How to update M-code in Tech section?
Forum Index -> Site Share: Facebook Twitter
bnam
bnam is offline
PostPosted: Sun May 27, 2018 9:58 pm    Post subject: How to update M-code in Tech section? Reply with quote
I came across a Birth certificate today for a typ1 that had an m-code that is not listed.
M531 - Harder suspension for rear
Is there a way to edit the archive info to include this?
Thx,
Byas
Click to view image
1952 Citroen TA 11BL
PostPosted: Mon May 28, 2018 9:45 am    Post subject: Re: How to update m-code in TEch section? Reply with quote
I can add it - thanks!
fusca66
fusca66 is offline
PostPosted: Sat Oct 01, 2022 4:03 am    Post subject: Re: How to update m-code in TEch section? Reply with quote
Hi, more one M-code not listed for a typ1 1952
M068 - Two towing hooks in front
Do you can add EverettB?
Could the original be like this?
https://www.classiccult.com/blog/vw-bug-tow-hook.html
Thanks
PostPosted: Sat Oct 01, 2022 6:55 am    Post subject: Re: How to update m-code in TEch section? Reply with quote
Yes, M68 is listed as unknown, I could update it.
Do you have a car that has this installed and has that M-code to confirm it is correct?
What is the source for your information?
I don't know if the tow hooks would be the same as the web page above as those appear to be aftermarket accessories.
They may have been very similar though.
fusca66
fusca66 is offline
PostPosted: Wed Oct 05, 2022 5:48 am    Post subject: Re: How to update m-code in TEch section? Reply with quote
HI, yes I have the car, but dont have the towing hooks =(
The information was sent on the car certificate issued by VW, if you can I can send photo. The certificate contains 3 items:
M009 - Yellow tail lights
M010 - Cannot be identifield
M068- Two towing hooks in front
The date of birth of the car is 31/10/1952 typ 11C
Bug 1966 2280cc
Bug 1951 1900cc
Bug 1952 typ4 1800cc
Sp2 1972 1700cc
Na duvida não ultrapasse
Reply to topic    Forum Index -> Site All times are Mountain Standard Time/Pacific Daylight Savings Time
