you can the fault. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
