fuel pump relay help
cdn_squareback
cdn_squareback is offline
PostPosted: Sat Jun 09, 2018 6:50 pm    Post subject: fuel pump relay help Reply with quote
Hey everyone
I just rebuilt my fi harness and now I'm having an issue. I don't seem to be getting a ground signal (beige wire plastic plug) from the ECM. what does the ecm look for to give the ground signal?
could I just ground that wire ? what would be the side effects from doing that?
thanks for the help
Danwvw
Danwvw is offline
PostPosted: Sat Jun 09, 2018 9:29 pm    Post subject: Re: fuel pump relay help Reply with quote
I would think Ground is just ground and the control wire from the Driver Transistors of Jetronics D control box would be pulsed positive.
Bosch Jetronics D schematic I would make the ground connection the same as the one grounding the control box.
1971 VW Sundial Camper:
Build Sheet: Type 1 1679cc & W-100 Cam, Type1 1800cc's Webcam 118 and 1.25:1 Rockers, Type 1 1800cc with Webcam 163 my current daily driver.
Bobnotch
Bobnotch is offline
PostPosted: Sun Jun 10, 2018 8:57 am    Post subject: Re: fuel pump relay help Reply with quote
cdn_squareback wrote:
Hey everyone
thanks for the help
Are you asking about the #19 wire? If so, that wire goes to the front under dash relay to run the fuel pump. With it grounded, it runs the pump anytime the key is in the on position.
Bob 65 Notch S with Sunroof
mark tucker wrote:
dont the youthinasisa make all our vw stuff? Shocked
Tram wrote:
KTPhil Premium Member
KTPhil is offline
PostPosted: Sun Jun 10, 2018 10:14 am    Post subject: Re: fuel pump relay help Reply with quote
You can try grounding that 19 wire in the engine bay for testing purposes, but I would not drive it that way. One function of that circuit is to cut ground to the pump relay if the engine stops. In an accident, the engine could stop but power still be on, causing the pump to run continuously and possibly dump gas all over.
Danwvw
Danwvw is offline
PostPosted: Sun Jun 10, 2018 10:28 am    Post subject: Re: fuel pump relay help Reply with quote
I assume Type 3 in question here is a 1971 and I see this wiring diagram showing the fuel pump relay running on a wire from a connector from the Jetronix electronics box. Wire J21 and the fuel pump on G6 are shown in this 1972 Diagram:1972 Wiring.
Here 1971 Wiring Diagram
cdn_squareback
PostPosted: Mon Jun 11, 2018 5:13 am    Post subject: Re: fuel pump relay help Reply with quote
Hey everyone
thanks for the help
yes, pin 19 at the ecm that goes to the fuel pump relay 85
cdn_squareback
PostPosted: Mon Jun 11, 2018 5:18 am    Post subject: Re: fuel pump relay help Reply with quote
Hey everyone
thanks for the help
whats the activity of the wire? I imagine it should pulse at key on. what does the ecm look for to send the pulse?
cdn_squareback
PostPosted: Mon Jun 11, 2018 5:25 am    Post subject: Re: fuel pump relay help Reply with quote
in my Bentley, it shows pin 19 out of the ecm to pin 85 of plug 26 on the fuel pump relay.
Bobnotch
Bobnotch is offline
PostPosted: Mon Jun 11, 2018 10:57 am    Post subject: Re: fuel pump relay help Reply with quote
The problem with that diagram, and most in the brown Bentley, is there are no real pics of the FI system in them. You have to go to either the "K" manual, or Elfrink to get the diagram needed.
Tram wrote:
Kanester
Kanester is offline
PostPosted: Wed Jun 13, 2018 10:12 pm    Post subject: Re: fuel pump relay help Reply with quote
KTPhil is offline
PostPosted: Thu Jun 14, 2018 8:01 am    Post subject: Re: fuel pump relay help Reply with quote
That last Elfrink wiring diagram answers a curiosity question I've had for a long time... on an automatic, where does the red electric AAR wire connect? Answer: Same as the fuel pump connection at the pump relay. Which means it lacks power if the engine isn't running, correct?
raygreenwood
raygreenwood is offline
PostPosted: Thu Jun 14, 2018 8:22 am    Post subject: Re: fuel pump relay help Reply with quote
I think that is correct. I need to go back through the pin outs.
This was done several ways across sevsral models. In auto 411 and 412....it surreptitiously gets its power through the enyine speed relay which actually pulls its power from the coil.
The non auto 411 412 do it just like the auto type 3 note that Elfrink made.....from pin 87 on the fuel pump relay. That "should" shut off when engine stops. Ray
raygreenwood
PostPosted: Thu Jun 14, 2018 8:44 am    Post subject: Re: fuel pump relay help Reply with quote
Also.....not sure what version of the Bfown Bentley you guys are using but the Pin out/schematic like the one Kanester posted....is on pages 18 and 19 of the EFI section in Bentley.
Yes....wire # 19 comes straight from the ECU to the pump relay. The ECU gets ground from several locations.
#11 is one ground source to the ECU at the main ground bundle. I do not know about the distribition path inside of the ECU and #11 "may" not be the only ground source. But if those ground bundles are not tight.....you can alternately get no run condition. Ray
