Eccentric camber adjusting bushing
1970fun
1970fun is offline
PostPosted: Sat Jun 02, 2018 10:05 am    Post subject: Eccentric camber adjusting bushing Reply with quote
What kind of steering would you get if the notch in the eccentric camber adjusting bushing is facing backward?
Just found out that mine is facing to the back and the Bentley manual says it should point forward, i think the allignment shop did this a few years ago but never noticed Rolling Eyes
SGKent Premium Member
SGKent is offline
PostPosted: Sat Jun 02, 2018 10:20 am    Post subject: Re: Eccentric camber adjusting bushing Reply with quote
it normally starts facing forward if you don't know where it was, but the actual camber when measured specifies where it will end up. You could have a bent part, or the shop may not have set the correct camber. Find an old time shop if you can. The newer shops aren't likely to have experience with a VW bus.
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
Wildthings
Wildthings is offline
PostPosted: Sat Jun 02, 2018 12:53 pm    Post subject: Re: Eccentric camber adjusting bushing Reply with quote
Insufficient caster will cause the vehicle to want to go anywhere but straight ahead. With the notch forward you have significantly more caster than with the notch facing back.
To achieve maximum caster, what I recommend is that you always have the notch facing dead forward +/-45°, if you can't get the camber in spec doing this then try to get the camber on both sides the same, all the while keeping the notches on both side within 45° of dead forward. It won't hurt much if the camber is a bit out of spec so long as both sides have the same camber.
1970fun
1970fun is offline
PostPosted: Sat Jun 02, 2018 10:54 pm    Post subject: Re: Eccentric camber adjusting bushing Reply with quote
Thanks Guys, i gonne adjust it with the notch pointing to the front and report back how the ride is compared to my old setting.
Tcash
Tcash is offline
PostPosted: Sun Jun 03, 2018 7:20 am    Post subject: Re: Eccentric camber adjusting bushing Reply with quote
Use a coupon and take it to an alignment shop.
Give them these specs.
SGKent is offline
PostPosted: Sun Jun 03, 2018 9:08 am    Post subject: Re: Eccentric camber adjusting bushing Reply with quote
That's really funny. LMAO Laughing
They make a cheap $10 - $15 camber alignment tool you can put on a flat surface and see what your camber is. I don't know if they make one that has a large enough surface area to mount on a VW bus wheel though. It's really designed for tires where a rotor is exposed. A tape measure will set toe. Get them wrong and the damage to the tires will cost you more than an alignment.
1970fun
1970fun is offline
PostPosted: Sun Jun 03, 2018 1:07 pm    Post subject: Re: Eccentric camber adjusting bushing Reply with quote
Well adjusted it today after i marked 3 edges of the nut and turned it 180 degrees to the front, that should do it for the test ride.
Noticed a little better straight ahead driving but not as much as hoped for but my still prety stiff febi ball joints could play a part in this as well!
Needs further allignment at a good shop, any pointers for a full tank or not and extra weight in the front cabin?
Wildthings
PostPosted: Sun Jun 03, 2018 5:56 pm    Post subject: Re: Eccentric camber adjusting bushing Reply with quote
Actually you would want to mark the original 90° location towards the wheel, measure the angle between the 90° position and the notch, say 50° and then turn the eccentric until the notch was 50° in front of the 90° position. This should give you close to the same camber as you had originally, but yes going to an alignment shop would be best.
There are some good DIY threads and it doesn't take much in the way of tools to do a front end alignment, I just use a tape measure, a torpedo level, and an easily made jig. A dead level surface is require if you aren't comfortable with math.
Have the alignment done with the weight you typically have on board, remember to put some weight up front to simulate the driver and passenger.
Busdriver79
Busdriver79 is offline
PostPosted: Tue Jul 09, 2019 1:22 pm    Post subject: Re: Eccentric camber adjusting bushing Reply with quote
Who sells replacement eccentric bushings?..The bushing in the left upper ball joint is stuck and I can't get it off..Right side OK..Ideas?
busdaddy
busdaddy is online now
PostPosted: Tue Jul 09, 2019 1:44 pm    Post subject: Re: Eccentric camber adjusting bushing Reply with quote
Слава Україні!
Busdriver79
PostPosted: Thu Jul 11, 2019 4:27 pm    Post subject: Re: Eccentric camber adjusting bushing Reply with quote
I found a good way to remove this bushing...use a pneumatic muffler "burp gun" Very Happy with a flat head blade...a quick burst, and VOILA !!! Thanks anyway, Busdaddy.
busdaddy
PostPosted: Thu Jul 11, 2019 5:29 pm    Post subject: Re: Eccentric camber adjusting bushing Reply with quote
Good to hear it worked, the wedge is a very powerful tool, aim for the old ball joint to avoid F'ng up the bushing too much.
Слава Україні!
Zed999
Zed999 is offline
PostPosted: Fri Jul 12, 2019 1:44 am    Post subject: Re: Eccentric camber adjusting bushing Reply with quote
Yes, until (if) they loosen up even the correct caster won't be enough.
Good Old Dusty
Good Old Dusty is offline
PostPosted: Sat Dec 10, 2022 6:18 pm    Post subject: Re: Eccentric camber adjusting bushing Reply with quote
I used a ball joint separator to remove the bushing from the ball joint.
The question I have now is, should I put anti-seize compound on the outside of the bushing before reinstalling it into the steering knuckle?
SGKent is offline
PostPosted: Sat Dec 10, 2022 9:07 pm    Post subject: Re: Eccentric camber adjusting bushing Reply with quote
it won't hurt anything in my opinion. Do clean it well first. Smile
Shonandb
Shonandb is offline
PostPosted: Tue Dec 13, 2022 9:58 am    Post subject: Re: Eccentric camber adjusting bushing Reply with quote
Busstom in the Lowering thread posted a link to new, more eccentric bushings.
https://www.ebay.ca/itm/162604378677
Previous 1973 Panel Bus:
Click to view image
Wildthings
PostPosted: Tue Dec 13, 2022 10:43 am    Post subject: Re: Eccentric camber adjusting bushing Reply with quote
That link says the eccentric fits and Bus but the application chart says it does not. I wouldn't buy without getting clarification from the seller.
SGKent is offline
PostPosted: Tue Dec 13, 2022 10:57 am    Post subject: Re: Eccentric camber adjusting bushing Reply with quote
I think a couple places sell refurbished ones that have been re-plated. There is really no reason to need a new one. Most are in excellent shape once cleaned up. That said, the part number is 211405319 / 211-405-319 . Google it and pick someone you like who sells it. Even CIP has repros. There are many ads for them. I am pretty sure Ken Madson at TheBusco or Chris at Busted Bus, Averys Air Cooled would have good used ones.
Busstom
Busstom is offline
PostPosted: Tue Dec 13, 2022 11:29 am    Post subject: Re: Eccentric camber adjusting bushing Reply with quote
[quote="busdaddy"]
Busdriver79 wrote:
Who sells replacement eccentric bushings?..The bushing in the left upper ball joint is stuck and I can't get it off..Right side OK..Ideas?[/quote
This is 3.5 yrs old, and the poster solved it, but for posterity, I was going to suggest another option: cut the stem of the ball joint just above the eccentric, then invert it on a press and drive the stem out.
My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom) 😏
SGKent is offline
PostPosted: Tue Dec 13, 2022 11:36 am    Post subject: Re: Eccentric camber adjusting bushing Reply with quote
or use one of these and a press or BFH
