Can this crank be saved?
swanlakers
swanlakers is offline
PostPosted: Sat May 26, 2018 8:27 pm    Post subject: Can this crank be saved? Reply with quote
Porsche 356 crank, 74 mm. Looks like the gland nut was not torqued properly and the dowels made the holes oval.
So, can I have the holes welded, turned and then drilled for a VW 8 dowel pattern? I would drill into the undamaged part, offset from the filled hole. And the VW dowels are itty bitty compared to the Porsche dowels.
Intended use is as a stroker for a 36hp case. Probably grind rod journals for 36hp rods. Maybe even change stroke to 72mm to ease the fit at the cam.
So, nuts or not?
esde
esde is offline
PostPosted: Sat May 26, 2018 8:42 pm    Post subject: Re: Can this crank be saved? Reply with quote
I had an 84mm, Porsche journal Okrasa crank welded and machined for oversized dowels after a very similar incident. I would imagine that DPR could do it, if not PM me for the contact info of who I used.
SD
modok wrote:
Braukuche
Braukuche is offline
PostPosted: Thu May 31, 2018 2:45 pm    Post subject: Re: Can this crank be saved? Reply with quote
Dowels are the same on 36hp and 356 cranks.
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
