Bayouboy63 Samba Member
Joined: October 17, 2015 Posts: 4 Location: Louisiana - (Bourg)
Posted: Tue Jun 12, 2018 7:11 am Post subject: Starts then loses fire, then won't start again |
Now it won't start at all. Turns over good. It was starting and would run 1min or 5 hrs but it's like someone would turn the ignition off and all it does is spin. Ignition wire at the new coil shows 12.6 volts but no spark in (clear) distributor cap. 1972 type II 1600 in fiberglass buggy. This problem just started, been riding this buggy for 2+ years |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15273 Location: Deep in the 405
Posted: Tue Jun 12, 2018 7:35 am Post subject: Re: Starts then loses fire, then won't start again |
Replace the clear dist cap with a good quality Bosch cap. Those transparent things are complete junk and should not even be sold. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Posted: Tue Jun 12, 2018 8:03 am Post subject: Re: Starts then loses fire, then won't start again |
vwracerdave wrote: |
Replace the clear dist cap with a good quality Bosch cap. Those transparent things are complete junk and should not even be sold. |
Ok, that's helpful.
I put it to see the spark. |
Wetstuff Samba Member
Joined: September 23, 2010 Posts: 700 Location: Maryland
Posted: Tue Jun 12, 2018 9:31 am Post subject: Re: Starts then loses fire, then won't start again |
Given you have three posts, Boy, you might wanna listen to someone with 12,000.
Jim _________________ Manx #2614 |
Posted: Tue Jun 12, 2018 10:37 am Post subject: Re: Starts then loses fire, then won't start again |
Wetstuff wrote: |
Jim |
Yep. Helpful again. I have a Bosch 009 with electronic compu fire in it, I put the clear cap just to see. No fire, Bosch cap back on it now, still no fire....No need to be an ass about it!!! Thanks again. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8686 Location: Sunset, Louisiana
Posted: Tue Jun 12, 2018 11:58 am Post subject: Re: Starts then loses fire, then won't start again |
My guess would be either the compufire module or the coil have failed. There are instructions all over the internet describing how to test a coil. I have no idea how to test a Compufire. Maybe install points and see if it runs?
That clear distributor cap is unreliable ... there are lots of reports of them failing. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20360 Location: Just a tiny bit west of Yosemite Valley
Posted: Tue Jun 12, 2018 3:31 pm Post subject: Re: Starts then loses fire, then won't start again |
Put a test lamp on negative (#1) terminal of coil... Attach other side of test lamp to ground....
Spin up engine with starter, if test lamp flashes off/on/off/on/off/on distributor and coil are good.... IF it does not flash coil may have open winding on primary side, or electronic module is not being trigger by magnet or module is fried...
One of these can be your new best friend...
YDBD Samba Member
Joined: February 25, 2017 Posts: 888 Location: Bavaria, Germany
Posted: Tue Jun 12, 2018 8:37 pm Post subject: Re: Starts then loses fire, then won't start again |
Had the compufire module in mine just go bad about 10 years ago...went back to points, no problems. Sometimes they just fail. _________________ '56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing" |
