Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Tue May 29, 2018 9:23 am Post subject: BMW E30 high/low headlights and South African grille |
I heard about this conversion recently that it is possible to install the high/low lights from an E30 in the inner position of the SA grille kit. Any info or details to share? It would be slick. They are high quality and projector style.
Thank you!
Steve |
Zeitgeist 13 Samba Member
Posted: Tue May 29, 2018 11:31 am Post subject: Re: BMW E30 high/low headlights and South African grille |
That whole grille would look pretty slick on a van. The E30 was one of the best cars they ever produced. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Tue May 29, 2018 12:38 pm Post subject: Re: BMW E30 high/low headlights and South African grille |
So to be more specific...the low beam projector headlight into the high beam spot on the Van. Right?
_________________ Stuart Zickefoose
206-841-7324
[email protected] |
hardway Samba Member
Joined: January 03, 2012 Posts: 416 Location: Fidalgo Island
Posted: Tue May 29, 2018 12:49 pm Post subject: Re: BMW E30 high/low headlights and South African grille |
I have owned an 88 e30 for a long time. The outboard (ellipsoid) headlights have only one bulb and only one beam pattern. The low beams remain on when the high beams are on.
The very first thing I did to my car was to replace the headlights because the ellipsoids are horrible. I replaced the buckets with sealed beam buckets from a lower trim line e30. I installed Cibie CSR headlamps into the buckets. I got the CSRs from Daniel Stern lighting consultancy. They are far superior to the ellipsoids. Even a standard H4 reflector would be superior to the ellipsoids.
The inner headlights on the SA grille should be high beams. The inner high beam lights on the ellipsoid lights were fine. But they don't hold a candle to the inboard CSR pencils that I have on the 325iX now.
Harold |
bstein Samba Member
Posted: Wed May 30, 2018 10:36 am Post subject: Re: BMW E30 high/low headlights and South African grille |
Steve Arndt wrote: |
I heard about this conversion recently that it is possible to install the high/low lights from an E30 in the inner position of the SA grille kit. Any info or details to share? It would be slick. They are high quality and projector style. |
I'm going out to the garage to investigate this shortly. _________________ 1987 Syncro Wolfsburg Weekender | Triple Knob | SAH 1.8T |
dkoesyncro Samba Member
Posted: Wed May 30, 2018 11:07 am Post subject: Re: BMW E30 high/low headlights and South African grille |
hardway wrote: |
Harold |
This is true! These are a DOT spec ellipsoid light of the 80's, not a DE or E spec ellipsoid. An H4 puts out better lumens. |
Robw_z Samba Member
Posted: Wed May 30, 2018 11:19 am Post subject: Re: BMW E30 high/low headlights and South African grille |
The E30 projector headlights are very deep and there is a bulkhead behind the drivers side of the grill it would bump into.
The inner lights of on an SA grill are technically redundant, so I’ve thought of cutting down the back-side of an E30 headlight to make it fit but not function. I’m totally that kind of guy. It would look cool in the daytime.
-Rob |
bstein Samba Member
Posted: Wed May 30, 2018 11:34 am Post subject: Re: BMW E30 high/low headlights and South African grille |
Robw_z wrote: |
I just took a look at this ...
The inner lights of on an SA grill are technically redundant, so I’ve thought of cutting down the back-side of an E30 headlight to make it fit but not function. I’m totally that kind of guy. It would look cool in the daytime. |
The low beam is very deep and definitely would not fit, but the high beam on my 89 M3 is barely deeper than the SA high beam and looks like it would work.
Brian _________________ 1987 Syncro Wolfsburg Weekender | Triple Knob | SAH 1.8T |
