74 Thing Samba Member
Posted: Tue Jun 05, 2018 8:19 pm Post subject: Dimensions for seal between gas tank and the body |
Does anyone know the width and thickness of the foam seal that goes between the gas tank and the body? |
FJBLF Samba Member
Posted: Mon Jun 18, 2018 6:18 am Post subject: Re: Dimensions for seal between gas tank and the body |
I ended up using a 1" wide closed cell roll of foam from HD it was only a few dollars and available locally. |
Zylinderkopf Samba Member
Joined: September 09, 2012 Posts: 679 Location: SE Oklahoma
Posted: Mon Jun 18, 2018 6:51 pm Post subject: Re: Dimensions for seal between gas tank and the body |
If you use the really thick stuff you end up having trouble getting the four gas tank bolts back on. I cut up a cardboard box from amazon...worked great! _________________ 1963 Beetle
1966 Beetle 1300
1970 Karmann Ghia Coupe
1971 Super Beetle
1974 Thing
"A lot of people never use their initiative because no one told them to." |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Mon Jun 18, 2018 7:48 pm Post subject: Re: Dimensions for seal between gas tank and the body |
I use generic hardware store weatherstrip. Depends on what is in my box as to what I use. I like the medium density gray stuff - about 1/2" wide and about 1/4" thick for beetles. But if I am out, I will use the lighter stuff. Its really not that critical. _________________ D-Dubya Manx clone - 63 Short pan,1914.
kubelmann Samba Member
Posted: Tue Jun 19, 2018 4:47 pm Post subject: Re: Dimensions for seal between gas tank and the body |
I use the same rubber trim that goes on the door tops. Looks super but it does require a small section is removed underneath to establish the ground connection for the fuel gauge... |
Al Capulco Samba Member
Joined: October 31, 2005 Posts: 532 Location: Northridge, CA.
Posted: Tue Jun 19, 2018 11:52 pm Post subject: Re: Dimensions for seal between gas tank and the body |
I have a solid rubber gasket under my gas tank and my gas gauge works perfect. My gas tank is ground through the 4 hold down clamps. |
Posted: Wed Jun 20, 2018 8:47 am Post subject: Re: Dimensions for seal between gas tank and the body |
POR 15 inisde/outside of tank created the need to clear an area for ground ~as usual~ a self created problem. Clamps jit the edge trim not the tank... |
