vwuguy Samba Member
Joined: November 01, 2005 Posts: 1053 Location: southwestern ontario, on and netherlands and bc
Posted: Tue Jun 12, 2018 7:14 pm Post subject: bus advice and will this 40hp run |
crossed my fingers hope this works.. _________________
Tcash Samba Member
vwuguy Samba Member
Posted: Wed Jun 13, 2018 5:03 am Post subject: Re: bus advice and will this 40hp run |
I think a 40hp is light enough that it will not need the adapter maybe?
to fit the 73 westy _________________
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Wed Jun 13, 2018 5:10 am Post subject: Re: bus advice and will this 40hp run |
vwuguy wrote: |
to fit the 73 westy |
How do you plan on mounting it without the (or a) adapter plate? _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Tcash Samba Member
Posted: Wed Jun 13, 2018 9:29 am Post subject: Re: bus advice and will this 40hp run |
vwuguy wrote: |
Going into a 73. Bug Guys have been hanging engines off 002's for years. Should not be a problem, as long as your trans has the two mounting ears on the belhousing.
If the Trans has the 68-73 5:37 ring and pinion (R&P) the gearing will work.
But if it is the later 74-79 4:86 R&P the gears will be a little tall for the 40hp.
Transmission ID
https://www.thesamba.com/vw/forum/viewtopic.php?p=7668732#7668732
Good luck
Tcash |
