John cilia Samba Member
Joined: May 03, 2016 Posts: 140 Location: Toronto, Canada
Posted: Wed Jun 13, 2018 8:55 am Post subject: Elomar radio fitment question ? |
Iam restoring a 52 11g presently and have discovered that unless I remove the entire ash tray assembly from dash, my Elomar radio will not fit.
Anybody hear or know of this ? _________________ Currently restoring a 1953 11g in metallic blue.
The most important thing on a Tombstone is the Dash between the 2 dates. |
spliteric Samba Member
Joined: November 06, 2006 Posts: 19 Location: JHB South Africa
Posted: Wed Jun 13, 2018 9:31 am Post subject: Re: Elomar radio fitment question ? |
The Elomar is a very early radio, it was introduced in 1949 and was designed to fit a Standard beetle without an ashtray. Later radios for a Split are designed to accommodate the ashtray and won't have this problem.So you either have to lose the ashtray or cut a chunk out of the radio,lol! |
Posted: Wed Jun 13, 2018 9:36 am Post subject: Re: Elomar radio fitment question ? |
Great info Thanks. _________________ Currently restoring a 1953 11g in metallic blue.
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Thu Jun 14, 2018 2:20 am Post subject: Re: Elomar radio fitment question ? |
Could you please post some pictures of how you install that Philps Elomar radio in your split (especially regarding the bracket that you use)?
I have one as well, and I don't have a clue on how to mount it....
Thanks! _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
Posted: Thu Jun 14, 2018 4:48 am Post subject: Re: Elomar radio fitment question ? |
Apparently it's the same brackets and springs that hold the battery in car.
I will post pics when I do it. _________________ Currently restoring a 1953 11g in metallic blue.
Posted: Thu Jun 14, 2018 1:08 pm Post subject: Re: Elomar radio fitment question ? |
What I did was take a small screwdriver at the back of radios and spread panels apart just enough for the battery brackets to hook into. At the back side of dash at radio opening the springs attach there. And it worked out perfect. _________________ Currently restoring a 1953 11g in metallic blue.
tisius Samba Member
Posted: Mon Jun 18, 2018 1:59 pm Post subject: Re: Elomar radio fitment question ? |
Thanks. That's a very effective mounting system like that. And I like how you've painted the radio to match the speedo pod. _________________ drive it like you just robbed the bank
Posted: Mon Jun 18, 2018 2:07 pm Post subject: Re: Elomar radio fitment question ? |
Yes the battery hold down springs are very strong and effective.
But get another person to help hold the radio while your pulling those springs 😆 _________________ Currently restoring a 1953 11g in metallic blue.
