How Many Still Have the A&E TransAwn 2000 Awning?
Page: Previous  1, 2, 3, 4, 5
mwilliamshs
mwilliamshs is offline
PostPosted: Mon Feb 15, 2016 12:47 pm    Post subject: Re: How Many Still Have the A&E TransAwn 2000 Awning? Reply with quote
http://www.eezi-awn.co.za/eeziawn/awnings.html
The Series 2000 look familiar? SAME AWNING.
It's my belief Eezi Awn is just a reciprocal of the A&E brand.
http://www.expeditionportal.com/forum/attachment.p...mp;thumb=1
Here's a pic of the Eezi Awn logo that's on the plastic end caps of their awning. It's basically identical to the A&E logo on my stock caps. Looks like they just flipped the mold plate.
mwilliamshs
PostPosted: Mon Feb 15, 2016 2:12 pm    Post subject: Re: How Many Still Have the A&E TransAwn 2000 Awning? Reply with quote
https://www.e-carefree.com/ecarefree30/ExplodedPartsViewController?productId=79
possible help from another awning brand, Carefree of Colorado. See item 6
My parents have one of their awnings on a camper so I'll test my Transawn foot with their FreedomIII bracket next time I'm down there
mwilliamshs
PostPosted: Wed Feb 17, 2016 9:23 am    Post subject: Re: How Many Still Have the A&E TransAwn 2000 Awning? Reply with quote
Ordered gutter mounting kit from Eezi Awn in Australia, cheaper than dometic even with shipping halfway around the globe. Also ordered new pvc end caps (all 4) and caps plus gutter kit was still cheaper than just brackets from Dometic/Adventure RV/etc. The foot-holding body-mounted brackets are not used/made/available from Eezi Awn.
Anybody got a close-up pic of the Dometic foot brackets?
EDIT: found some
Might just whip up some of these and install with VHB instead of drilling holes
BUT I'd use these spring-loaded, internal retainers instead of that clumsy pin-and-clip that I can imagine leading to paint scratches galore
uncommonvw
uncommonvw is offline
PostPosted: Mon Sep 12, 2016 7:53 am    Post subject: Re: How Many Still Have the A&E TransAwn 2000 Awning? Reply with quote
I just picked one of these up on the weekend for my Whitestar. I found it while looking at cheap tent trailers.
Looks to need a good cleaning and the latches are rusty. I was happy to pay $100 CDN for it. I'll make my own gutter mounts to attach it to the van. Thanks for the links to find the latches. $20 a pair is fine by me.
sake
sake is offline
PostPosted: Thu Jun 14, 2018 1:49 pm    Post subject: Re: How Many Still Have the A&E TransAwn 2000 Awning? Reply with quote
Bought an Eezi Awn 2000, does anyone know where to buy mounting brackets + pressure clamps? (Europe preferred).
rmcd
rmcd is offline
PostPosted: Sun Mar 31, 2019 9:54 pm    Post subject: Re: How Many Still Have the A&E TransAwn 2000 Awning? Reply with quote
Just found us distributor.
https://www.equipt1.com/products/series-2000-awning
VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight=
kamzcab86
kamzcab86 is offline
PostPosted: Tue Aug 20, 2019 4:01 pm    Post subject: Re: How Many Still Have the A&E TransAwn 2000 Awning? Reply with quote
For those buying an old Trans-Awn or a new Eezi-Awn, you can use Fiamma mounting brackets:
I ditched the small 30-year-old Dometic brackets a couple weeks ago and installed the beefier Fiamma brackets (ARB brackets would probably work as well, but RMW didn't have any in stock when I was browsing). The original case holes were re-used, but an additional hole was added for each bracket. The awning is now sturdier and sits higher eliminating this problem: https://www.thesamba.com/vw/forum/viewtopic.php?t=706841 . Added bonus: The accessory track on the case can now be used for... accessories! Very Happy
If you go this route: You'll be using only two brackets. Adding a third at the C-pillar will be impossible without making modifications. There's a lengthwise curve to the vans, which makes it difficult to utilize a third/center bracket without adding a ton of torque/outward force to the front bracket and, thus, damaging the gutter (I hypothesize that that's the reason for the minor gutter damage on my van since the awning was mounted using 3 Dometic brackets).
~Kamz Anxious
2016 Golf GTI S
ambrose_d
ambrose_d is offline
PostPosted: Fri Jul 03, 2020 1:25 pm    Post subject: Re: How Many Still Have the A&E TransAwn 2000 Awning? Reply with quote
Any luck with these? Or anyone else come up with a solution for the bottom bracket?
chojinchef
chojinchef is offline
PostPosted: Tue Dec 08, 2020 2:52 pm    Post subject: Re: How Many Still Have the A&E TransAwn 2000 Awning? Reply with quote
Anyone have a set of end caps for the trans awn kicking about?
Just need to borrow for some reverse engineering to create some repro availability.
Thank you
LP
Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory.
Love My Westy
Love My Westy is offline
PostPosted: Tue Dec 08, 2020 9:09 pm    Post subject: Re: How Many Still Have the A&E TransAwn 2000 Awning? Reply with quote
Thank you
LP
They are available from Eqipt Expeditions in Salt Lake City. They are the Eezi Awn importers:
https://www.equipt1.com/collections/awnings
chojinchef
PostPosted: Wed Dec 09, 2020 5:05 am    Post subject: Re: How Many Still Have the A&E TransAwn 2000 Awning? Reply with quote
Well that makes that repair easy. Thank you.
Thank you
LP
KBM
KBM is offline
PostPosted: Wed Jan 19, 2022 1:52 pm    Post subject: Re: How Many Still Have the A&E TransAwn 2000 Awning? Reply with quote
Still have the TA-2000. Bought the Bus Depot Larger Awning with walls. Want to keep the AT-2000 installed for overnights then add the BD Large awning for several days stays. Best of both. AT-2000 attached with two GW brackets.
Have seem some make bracket for raising the roll up awning attached to the roof rack leaving almost all of the rain gutter available for the tent type awning.
Anyone seem this or done it themselves?
Annie a 87 Vanagon Camper - 2.1 Auto
rmcd
rmcd is offline
PostPosted: Wed Jan 19, 2022 9:06 pm    Post subject: Re: How Many Still Have the A&E TransAwn 2000 Awning? Reply with quote
Kind of? I modified a set of aluminum TransAwn brackets to add more bearing surface where it rests on the gutter. I also experimented with making them taller. Maybe there is lesson or approach that will help you?
And a set for sale. https://www.thesamba.com/vw/classifieds/detail.php?id=2503031
Page 5 of 5
