onezero Samba Member
Joined: September 14, 2005 Posts: 42 Location: Marquette, Michigan
Posted: Sun Jun 03, 2018 7:53 am Post subject: FV Formula Vee shifter question |
Does anyone have the original install instructions for the Formula Vee FV shifter?
I am wondering how the plastic shifter housing mounts to the tunnel. Is it a couple of screws?
Thanks |
Typ3nut Samba Member
Joined: October 08, 2002 Posts: 1192 Location: MI, MotorCity ManCave
Posted: Sun Jun 03, 2018 1:22 pm Post subject: Re: FV Formula Vee shifter question |
Small "L" brackets go under mounting bolts them small screws attach through holes in plastic housing. |
Posted: Sun Jun 03, 2018 1:45 pm Post subject: Re: FV Formula Vee shifter question |
Typ3nut wrote: |
Ok Cool. That helps. I was thinking you had to drill into tunnel. DO you have a copy of original instructions or pics?
Thanks
Shawn |
Posted: Sun Jun 03, 2018 2:05 pm Post subject: Re: FV Formula Vee shifter question |
Typ3nut wrote: |
Also, were the original screws black or silver?
Thanks |
Posted: Sun Jun 03, 2018 7:02 pm Post subject: Re: FV Formula Vee shifter question |
I like the NOS one you have in the box.
I've never seen original installation instructions but I have owned several of these FV Shifters. |
Posted: Sun Jun 03, 2018 7:05 pm Post subject: Re: FV Formula Vee shifter question |
Typ3nut wrote: |
Yes it is cool. But it did not have the install packet with screws or instructions. But I can make a bracket as you indicated and put the screws in it. I am guessing they are black to match.
Thanks for the info. |
