002 Trans in a 181 with 10 degree kit
joosty_chin
joosty_chin is offline
PostPosted: Tue Apr 10, 2018 11:11 am    Post subject: 002 Trans in a 181 with 10 degree kit Reply with quote
Hi all, I found a bus to thing transmission transplant on here but can't find anything on the 10 degree kit where the linkage stays in the tunnel. I have the body and pan separated and am ready to get a 002 trans in the Thing. Any help would be greatly appreciated.
Bashr52
Bashr52 is offline
PostPosted: Wed Apr 11, 2018 4:44 am    Post subject: Re: 002 Trans in a 181 with 10 degree kit Reply with quote
Try in the HBB/Off Road section. Those guys do bus conversions on the regular.
It's a play thing
It's a play thing is offline
PostPosted: Wed Apr 11, 2018 8:24 am    Post subject: Re: 002 Trans in a 181 with 10 degree kit Reply with quote
Yes, with a 10 degree kit your shift rod will stay in the tunnel.
It's not the size of your shop, it's what comes out of it that counts.
I've been playing with my thing ever since I got it...
joosty_chin
PostPosted: Thu Apr 12, 2018 11:16 am    Post subject: Re: 002 Trans in a 181 with 10 degree kit Reply with quote
All I see in there is on those applications like a baha or tube style frame. I bought the kit (just waiting on it to arrive) but I may be having second thoughts. I'm concerned that I may have shifting issues, or a heck of a time getting the linkage just right to shift properly. I also wonder if the engine will then be at a 10 degree angle and not flush like it should be (Would this mess with the 34 PICT Carb?
It's a play thing
PostPosted: Thu Apr 12, 2018 11:45 am    Post subject: Re: 002 Trans in a 181 with 10 degree kit Reply with quote
Shift linkage is not an issue with a 10 degree kit.
joosty_chin
PostPosted: Fri Apr 13, 2018 5:59 am    Post subject: Re: 002 Trans in a 181 with 10 degree kit Reply with quote
Well, the kit has been ordered. It should be a couple months before all is in place. I will keep you all up to date.
It's a play thing
PostPosted: Fri Apr 13, 2018 10:03 am    Post subject: Re: 002 Trans in a 181 with 10 degree kit Reply with quote
The only issue I had using a 10 degree kit in my pre-runner style Thing is with dual carbs, I had to message the air cleaner on the drivers side to fit. other than that the kit works great. I hope that helps, Matt
joosty_chin
PostPosted: Wed Jun 06, 2018 9:38 am    Post subject: Re: 002 Trans in a 181 with 10 degree kit Reply with quote
Ok, I bought the kit and took the pan, kit, and trans to a local VW restoration fella. I just got word that it is complete and ready for pick up. I will try to post pictures when I receive it back.
joosty_chin
PostPosted: Wed Sep 26, 2018 7:59 am    Post subject: Re: 002 Trans in a 181 with 10 degree kit Reply with quote
Did you modify the exhaust for the body, or is your body modified. I'd love to utilize an off the shelf exhaust, but now with the engine at a 10 degree angle I can't get any exhaust to fit. May have to get one modified. Any suggestions?
joosty_chin
PostPosted: Thu Sep 27, 2018 6:48 pm    Post subject: Re: 002 Trans in a 181 with 10 degree kit Reply with quote
I hope the pics help
