68 T1 Samba Member
Joined: April 29, 2006 Posts: 58 Location: Shreveport LA
Posted: Thu May 31, 2018 6:23 pm Post subject: Tiger striping in metallic paint |
I'm having problems with tiger striping in my paint job I don't know if it's the paint I'm using (duplicolor paint shop) or I'm holding the paint gun too close or don't have it set right but I can't get away from tiger striping with the blue metallic. Does anybody have any suggestions this is driving me crazy having some areas darker than others. |
Spezialist Banned
Posted: Thu May 31, 2018 7:23 pm Post subject: Re: Tiger striping in metallic paint |
Sounds like a single stage issue. _________________
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Thu May 31, 2018 8:06 pm Post subject: Re: Tiger striping in metallic paint |
you need to keep a consistent distance from the panel, then do multiple directions, then a drop coat for metallic orientation.
I bet you're painting left to right, or up and down. can't do that. it's hard to explain... but it's all in the wrist. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
68 T1 Samba Member
Posted: Fri Jun 01, 2018 12:19 pm Post subject: Re: Tiger striping in metallic paint |
I'm new to this what's a drop coat? It is a base clear paint. |
Spezialist Banned
Posted: Fri Jun 01, 2018 12:30 pm Post subject: Re: Tiger striping in metallic paint |
68 T1 wrote: |
https://youtu.be/hqPh0MQQ6Iw _________________
68 T1 Samba Member
Posted: Fri Jun 01, 2018 5:19 pm Post subject: Re: Tiger striping in metallic paint |
So my problem is holding the gun too close and going side to side and up and down gotcha. Any more tips from pros? |
Spezialist Banned
Posted: Fri Jun 01, 2018 5:30 pm Post subject: Re: Tiger striping in metallic paint |
When I do a translucent job, I mix the whole batch and the final coat is diluted and the air pressure is a bit high. And well wrist action.
FOG IT! _________________
Posted: Fri Jun 01, 2018 6:14 pm Post subject: Re: Tiger striping in metallic paint |
the guy in the video is using a $1,000.00+ gun.....
something tells me you aren't.
are you sure your tip size is proper for metallic? because if you're using a 1.0 and it calls for a 1.5-1.7......that .5 or .7 is a HUGE difference.
for a novice metallic sprayer, here is what I would suggest.
do your first coat left to right. let it flash. second coat on a 45* angle, starting at top left, to bottom right. 3rd coat at a 45* angle starting from top right to bottom left. see what it looks like. if you do a drop coat, back up, and do left to right.
so...paint like this: -------- \\\\\\\\ //////////
reason being is you want to have good coverage. like a cross hatch pattern if you will
DO NOT panel paint....this is for an overall. reason being, you will change the pitch of the metallic.
personally, I don't like the way the guy in the video painted. he didn't connect the panels on his first few coats, but kind of did on the drop coat. to his own admission, it works for HIM....painting has it's own style for sure _________________
Jake Raby wrote: |
Brian wrote: |
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Sat Jun 02, 2018 7:16 pm Post subject: Re: Tiger striping in metallic paint |
one thing you need to check is the spray pattern of the gun ....spray it briefly at a piece of cardboard...you dont want it to be a circle like a spray can...or the other extereme like a figure 8...just as large an even oval as you can get (your gun has adjustments for this)....how good a pattern you get has a lot to do with how good a gun you have.... too close or far away affects this as well as air pressure...the stripes are from too much paint in some spots and not enough in others from not overlapping the passes the correct amount...and the lacquer drys so fast that you can get dry overspray at the top and bottom of each pass which will change the texture of the paint and the metallic flakes will not lay down evenly...maybe you need to add some retarder to the paint so it flows better...you may be going too fast, not putting on enough paint to flow into the previous pass...lacquer dries so fast its hard to blend but almost impossible to run...unfortunately you'll just have to keep trying till you hit on a rhythm that works....and technique for lacquer , enamel and urethane all differ....urethane uses different activators depending on temp to make the paint dry at the correct speed...lacquer thinner you have to add retarder to slow it down...and humidity will give you problems too as moisture in the air supply gets trapped in the paint and cant evaporate out before the surface dries, causing a greyish haze called blushing... saw you're in la...believe me heat, humidity and lacquer dont play well together |
