nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Mon Jun 04, 2018 12:38 pm Post subject: Re: Westfalia Traders |
Over the left tail light is where it is on my 1966 SO44 |
pillansii Samba Member
Posted: Mon Jun 04, 2018 12:48 pm Post subject: Re: Westfalia Traders |
It’s over the left tail light for all SO-42 for 65,66, and even some very early 67s
Then in 67 it moved to the long drivers side panel just behind the door.
American made kits had the option of putting it where they wanted
But 67 to 71 have the body mounted reverse lights above the brake lights.
Which prompted westfalia to move the location in the first place. |
swharris Samba Member
Joined: September 10, 2010 Posts: 496 Location: N. Orange County
Posted: Mon Jun 04, 2018 12:53 pm Post subject: Re: Westfalia Traders |
DadaCheese wrote: |
Wow, never noticed this (I don't think we have ever removed that seat). Just ran out to ours (1967 SO-42), and indeed, it's there. Very thin, swivels with just enough friction to stay in place.
I assume ours has the electrical warning, but couldn't see from this angle.
LOL, me too. I have a tin top '67 SO42 W/T. I've never looked close under the jump seat. When I do I'll report back. |
Posted: Mon Jun 04, 2018 12:56 pm Post subject: Re: Westfalia Traders |
pillansii wrote: |
As far as I know the outlet being on the jumpseat is a bay window thing.
No split windows had it on the jumpseat. |
THIS^^ Also, I don't think any split SO42 had a circuit breaker or fuse or switch of any kind like the bay had. Bill posted a pic with what looks like a bay jumpseat. Maybe very late 67's came that way. Not sure. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14257 Location: Casa de Oro, California
Posted: Thu Jun 07, 2018 10:25 am Post subject: Re: Westfalia Traders |
swiss_bulli wrote: |
I‘m happy BarryL that our buses look like havi g the same specs. I think also the side power plug hole is different. As far as I remember, the earlier once have a round hole in the wall. Here is mine:
Do you have a photo from anything on the inside?
Here are two photos from TheSamba Technical section of a 1970 Westfalia manual.
This photo is like mine. I know this is Bay and the 3rd year of Bay. I know Bay had this configuration. I know mine came with it there as a June 1967.
The may be a duality in versions as this very same 1970 Westy manual also shows this setup.
swiss_bulli Samba Member
Joined: February 17, 2017 Posts: 123 Location: Switzerland
Posted: Fri Jun 08, 2018 6:24 am Post subject: Re: Westfalia Traders |
Here are some photos from my inlet and power plug. The wiring goes from the plug into the side of the seat and I do not have such a cover plate with the warning sign mentioned on earlier SO-42‘s.
What I was wondering, did the 110v plate on the outside come with a rubber seal similar to the one that the levinton plug uses? Mine was just screwed to the metal, which leads to leakage. |
BarryL Samba Member
Posted: Fri Jun 08, 2018 10:16 am Post subject: Re: Westfalia Traders |
Mine has gasket and same inlet and location as yours.
Here are some photos from my inlet and power plug. The wiring goes from the plug into the side of the seat and I do not have such a cover plate with the warning sign mentioned on earlier SO-42‘s. |
Mine was exactly like yours but I bought new parts from Cole Hersee.
srfndoc Samba Member
Posted: Fri Jun 08, 2018 10:36 am Post subject: Re: Westfalia Traders |
Westfalia seems to have used this setup on European delivered Westy's (possibly in late 67 only) as I've seen this setup on an original owner 67 Westy that was purchased in Germany. Maybe they were testing this setup as a transition to what was used on the Bay Westy's. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
BarryL Samba Member
Posted: Mon Jun 11, 2018 9:42 am Post subject: Re: Westfalia Traders |
pillansii wrote: |
I am 100% sure this bus has never been altered in any way. 100% OG. |
Could pillansii or someone post up a photo of the outside location of that inlet for that outlet on the outside or is it by the taillight? |
Posted: Mon Jun 11, 2018 10:21 am Post subject: Re: June '67 Westy outlet location |
Sorry for the weird angle.
It’s parked right up against a wall right now. |
